04-21-2024, 12:04 PM | #1717 |
Rep 1
Hello Shawn,
maybe you also can help me out with my cic Navigation on my E92 325d 2009 I would like to update from Road Map Europe West Premium 2016-1 to Road Map Europe West Premium 2024-2 VIN: WBAWD31060P356102 Thank you! |
04-21-2024, 12:21 PM | #1718 |
Rep 40,878
PM sent.
04-22-2024, 02:58 PM | #1719 |
Rep 6
Hello Shawn!
May I have your help with my CIC-High navigation on F30 328i xDrive 2013. I'd like to update its map to North America Premium 2024. VIN: WBA3B3C50DJ698817 Thank you very much for your help. |
04-22-2024, 03:04 PM | #1720 |
Rep 40,878
PM sent.
04-22-2024, 03:16 PM | #1721 |
Rep 1
Hi, Shawn
Could you please generate a FSC code please. Model : BMW E70 2010 VIN: WBSGY01020LK10564 New Map: PREMIUM Road Map Europe West NEXT 2024-2 Thank you in advance. |
04-22-2024, 03:19 PM | #1722 |
Rep 40,878
PM sent.
04-22-2024, 05:06 PM | #1723 |
Rep 1
FSC Code please
Model: BMW E70 2013 VIN: 5UXZV4C55D0B01436 Date: Thursday, May 3rd 2012 Road Map North America Premium (USB) 2021 Thanks guys, I've tried a few ways to extract the FSC, but none of the codes will let me update the maps |
04-22-2024, 05:09 PM | #1724 |
Rep 40,878
PM sent.
04-22-2024, 05:17 PM | #1726 |
Rep 40,878
PM sent.
04-24-2024, 06:38 AM | #1728 |
Rep 40,878
PM sent.
04-24-2024, 12:10 PM | #1730 |
Rep 40,878
PM sent.
04-25-2024, 10:01 PM | #1731 |
Rep 1,590
I am undoing my NBT retrofit FSC-emulator box and replacing it with an after-market Retrofit FSC code set via USB plug in update.
2012 (May) F30 car with CIC no/nav factory setup Currently using donor NBT HU w/NAV prof. from 2015 car. So when installed the Emulator box I had to VO code the NBT ECU w/Zeitkriterium 03/2015 and also with Donor VIN. Also VO coded the KOMBI ECU and EPS ECU, and iDrive Controller ECU with 07/13 and 07/14 Zeitkriteruim. Question: Since the after-marker FSC codes will "validate" my factory VIN and will write it into my retrofit donor NBT HU...will I still need to VO code the NBT HU ECU, and KOMBI ECU, and EPS ECU , and IDrive Controller ECU with a Zeitkriterium?
04-25-2024, 11:08 PM | #1732 | |
Rep 40,878
04-25-2024, 11:13 PM | #1733 |
Rep 1,590
Thank you. So to confirm, after the NBT Retrofit FSC set is imported, I will still need to VO code with the proper later Zeitkriterium those ECUs that were not yet manufactured in 2012 May (my car's factory manufacture date).
04-25-2024, 11:18 PM | #1734 |
Rep 40,878
Just NBT.
fe7565552.50 |
04-25-2024, 11:20 PM | #1735 |
Rep 1,590
Got it. Thank you! So only need to VO code the NBT-HU ECU with Zeitkriterium. Not the KOMBI, etc
04-26-2024, 05:12 AM | #1736 |
Rep 4
Hello again, I was able to update my CIC browser without problems generating the FSC code with the generator that is posted in this post.
Now I need to do it in an NBT browser from 2014, My question is, is it the same process as in the CIC? With the generator can I get the FSC code? thank you so much |
04-26-2024, 09:35 AM | #1737 | |
Rep 40,878
04-26-2024, 09:11 PM | #1738 |
Rep 1
Hey Shawn could you please help me with a lifetime FSC code? I'm updating to the North America 2023-2024 maps.
Road Map NORTH AMERICA EVO 2017-1 Vin: WMWXP7C34H3C62025 Any more info let me know. |
