05-06-2015, 09:35 AM | #8603 | |
Rep 179
My next step would be sourcing the problem.. Any ideas where to start? |
05-06-2015, 10:10 AM | #8604 |
Rep 40,768
Not really.
05-06-2015, 10:25 AM | #8606 |
Rep 40,768
Good luck. I'd be checking the fuses again...
05-06-2015, 10:34 AM | #8607 |
Rep 179
05-06-2015, 06:15 PM | #8608 |
Rep 11
Hello all,
Where can I find the latest versions for PSdZData, E-sys and EDIABAS ? My Enet cable has just arrived, but I think the versions on DVD received are too old for my F30 (PSdZData 50.3, my car was made at 2014-08-08)... |
05-06-2015, 06:58 PM | #8609 |
Rep 40,768
PM sent.
05-08-2015, 01:53 AM | #8612 |
Rep 40,768
Are you wanting to use OEM FSC Codes or an Activation Module?
05-08-2015, 08:59 AM | #8613 |
Rep 1,976
Drives: 2020 G20 320i M Sport
Hey Shawn, not sure if you know but I tried getting the folding mirrors to work on my F23 and no luck. Weird part is, I've done this before on an F33 and it worked fine. I also did similar steps on FRM and CAS on an F13 and the mirrors folded without any issue so I don't think it's because I have a convertible. I have the button on the door sill to close it within the cabin so the functionality is there.
I ended up using 55.4 to generate the NCD, renamed it to its 55.1 equivalent and used to FDL editor to make changes then changing it back to its 55.4 name before FDL coding. Amber delete and unlock doors when when engine worked if that matters. Is there something I might be missing? KOMFORTSCHLIESSUNG_FB AKTIV KOMFORTSCHLIESSUNG_PA AKTIV ASP_BEIKLAPPEN_BEI_KOMFORTSLIESSUNG AKTIV ASP_AUSKLAPPEN_NACH_KOMFORTSLIESSUNG AKTIV
Vehicle Diagnostics | CarPlay Solutions | Retrofit & Repair Consulting/Programming steve.ma@cmbsolutionsltd.com | www.codemybimmer.ca Online Store | Remote Coding Package| ID6 Retrofit for almost all F Chassis BMWs |
05-08-2015, 09:21 AM | #8614 | |
Rep 40,768
05-12-2015, 05:37 PM | #8617 |
Rep 16
ESys files missing from download location
05-12-2015, 07:40 PM | #8618 |
Rep 40,768
Add 2TB to FA and VO Code car.
05-12-2015, 07:41 PM | #8619 |
Rep 40,768
PM sent.
05-13-2015, 06:59 AM | #8622 | ||
Rep 40,768
PM's sent.
