06-04-2017, 09:00 PM | #1 |
Rep 12
Could this be due to flashing or coding?
My wing mirror turn signals dont work, neither do the door handle leds. The internal footwell lighst also dont work and not sure if this is due to me flashing the FEM module or due to coding.
The car was a salvage and didnt take note of these things working or not. Could be a fuse but not sure.. Please help guys.. |
06-05-2017, 04:33 AM | #2 | |
No 55mph
1621
Rep 8,476
Check fuses 1st, then check for proper voltage @ ends of wiring harness where actual lamps plug in, etc.
06-05-2017, 07:17 AM | #3 |
2JZ-GTE
3032
Rep 3,992
Depending on how you code th car? It could be an issue. But since it's a salvage like others have mentioned it might have issues ? Good luck
06-07-2017, 02:21 PM | #6 |
Rep 12
Rear and front turn signals work. Im suspecting the fem as well but could be the fuse on the module im hoping.
Cant figure out how to access it though |
