02-11-2014, 08:29 AM | #45 | |
Rep 32,881
02-11-2014, 08:37 AM | #47 |
Rep 3,445
Drives: G22 M440D
I bought an Sdrive because it was already much lower.
Meaning I don't have to fanny around with aftermarket parts and fitting, and hope that it looks lower but still drives faultlessly in all conditions without affecting my warranty. Without going aftermarket you have to weigh up if the increased ride height, weight and drag are worth the extra traction. Going by the other threads on the subject, there are many different thoughts on that.... D.
Escort Mk1 RS2000 (2.1 2x44IDFS, BVH, Kent FR32, 5spd, 180 BHP) : M440D ¦ Previously : F32 435D : F32 430D M Sport sDrive, 335D E92 2006
02-11-2014, 08:38 AM | #48 | |
Rep 32,881
02-11-2014, 10:12 AM | #49 | |
Rep 11,292
But from what I understand ALL xdrive BMWs (even E9X’s) had higher suspension. We know its possible to have 4WD and have lower suspension, just look at Audi’s. I think a lot of us here would actually like to know the real reason why BMW choose to fit higher springs.
Current: Golf R Mk8Previous: Golf R Mk7.5 Mercedes AMG C63 S Coupe F80 M3 Competition Pack |
02-11-2014, 10:21 AM | #50 | |
Rep 1,919
02-11-2014, 11:00 AM | #51 | |
Rep 3,445
Drives: G22 M440D
Might be as simple as trying to keep the driveshafts as level as possible, or having a certain minimum clearance between your transfer case and the ground. Especially if they expect any off road aspirations, or borrow the setup from the X series. D.
02-11-2014, 11:04 AM | #52 | |
Rep 15,858
On the xDrive issue, we can only guess at BMW's reasons. I suggest they are looking at the bigger picture, the world market and have compromised on a mid range suspension ride height setting. We must remember some markets still have models with "rough-road" suspension, riding higher. With my design hat on, I do believe they will have calibrated the xDrive to perform at optimum levels within those suspension parameters. I'd like to be proven wrong, but suggest that having different suspension frequencies (due to a lower suspension and higher spring rates) could mean revised calibrations to achieve and comply with BMW target values. Doesn't mean they can't do that for the F30/31 with current xDrive hardware, with a lower suspension... but who knows the full picture? HighlandPete |
02-11-2014, 11:19 AM | #53 |
Rep 19,982
I was under the impression that the Alpina D3 can be had as an xdrive in LHD markets... if this is the case then there is clearly a way it can be done, as there is now way I can imagine that Alpina would have a car on the market with standard xdrive ride height!
02-11-2014, 12:03 PM | #54 | |
Rep 1,919
02-11-2014, 12:14 PM | #55 |
Rep 385
Interestingly Aberdeen BMW stated to my co worker that if he lowered his 320d x drive the only parts that were no longer covered under warranty were suspension components (springs, shocks, bushes, wishbones et al). Which would imply that there aren't any other major issues with doing it.
It could also be the dealer being retarded. I've told him to get it in writing from them and then fit the springs. |
02-11-2014, 12:18 PM | #56 | |
Rep 1,919
02-11-2014, 12:38 PM | #58 | |
Rep 19,982
The whole point of giving a warranty (for a company) is to ensure peace of mind and good customer service, so I don't think it makes that much sense to assume they are going to try and use any excuse to avoid fixing your car whilst under warranty... it's just bad customer service. Sure, if someone has clearly been abusing their car, not maintained at all like it is supposed to, or modified it such that this caused the issue then fair enough. Most issues you hear about when there is a disagreement is whether you have a failed component or wear and tear leading to a replacement needing required, or post warranty when major things go wrong... or component failure leads to greater damage eg. swirl flaps |
02-11-2014, 01:29 PM | #59 | |||
Rep 15,858
HighlandPete |
02-11-2014, 01:52 PM | #60 | |
Rep 19,982
02-11-2014, 02:22 PM | #61 |
Rep 15,858
Biggest part of my career was in the safety business, R@D and design. I started out with an apprenticeship in general engineering, then into the production environment, had a period in the motor trade, but went back into the engineering business. Started my own company along with my father, which led to innovative product in the safety business, which company is now going from strength to strength. I bowed out several years back and basically slowed down to early retirement.
HighlandPete |
02-11-2014, 02:53 PM | #62 |
Rep 5,021
@BMWSKI:
Sorry to state the obvious, but do you not think you shaould have bought an sDrive if you are so concerned with the aesthetics? Put it this way, your car rides high as if on stilts like an SUV, has a saloon body and it will negotiate those speed bumps perfectly. You've got the best of both worlds in a way, just minus the sleek looks. Be happy.
Previous: Superman 330d sDrive M Sport + Toys
Present: Red Tornado Golf 7R 5 Dr, DSG + Toys |
02-11-2014, 03:11 PM | #63 | |
Rep 1,919
That's why I posted about ACS exhaust mods recently but that went down like a lead balloon! I don't think I dare start asking about performance upgrades Your comment 'your car rides high as if on stilts like an SUV' is a tad exaggerated I feel |
02-11-2014, 03:15 PM | #64 | |
Rep 5,021
But I must admit that to an sDrive owner, the xDrives do look a tad odd.
02-11-2014, 03:23 PM | #65 |
Rep 11,292
It doesn't look odd compared to other manufacturers (look at Fords)!
But it looks a little odd for a BMW. anyway, it's a small price you have to pay for a fantastic car.
