06-22-2018, 09:18 PM | #1 |
researcher
40
Rep 129
Interior Wrap Help
Hi guys, I'm working through wrapping the interior trim with carbon fiber vinyl because I really hated the burl wood pattern. So far, I've had no issues with the dash pieces & iDrive trim piece. However, when it comes to the door handle trim pieces, I'm having a hard time getting it off due to fear or breaking the clips.
Does anyone have any advice on the best way to get the trim off the door handles? Btw, I know everyone likes photos. These are the completed pieces (forgot to take before photos).
06-22-2018, 09:29 PM | #2 |
Rep 776
You just have to place a flathead screwdriver in the lower notch on each handle, gently pull it so the lowest clips come out, and then gently dislodge it bottom to top with your fingers. You'll want to only pull it out about 1/4-1/2 inch until you get the top clips out, then pull the entire thing off from the top and there is a plastic hanger at the bottom.
M240i | Mineral White | Coral Red
rayxi40.00 |
06-22-2018, 09:38 PM | #3 |
Rep 16,082
Go get some plastic trim removal wedges, they sell them at Autozone etc. You want to use at least three, gradually inserting them to push the trim piece off as equally as possible over its full length. When it comes off some of the metal clips that hold it in place will stick to it, some will stick to the door pull. Use needle nose pliers to remove those on the door pull, insert them onto the trim where they belong, paying attention to their orientation.
rayxi40.00 |
06-22-2018, 09:41 PM | #4 | |
researcher
40
Rep 129
06-22-2018, 09:43 PM | #5 | |
researcher
40
Rep 129
06-23-2018, 08:31 AM | #7 | |
Schmollbraten
12512
Rep 1,985
Citizen of ///M - Town, where too much is just right Some say, that my scrotum has its own small gravity field and when Im slowing down that brake lights come on at my buttox |
rayxi40.00 |
06-23-2018, 09:03 AM | #8 | ||
researcher
40
Rep 129
The multiple trim tools advice did the trick. I was able to get them off this morning.
Dang3r12512.00 |
06-23-2018, 01:08 PM | #9 |
A family of bimmers
2747
Rep 7,742
Not to be a Debbie downer but your patterns go the wrong way on the left vent and center console respective to the large center trim you did.
06-23-2018, 01:13 PM | #10 |
researcher
40
Rep 129
No worries. Thanks for pointing that out. That's what I get for not waiting until the weekend to do it right. I'll have to redo the large dash piece again some day since that's the easiest piece to remove.
06-28-2018, 05:55 PM | #11 |
Masterchief
362
Rep 1,011
pulling the handles out and putting them back in the right place with all clips secure is probably the biggest PITA,
expect raw fingers and frustration.. you will eventually get it.
AWE Non-Res Touring | TE37 SL PW | Ohlins RT |
06-28-2018, 10:23 PM | #12 |
researcher
40
Rep 129
haha yes, my fingers were definitely raw. i was mostly very nervous about breaking the clips but they were pretty strong.
06-29-2018, 06:26 PM | #13 |
Yoda of mods
1673
Rep 3,004
Drives: X5 RWD
Looks good.
F87 AW (retired) F30 SBM 316rwhp/440rwtq (retired) Follow me on Twitter: https://twitter.com/EdwyerCLT YT: https://www.youtube.com/@DWYERGARAGE/videos |
rayxi40.00 |
