BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N20, N26, B46, B48 Turbo Engine / Drivetrain / Exhaust Modifications > BMW 320i Dyno Results!
      08-05-2013, 02:38 PM   #45
Jamesons Viggen
Drives: '98 M Roadster stg 2+ S/C
Originally Posted by Wrinckled View Post
So what is the stage 2 (non-Beta) putting out on the 320i's?
266whp
http://www.n54tech.com/forums/showthread.php?t=19987
'98 Dinan/RMS stage 2+(VAC cams, CES Cutring etc)
'15 Buick Regal "T"(wife)
'06 Saab 9-5 Combi 5mt (full suspension, LSD, clipped turbo etc)
      08-05-2013, 02:40 PM   #46
TheDukeYYC
Drives: TBD: F30 320i ZSP + ZMT ?
Originally Posted by Jamesons Viggen View Post
That is Stage 2 BETA. again, there isn't a non beta yet. I believe they are waiting for electronic control of the waste gate solenoid.
      08-05-2013, 04:17 PM   #47
Wrinckled
Drives: 1990 325i
Beat me to it, thanks for the feedback though guys.
      08-05-2013, 06:09 PM   #48
Jamesons Viggen
I did not specify beta or non beta, only showed the most current dyno and numbers.
Keep holding your breath for the electronic boost control. It's not going to really change the power outcome much at all.
      08-05-2013, 06:44 PM   #49
Wrinckled
Drives: 1990 325i
I'm just trying to see what the nonbeta would produce. You never know, it could be significantly higher / lower.
      08-06-2013, 09:26 AM   #50
Jamesons Viggen
That was not the case when stage 1 went in and out of beta. It's more about small refinements. If it was anything that drastic, they would not allow so many in the hands of customers so early.
Me, I am holding out for electronic solenoid control before I jump back into a piggyback.
      08-06-2013, 10:16 AM   #51
Wrinckled
Drives: 1990 325i
Hmm.. the current Stage 2 version that is out - is it easy to "un-do" when going in for services?
      08-06-2013, 10:43 AM   #52
Jamesons Viggen
Should be less than 10 minutes. Stage 1 took me under 5.
      08-06-2013, 10:46 AM   #53
Wrinckled
Drives: 1990 325i
Good man, thanks for the fast replies & non sarcastic responses.
The internet needs more people like you hah!
Just curious, what's the worst that could happen / risks on a 320i w/ Stage 2 in beta?
      08-06-2013, 11:15 AM   #54
Jamesons Viggen
Well, I saw an N20 that needed a full engine replacement due to a failed injector-he had a AFE tune and the dealer is nice enough to realize it was not the fault of the tune. Most dealers would not be so nice, and you can be on the hook for $5-10-15k. But he also did not bother to remove the tune when he brought it in.
      08-06-2013, 11:54 AM   #55
Wrinckled
Drives: 1990 325i
That's terrifying... I'd feel unethical bringing my car in if my engine broke due to an aftermarket tune :\
      08-06-2013, 01:09 PM   #56
Wrinckled
Drives: 1990 325i
Is there a link to where you've seen this? I'd like to read up on it.. I wonder if BMS is more reliable.
      08-06-2013, 01:48 PM   #57
Jamesons Viggen
It's the chance you take. Do not modify the car if you do not want to go down this road.
http://www.bimmerfest.com/forums/sho...d.php?t=712292
      08-06-2013, 02:26 PM   #58
TheDukeYYC
Gotta pay to play.
No such thing as a free lunch.
Insert Cliche here
      08-06-2013, 03:07 PM   #59
Wrinckled
Drives: 1990 325i
I wonder what the chances are, haven't heard of any malfunctions with JB4.
      09-06-2013, 01:12 PM   #60
joedimarzio
Drives: 2014 BMW 328i, Sport Line
Hi Guys,
I have installed the Stage 1 from BMS on my 320i. I bought it to a reseller in Chile, but after knowing that the Stage 1 comes with default presets for the 328i, i want to check if the values are correct and suitable for my 320i. I know that you can modify the main values of the box by connecting to a BMS software. Does anyone know how to do this?
Can someone kindly please explain on detail how to do this, and what are the optimal values for best 320i n20 performance? (I want to achieve those 220whp)
Has anyone used this software before?
Than you guys!,
      09-06-2013, 02:11 PM   #61
brunox2
brunox2's Avatar
Brazil
17
Drives: BMW ///M3 E92 AW
Originally Posted by joedimarzio View Post
Hi Guys,
Than you guys!,
Boost over stock should be 4
you have to download the software from n54tech.com and make sure that you have this configuration, the rest is all the same, confirmed yesterday.
08' BMW ///M3 E92 AW
      09-08-2013, 09:07 AM   #62
uluj333
Drives: bmw
BMS N20 Tuning Box, 4psi setting adjusts how?Setting out of box? Setting up the software is? (default 3psi?)
Thank you ...
      09-09-2013, 01:07 AM   #63
Nikor
Nikor's Avatar
Israel
Drives: F30 320i
here
http://www.n54tech.com/forums/showpo...69&postcount=1
      09-11-2013, 06:03 PM   #64
joedimarzio
Thank man, but, you know the procedure? you just have to plug the box to the laptop and do the change? with the engine running or not?
thanks!
      09-15-2013, 07:29 PM   #65
aspang86
aspang86's Avatar
Drives: 2012 BMW 320i
has anyone tried running 5psi with the stage 1? I have 94 octane fuel available and was wondering if it would be safe?
      09-15-2013, 10:18 PM   #66
TheDukeYYC
I tried it on my car... Didn't notice a difference...
I am running the same (I assume) Petro_Canada 94 octane.
Currently set at 4.5PSI.
