03-06-2018, 09:58 PM | #1 |
Enthusiast
210
Rep 367
Jb4 + Bm3/mhd
So I have been curious and I have seen that some people run JB4 and BM3/MHD on top of that - what are the benefits of doing this instead of running JB4 alone or BM3/MHD alone? What is "better" for the money? Pros and cons?
03-07-2018, 01:18 PM | #2 |
Rep 115,980
From the FAQ:
FAQ: What benefits does a back end flash map add to the JB4? Adding in the back end flash map allows JB4 adjustment over a wider range of engine parameters than are available on the factory flash. Including direct adjustment of timing and fueling tables, VANOS adjustment, fuel scalar adjustment for heavier E85 mixtures than possible JB4 only, speed limiter delete, optional exhaust burble, higher calculated torque reported to the automatic transmission, and a host of other parameters than are only possible via flashing the DME. What are the benefits of running a JB4 with a flash rather than flash only for tuning? While it's possible to tune an F series without a JB4 doing so comes with many disadvantages. 1) With JB4s unique features and logic paths, combined with the flexibility of adjusting DME tables directly via the back end flash map, you get better quality, safety, and more powerful tuning. The JB4 includes more robust safety systems than are possible via flash only. Starting with fundamental safety systems like reverting to a safety map if boost exceeds your safety setting, if the air/fuel ratio in either bank turns dangerously lean, or if fuel pressure drops below a safe level. While you might think the DME alone can handle these basic safety systems surprisingly it's not the case. The DME will happily let you run along at full power and a 18:1 AFR, with boost pegged, and the only fuel pressure safety provided is when fuel pressure drops down so low fuel injection itself has to be suspended. 2) More mapping options including absolute boost target maps. The JB4 boost control system is programmed to offer both absolute and additive maps. Absolute meaning you'll always target a specific boost level. Unlike the DME which naturally implements a LOAD control system where boost levels go down when it's cold and go up when its warm. The opposite of what you generally want for turbocharged performance. In addition the JB4 is quick and easily adaptable to a wide range of setups eliminating the need for expensive custom boost tuning and the risks that come with repeated logs on systems that are not yet setup. It's not uncommon for engine damage to occur while a new setup is initially being dialed in. The JB4 automatically tunes wastegate dutycycle, fuel trims, and other important tuning criteria full time in the background greatly simplifying the tuning process. In addition the JB4 auto-tuning map can self tune for various ethanol mixtures without the need of an expensive and difficult to install flex fuel sensor. Pedal to boost mapping, spool aggression, boost by gear, and other critical factors can be easily adjusted to suit the needs for the particular track or racing situation. 3) On the fly changes. Whether it's changing the boost/power level, boost by gear setting (including being able to disable it on the fly for burn outs or if traction turns out to be better than expected), pedal input, exhaust flap position, or what gauges are shown in dash, the JB4 allows a wide range of user adjustment real time from the drivers seat without having to use a 3rd party device or risk programming the DME between runs. You're able to make the changes while out on the track where you need to make them. 4) The JB4 allows for much better real time feedback to the driver. User adjustable in dash gauges allow you to keep a constant eye on boost, timing, knock, meth flow, and/or AFR, all selectable and changeable on the fly from the drivers seat. A user adjustable shift light can be triggered making rowing through the gears easier. JB4 Mobile allows wireless bluetooth logging via your Android or Apple phone without a cable locked in your OBDII port. In addition you can select map0 on the fly to allow OBDII port logging and diagnostics when needed for vehicle service. The JB4 default logging set includes all relevant data required for tuning including boost, timing cylinders 1-6, AFR and fuel trims in both banks, high and low fuel pressure, load, calculated torque, trans temperature, and many other parameters. The JB4 provides a simple to use but incredibly robust data logging system eliminating the need to select what parameters to record before each run and providing instant on the fly charting without the need of 3rd party internet programs. We routinely add parameters to the JB4 logging set based on customer feedback and evolving tuning requirements. 5) Integrated JB4 features such as anti-lag, port injection control, flex fuel sensor, and progressive water/meth (WMI) control eliminate the need for independent add on boxes that are more difficult to install and technically unable to communicate with each other. Integration allows these extra features to share information for a smooth and cohesive tuning solution. When the DME requests a torque drop due to traction or stability control the JB4, WMI, and PI systems all respond accordingly. WMI integration is able to hold boost levels low UNTIL fluid is flowing adequately to prevent spool up and transitional knock, adjust your boost target if the fluid being injected turns out not to be as potent as was expected or required to prevent knock, and in the event of a fail-safe depending on the severity of the situation either lower your boost target partially OR instantly dump boost out the diverter/close the throttle/cut timing. These are just some of the many examples of why having add on boxes an features all integrated through a single system is advantageous. 6) Free maps for life. The JB4 is widely used and widely supported including free unlocked back end flash maps and custom mapping support from BMS via the n54tech support forum. BMS sponsors and attends several 1/4 mile and 1/2 mile races per year continuously improving the JB4 base maps and features based on real world experience and feedback. These updates are provided free of charge to JB4 customers via n54tech firmware posts. 7) The JB4 hardware is robust, reliable, highly developed, and upgradable, with many thousands of systems in use since 2008 when it was first released. The key to the JB4’s success is that it DOES NOT replace the factory engine computer or DME. The JB4 simply adds on to functionality already provided by the DME. As a result the DME remains in full control of your engine at all times with the JB4 dynamically making small but impactful adjustments to add in extra safety systems and features and dramatically improve performance. And unlike disposable flash maps the JB4 is a physical system you can remove and resell down the road. Once I flash the DME can the dealership tell? What if I flash it back to stock? Modifying your vehicle is not without risks and we believe flashing the DME is traceable even if flashed to stock. If you are really concerned about your warranty, it's best not to flash your vehicle. That said when used in conjunction with the JB4's expanded safety systems and mapping use/guidelines, expect a relatively high level of reliability at the elevated power levels. What flash time options are available? Certain settings can be toggled on/off or adjusted during the flashing process itself. Including the user adjustable exhaust burble settings, speed limiter delete, cold start delete, CEL delete, etc. MHD will be adding these as their development progresses. |
03-07-2018, 02:02 PM | #3 |
Enthusiast
210
Rep 367
Thanks Mike!
03-07-2018, 06:47 PM | #4 |
Rep 190,777
You basically would be getting the best of both worlds.
Flash smooth power delivery and access to ECU tables + All the Jb4 features that are not offered with a flash tune
03-07-2018, 07:31 PM | #5 |
Rep 1,348
The jB4 I can use with the AA flash as a logging tool right Mike?
2k15 335i Msport xdrive 6spd
03-07-2018, 07:32 PM | #6 |
Rep 190,777
You sure can ... You can take advantage of the Jb4's datalogging feautures and boost by gear for a better traction control
03-07-2018, 07:36 PM | #7 | |
Rep 1,348
I can leave the JB4 to log but I do have the option to modify the fuel tables of the AA flash with the JB4/ not that I would do that but just curious if it gives me that capability?
03-07-2018, 07:38 PM | #8 | |
Rep 190,777
You can increase or decrease boost using the Jb4 ... i would use AA flash to change any ignition or AFR value Pm coming your way
03-07-2018, 07:41 PM | #9 | |
Rep 1,348
Jb4 on map 4 no tuning is the ticket then!
03-08-2018, 10:52 AM | #10 | |
Rep 115,980
JB4 is a great tool on its own or used with a back end flash specifically for it or like above.. Mike |
ceedawg467.50 |
03-20-2018, 11:24 AM | #11 |
Rep 86
Quick question and sorry if this is redundant.
If I run BM3 with JB4 map 1, would I essentially up the boost levels further (3-4 PSI) from what the BM3 flash has already programmed? Trying to do my research because I am not too familiar with flash tunes. Really trying to figure this out because I am already running a JB4 and the info from all the BM3 performance numbers have me interested. Thanks |
03-20-2018, 02:04 PM | #12 | |
IG @bmwF9xG80
3813
Rep 7,593
60-130mph 6.5s X4M #HCP
03-20-2018, 07:53 PM | #13 | |
Rep 2,357
I was just about to pull the trigger on MHD hahaha!
(A Dane in China) |
03-20-2018, 10:53 PM | #14 |
Rep 1,693
03-20-2018, 11:43 PM | #15 |
IG @bmwF9xG80
3813
Rep 7,593
*** WARNING PROCEED SLOWLY ***
No they're not meant to be editable right now, but I can edit BMS BEF
03-21-2018, 12:23 AM | #16 |
Rep 4
You guys are just making things harder to figure out lol. I was all set on mhd when they go live for the 14 f N55 cars but now I’m back to thinking researching and thinking more.
03-21-2018, 01:53 AM | #17 |
Rep 2,357
Pfffffffffffff...no guts no glory
(A Dane in China) |
JaredG_F301106.00 FSociety3812.50 |
03-21-2018, 07:08 AM | #18 |
Rep 1,499
That is F'ing stellar. How would I procure such maps? I don't have JB4 currently but have thought about using it as a meth controller and for logging when I'm ready to get into the 500hp club.
03-21-2018, 08:02 AM | #19 | ||
IG @bmwF9xG80
3813
Rep 7,593
It was just a random test I did yesterday and loaded all BIN files simply by adding the file to my account and was able to compare N55 EWG BEF he has currently in testing. So definitely not something I recommend anyone to try as they're still in BETA (only been 3 months) "just seeing their progress"
JaredG_F301106.00 |
03-21-2018, 08:10 AM | #20 | |
Rep 1,499
Got it!! No rush as I'm not going to be adding power mods until after LSD and coilovers. By the time I am ready to go PI or meth this will probably be all worked out. Good to see some insight into the future though. Just makes me more happy with my decision to go BM3. Thanks for sharing!
FSociety3812.50 deezeedee33532.00 |
03-21-2018, 09:24 AM | #21 |
Rep 2,357
Damn this is going directly on my trophy wall
(A Dane in China) |
FSociety3812.50 terryd5150507.00 |
03-21-2018, 09:26 AM | #22 | |
Rep 2,357
(A Dane in China) |
