09-13-2014, 03:30 PM | #45 | |
Rep 40,650
11-04-2014, 03:46 AM | #46 |
Rep 3
Hello everyone
In a few days will withdraw my BMW 316d f31 Sportline used Dec 2013 with 8000 km. I will start to code something on my PC and I installed version 3.25.3 of ESYS PSdZData with 52.1 but I read that this version is not stable. Can someone kindly fornirimi the link to download the most stable version? Thanks in advance Best regards |
11-04-2014, 06:23 AM | #47 | |
Rep 40,650
11-04-2014, 12:42 PM | #49 |
Rep 40,650
PM sent.
11-04-2014, 11:29 PM | #50 |
Rep 105
Drives: 2015 335 xDrive M Perf Ed -LSB
Coding DVD video
11-05-2014, 04:28 AM | #51 |
Rep 40,650
PM sent.
11-23-2014, 11:30 AM | #52 |
Rep 61
So I have the e-sys program. Shawn, can you help me with the Psdzdata for a F30 2012 335i? I need instructions to download and place them in appropriate folders. Oh and I have the m-power pack. Would it be an issue to program some items live dvd in motion etc. Would I break the m-power programming in anyway? Thanks for the help.
11-23-2014, 12:19 PM | #53 | |
Rep 40,650
11-23-2014, 12:37 PM | #54 |
Rep 61
Thanks for for quick reply Shawn. Much appreciated. I have the two files part 1 and part 2. What I don't know is the correct directory structure to put the extracted file in (especially part 2). Thanks for helping out.
11-23-2014, 12:45 PM | #55 | |
Rep 40,650
http://www.rarlab.com/rar_file.htm Some RAR files can be parts of multi-volume sequences. In WinRAR you can split a huge archive to a few smaller files, which are called volumes. They may have extensions .rar (the first volume), .r00, .r01, ..., or .part1.rar (the first volume), .part2.rar, ..., etc. If you need to unpack volumes, place all them to the same folder and start extraction from the first volume. So, open only Part1.rar and hit Extract. It will automatically extract all files and folders that are spanned across all parts of the .RAR archive. When you are done extracting, you will have your psdzdata folder that you will copy to your E-Sys data folder (e.g. C:\Data\psdzdata).
11-30-2014, 11:32 AM | #56 |
MVP
Rep 32
Drives: BMW F30 XDrive
Video in Motion
Shawn
I have a 2015 328i XDrive and the cable coming soon. I would like to code the video on thumb drive. Please send me the info for the latest versions. Thank you very much in advance. |
11-30-2014, 11:33 AM | #57 |
Rep 40,650
PM sent.
Persian0.00 |
11-30-2014, 12:45 PM | #58 |
MVP
Rep 32
Flashing
11-30-2014, 12:48 PM | #59 | |
Rep 40,650
Flashing is entirely different.
12-03-2014, 07:37 PM | #60 |
MVP
Rep 32
read FA failed!
Shawn,
I followed all instructions, got successful connection popup. But when I try to read code I receive the following message. Please let me know if you can help. thanks Read FA failed! possibly there is no FA stored Here is the description ParameterizationException: Code=49184, CodeDescription='Object with name not found', Severity=2051, VendorCode=3, VendorCodeDescription='provided name CONFIG_ECU_ETHERNET doesn't map to an item' __________________________________________________ ___ com.bmw.esys.domain.psdz.PsdzException: Read FA failed! Possibly there is no FA stored in the VCM. [C060] at com.bmw.esys.domain.psdz.Psdz.requestFA(Psdz.java: 1333) at com.bmw.esys.domain.fa.FalLogic.readFa(FalLogic.ja va:89) at com.bmw.esys.gui.fa.FalController$ReadWriteControl ler.doRead(FalController.java:194) at com.bmw.esys.gui.DefaultReadWriteController.read(D efaultReadWriteController.java:75) at com.bmw.esys.gui.ReadWriteSupport$ReadAction.doAct ionPerformed(ReadWriteSupport.java:93) at com.bmw.esys.gui.AbstractView$AbstractGuiAction.ac tionPerformed(AbstractView.java:234) at javax.swing.AbstractButton.fireActionPerformed(Abs tractButton.java:2018) at javax.swing.AbstractButton$Handler.actionPerformed (AbstractButton.java:2341) at javax.swing.DefaultButtonModel.fireActionPerformed (DefaultButtonModel.java:402) at javax.swing.DefaultButtonModel.setPressed(DefaultB uttonModel.java:259) at javax.swing.plaf.basic.BasicButtonListener.mouseRe leased(BasicButtonListener.java:252) at java.awt.Component.processMouseEvent(Component.jav a:6505) at javax.swing.JComponent.processMouseEvent(JComponen t.java:3320) at java.awt.Component.processEvent(Component.java:627 0) at java.awt.Container.processEvent(Container.java:222 9) at java.awt.Component.dispatchEventImpl(Component.jav a:4861) at java.awt.Container.dispatchEventImpl(Container.jav a:2287) at java.awt.Component.dispatchEvent(Component.java:46 87) at java.awt.LightweightDispatcher.retargetMouseEvent( Container.java:4832) at java.awt.LightweightDispatcher.processMouseEvent(C ontainer.java:4492) at java.awt.LightweightDispatcher.dispatchEvent(Conta iner.java:4422) at java.awt.Container.dispatchEventImpl(Container.jav a:2273) at java.awt.Window.dispatchEventImpl(Window.java:2719 ) at java.awt.Component.dispatchEvent(Component.java:46 87) at java.awt.EventQueue.dispatchEventImpl(EventQueue.j ava:735) at java.awt.EventQueue.access$200(EventQueue.java:103 ) at java.awt.EventQueue$3.run(EventQueue.java:694) at java.awt.EventQueue$3.run(EventQueue.java:692) at java.security.AccessController.doPrivileged(Native Method) at java.security.ProtectionDomain$1.doIntersectionPri vilege(ProtectionDomain.java:76) at java.security.ProtectionDomain$1.doIntersectionPri vilege(ProtectionDomain.java:87) at java.awt.EventQueue$4.run(EventQueue.java:708) at java.awt.EventQueue$4.run(EventQueue.java:706) at java.security.AccessController.doPrivileged(Native Method) at java.security.ProtectionDomain$1.doIntersectionPri vilege(ProtectionDomain.java:76) at java.awt.EventQueue.dispatchEvent(EventQueue.java: 705) at java.awt.EventDispatchThread.pumpOneEventForFilter s(EventDispatchThread.java:242) at java.awt.EventDispatchThread.pumpEventsForFilter(E ventDispatchThread.java:161) at java.awt.EventDispatchThread.pumpEventsForHierarch y(EventDispatchThread.java:150) at java.awt.EventDispatchThread.pumpEvents(EventDispa tchThread.java:146) at java.awt.EventDispatchThread.pumpEvents(EventDispa tchThread.java:138) at java.awt.EventDispatchThread.run(EventDispatchThre ad.java:91) Caused by: could not retrieve ECUIdentifier for SystemFunction CONFIG_ECU_ETHERNET Timestamp: Wed Dec 03 20:10:05 EST 2014 ErrorCategory: SYSTEM_ERROR ID: 1929 Class: com.bmw.psdz.vehicle.connection.wrapper.Configured DProject ExecutionContext={category=SETUP, ecuid=(UNKNOWN,?)} at com.bmw.psdz.vehicle.connection.wrapper.Configured DProject.getSystemFunctionHostEcu(ConfiguredDProje ct.java:489) at com.bmw.psdz.vehicle.connection.wrapper.LinkPool.g etSystemFunctionHostECUId(LinkPool.java:249) at com.bmw.psdz.vehicle.connection.wrapper.LinkPool.g etSystemFunctionECUId(LinkPool.java:230) at com.bmw.psdz.vehicle.connection.wrapper.LinkPool.o penLink(LinkPool.java:430) at com.bmw.psdz.programmer.AbstractProgrammer.openSys temFunction(AbstractProgrammer.java:1076) at com.bmw.psdz.programmer.ProgrammerImpl.systemFunct ion_requestFAFromConfigECU(ProgrammerImpl.java:228 ) at com.bmw.psdz.uc.VCMImpl.requestFA(VCMImpl.java:160 ) at com.bmw.psdz.api.impl.bf.VCMBF.requestFA_aroundBod y0(VCMBF.java:31) at com.bmw.psdz.api.impl.bf.VCMBF.requestFA_aroundBod y1$advice(VCMBF.java:79) at com.bmw.psdz.api.impl.bf.VCMBF.requestFA(VCMBF.jav a:1) at com.bmw.esys.domain.psdz.Psdz.requestFA(Psdz.java: 1329) ... 41 more Caused by: com.bmw.prodias.exceptions.mcd.ParameterizationExc eption: Code=49184, CodeDescription='Object with name not found', Severity=2051, VendorCode=3, VendorCodeDescription='provided name CONFIG_ECU_ETHERNET doesn't map to an item' at com.bmw.prodias.collections.mcd.AbstractNamedColle ction.getItemByName(AbstractNamedCollection.java:2 41) at com.bmw.prodias.collections.mcd.db.LogicalLinks.ge tItemByName(LogicalLinks.java:13) at com.bmw.psdz.vehicle.connection.wrapper.Configured DProject.getSystemFunctionHostEcu(ConfiguredDProje ct.java:483) ... 51 more |
12-05-2014, 04:34 AM | #62 | |
Rep 40,650
Verify the following when connecting: On E-Sys Toolbar Press the "Connect" Button and in the "Open Connection" window under "Target", select desired Target Vehicle based on car's Chassis. (e.g. "TargetSelector:Project=F020-14-11-502, VehicleInfo=F020") *NOTE: Do NOT select the Target with the "_DIRECT" suffix (e.g. TargetSelector:Project=F020-14-11-502, VehicleInfo=F020_DIRECT). In the "Open Connection" window under "Interface" select "Connection via VIN". In the "Open Connection" window under "vehicle-specific parameter (optional)" select "Series, I-Step Shipment", and leave the two Dropdown boxes blank. *NOTE: Do not select "Read parameters from VCM".
12-05-2014, 04:35 AM | #63 |
Rep 40,650
PM sent.
12-05-2014, 10:43 AM | #64 | |
MVP
Rep 32
Save button Grayed out
100% correct Shawn i was choosing target with direct suffix. Now I have a new issue.
When I activate the fa browse to what I want to change edit fl however the save button is grayed out on top not allowing me to save. Any advice? As always thanks in advance Quote:
12-05-2014, 01:31 PM | #65 |
Rep 40,650
Just so I am clear, you are in the Coding Module, FA is Activated, and you Read ECU and then Edit FDL, change a setting, and then the Save icon is still grayed out?
12-06-2014, 01:11 PM | #66 |
Rep 7
Hi Shawn,
have a 2012 f30 and my Bimmber Contractor just updated software two weeks ago Could you provide me with latest esys, code and data please. Thanks in advance! |
