07-06-2016, 10:22 PM | #1 |
Rep 208
Which Cold Air Intake Should I Choose
I've narrowed it down to tree choices
1. First is the Injen CAI. This seems to be the one I see people have the most on this forum and the majority of the people who have it seemed to be pleased. I'm not too sure about it not being a sealed air box intake. http://www.topgearsolutions.com/inje...i-f30-n26.html 2. AFE Momentum Pro intake. I've seen that some people have this one and again seemed to be pleased with it, but haven't really seen as much feedback about it as the Injen. This one is a sealed airbox. http://www.topgearsolutions.com/afemainstsip2.html 3. AFR Stage 2 Intake. This one I haven't seen anybody with this intake. This is an open exhaust although AFE sells a box you can put a around it. http://www.topgearsolutions.com/afe-...28i-f30-n.html |
07-06-2016, 11:22 PM | #3 | |
Rep 208
07-06-2016, 11:34 PM | #4 |
Rep 1,627
I doubt any of them will hinder performance, but the Injen seem to be the highest quality for the price (for sound).
M4 in MG | 6 MT
07-07-2016, 08:03 AM | #6 | |
Rep 208
07-07-2016, 09:51 AM | #8 | |
Rep 764
07-07-2016, 10:10 AM | #9 | ||
Rep 208
07-07-2016, 10:31 AM | #10 | |
Enthuisiast
93
Rep 423
There are always going to be trade offs between different intakes. Metal tubes may see a rise in IAT's, but the plastic intakes can warp or (depending on mfg quality and design) reduce the airflow (compared to a smooth aluminum tube.) Some plastic intakes can be BETTER than the aluminum tubes since you can design and tune plenums in specific ways compared to using a simple extruded aluminum tube. They are also relatively inexpensive to produce. Take it with a grain of salt though since the differences will likely not be noticed in any significant way on a stock car. My main concern with an intake system would be the air filter element itself. You can compare different types of tube materials but the filter type and flow seem paramount to me. A properly sized intake tube and high flow filter will work well enough. Like all mods, there is a finite amount of power to gain from a modified intake system. Other things to consider would be air inlets, size, heat shields and boxes (keeping the air flowing into the filter as cool as possible) and not to mention the MAF sensor position and location. From what I have seen, it seems that upgrading the intake should be paired with the JB4 for best results otherwise the stock MAF reading could be a little unstable. Hope that helps!
AW F80 M3 / RAYS / TOYO TIRES / BMS
IG: @hybrid_david |
07-07-2016, 10:51 AM | #11 | ||
Rep 208
07-07-2016, 11:16 AM | #12 | |
Enthuisiast
93
Rep 423
I do have other cars (non-BMW) and have a hand in developing performance intake systems for them through my company. I've been doing a lot of research on F30 systems and from what I have seen, the BMS intake seems to be the best value. I have read concerns about the tube housing warping issues (not surprising) and their fix for it. The AFE looks like a really nice part as well but I have yet to see much to justify the costs, especially when none of the manufactures will put out dyno graphs. No matter which route you go, it seems like the JB4 will make anything better.
IG: @hybrid_david |
07-07-2016, 11:22 AM | #13 | ||
Rep 208
07-07-2016, 11:38 AM | #14 |
Rep 4,322
check the N20 engine sub-forums. currently, there are a few threads on injen and awe intakes up top.
it seems injen has the best performance gains and is what most have. however, from what i have read intakes don't do much except make more sound (for the N20/26) and look pretty in the engine bay. personally i'd just put a HPA high flow air filter and spend towards a tune or ER FMIC and charge pipe. flash or piggyback tunes are largest performance enhancement for the least amount of money, without a shadow of a doubt. |
07-07-2016, 11:47 AM | #15 |
Member
457
Rep 1,517
Intakes are for looks and sound only. I find it impossible that just an air intake gains you 10 HP without a tune.
Here are some cheaper alternatives to gain 5 HP: -Kick your GF out of the passenger seat -Clean out 50 lbs worth of junk in the car -Remove the back seats
Previous: 2013 135i Space Grey w/Coral Red | 6 Speed MT | M Pkg | JB4 | AA Downpipes | AA Exhaust |
Previous: 2015 M3, BSM[/SO/CF | DCT | Adaptive M | 19" Black | CF Roof | Previous: 2018 M2, AW | DCT | Exec Pkg Current 2020 X7 50i |
07-07-2016, 11:49 AM | #16 |
EMT - Firefighter
86
Rep 418
Drives: BMW f30 340xi mppsk
Went for option 3 because i bought it used at a good price. I don't really care for the performance gain discussion. Still i love the increase sound of the DV.
BMW 2012 328i F30 Sport / Ext black / Mperf Front and Rear bumper / Front lip and rear diffusor Mperf / Oem Yellow BBK / Low kick carbon spoiler / Varrstoen ES1 / H&R coilover / 335i MPE / AA flash tune + burble / ER downpipe
07-07-2016, 11:50 AM | #17 | |
Rep 208
07-07-2016, 12:49 PM | #18 |
Rep 2,802
07-07-2016, 12:54 PM | #19 | |
Rep 208
And I have a full catback exhaust on my car and it was recently at the dealer to get some stuff fixed under warranty and they didn't say anything about the exhaust so I imagine and hope they wouldn't care about an intake. |
07-07-2016, 12:58 PM | #20 | |
e90noob
1588
Rep 1,862
every 8 pounds shaved is the equivalent of gaining 1 hp
2008 E90 M3 / LCI trunk + euro tail swap
Production date - 2008-04-22 |
07-07-2016, 01:22 PM | #21 |
Rep 16,065
07-07-2016, 01:40 PM | #22 |
Enthuisiast
93
Rep 423
If you have a 328i N20, the results may be different than what I have been seeing with the N55 EWG F30. As stated above, you really need a tune to get any sort of significant increase in power. That pretty much applies to any car, except for like a Mustang GT or something. hehehe
IG: @hybrid_david |
