BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > Remove Automatic Gearbox to replace with Sport Automatic Gearbox
Studio RSR
      07-04-2013, 11:51 PM   #1
henryeeex
Drives: 2013 335i
Anyone have a slightest clue on how to remove the automatic gearbox?
Trying to swap the standard automatic gearbox with the sport one that comes with the leather boot.
      07-05-2013, 10:56 AM   #2
diesel86
Drives: 2012 BMW 328i Sportline
I assume you are actually talking about swapping the actual shifter rather than the entire gearbox (transmission). I think there was a thread recently about a person trying to retrofit this same thing on his vehicle, but I believe was having some difficulty because it may have needed some coding as well. He was trying to add the paddles though so maybe that was the problem.
2012 328i Sportline - Black Sapphire Metallic - 8AT Sport
I pronounce it "Beemer" and turn my fog lights on even when it's not foggy.
      07-05-2013, 11:22 PM   #3
henryeeex
Drives: 2013 335i
You have a link to that thread? search bought nothing. And yes, I do want to switch out the swifter to the nice sport one w/ the leather boot.
      07-06-2013, 01:04 AM   #4
Frogman
Drives: 2012 F30 328i
There's a thread by a guy who did this on his F10.
http://www.bimmerfest.com/forums/sho...ighlight=shift
      07-06-2013, 07:50 PM   #5
shawnsheridan
shawnsheridan's Avatar
Man...that guy is good.
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant
2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE
      07-07-2013, 12:01 AM   #6
Frogman
Definitely worth a few dancing bananas, but this forum doesn't have them
so:
      07-07-2013, 12:11 AM   #7
shawnsheridan
so:
...and that's just not right, so I borrowed these from Bimmerfest:
      07-07-2013, 01:43 AM   #8
Frogman
Attachment 885089
But they aren't dancing!
      07-07-2013, 01:45 AM   #9
shawnsheridan
Hey...I can only do so much...
      07-07-2013, 04:46 PM   #10
henryeeex
Drives: 2013 335i
      07-07-2013, 08:49 PM   #11
shawnsheridan
Guilty as charged.
      08-07-2013, 04:46 PM   #12
larryzhou
Drives: 120i mt
it's a easy job.
unclip the console deco strip
unclip the console trim
unclip the shifter lever base trim
unscrew the shifter, then unplug,
      08-18-2013, 12:11 AM   #13
henryeeex
Drives: 2013 335i
Any reason for unclipping the console strip / trim? I removed the shifter level base trim and had access to the screws to the shifter... I believe that's it right?
      10-31-2014, 05:36 AM   #14
PSILVA
Drives: F31 318dA
Hi, i want to do this in my F31 with 205, i want change just the gear trim with the 2TB, it's just unplug the old one and plug the new?? No coding ??
Thanks
      10-31-2014, 10:10 AM   #15
carzaddict
Drives: 2015 Cadillac Escalade ESV
it should be plug and play....but coding will be required.
2015i Cadillac Escalade ESV
      10-31-2014, 10:12 AM   #16
PSILVA
Drives: F31 318dA
And I code 205 or 2TB?
      10-31-2014, 12:08 PM   #17
Frogman
AFAIK, you don't need to code anything to just retrofit the shifter (it's not programmable).
But, if you want the Sports Auto Transmission (SAT) features, you would change 205 to 2TB in your FA and then VO code EGS, KOMBI, and ICM. You don't want both option codes in there at the same time!
You will get a stability error when you VO code the ICM, it should go away after you turn the car off and back on again.
      10-31-2014, 12:42 PM   #18
PSILVA
Drives: F31 318dA
Ok, code:
2TB in FA
In VO
EGS 3000Applikat Sportschalter aktiv
EGS 3000 Applikat Sportschalter_alt aktiv
EGS 3000 Applikation_LC / LC aktiv
ICM 3000 LCMKOD_B_SPORTLENKUNG aktiv
And Kombi?
Thanks
      10-31-2014, 03:30 PM   #19
Frogman
Ok, code:
2TB in FA
In VO
And Kombi?
Thanks
You are confusing the two things.
There are 2 ways to code SAT.
1. VO coding. You simply change 205 to 2TB in your FA and "Code" (not FDL code) your EGS, KOMBI, and ICM. You do not need to do any FDL changes like what you list; the "VO coding" does it for you. This is the faster and possibly safer way to code SAT.
2. Change the individual FDL codes are you indicated. Using this technique does not require you to change the FA. You only need to change the FA when you VO code (like in # 1). The ECUs do not look at the FA while they are operating.
If you want to FDL code SAT, then you missed the following:
ICM / 3000 / LCMKod_B_S2TB aktiv
You have to code the KOMBI to get Sport+ mode to show up in the instrument cluster. To do so, you have to code the following:
KOMBI / 300C / FDS_MENUE_TEXT_1 to menue_3
KOMBI / 300C / FDS_MENUE_SIGNAL_1 to menue_3
KOMBI / 300C / FDS_MENUE_TEXT_2 to menue_3
KOMBI / 300C / FDS_MENUE_SIGNAL_2 to menue_3
KOMBI / 300C / FDS_MENUE_TEXT_3 to menue_3
KOMBI / 300C / FDS_MENUE_SIGNAL_3 to menue_3
KOMBI / 300C / FDS_MENUE_TEXT_4 to menue_3
KOMBI / 300C / FDS_MENUE_SIGNAL_4 to menue_3
      10-31-2014, 06:15 PM   #20
PSILVA
Drives: F31 318dA
Ok thanks Frogman
      11-21-2014, 08:37 AM   #21
PSILVA
Drives: F31 318dA
Hi, how to remove the shifter level base trim to have access to the screws to the shifter (nš 3)?
      11-21-2014, 08:58 AM   #22
carzaddict
if you dont mind me asking, how much is the part? im interested in doing the mod myself
