      01-14-2013, 06:03 AM   #2003
shawnsheridan
shawnsheridan's Avatar
Originally Posted by Spikey View Post
Damn, I've changed my KOMBI / BMW_LOGO = mpm but it still stays as original BMW logo
Besides newer software, it seems it only works with the Extended Panel Display. If you have the basic KOMBI, it won't work.
      01-14-2013, 06:44 AM   #2004
kon
Singapore
Drives: F30 310i > G20 310i
Originally Posted by ykau View Post
hey, you and me come from the same , dun have to tease me lah, you know is a typo
You could have went to retrofit 6NR, alternatively, perhaps (obviously not) it does play USB video, just that I never tried it.
In any case, video is not high in my "wish" list, used to have a headunit on my JDM that could play any format I throw at it, alas I never play any video at all... law abiding
      01-14-2013, 08:10 AM   #2005
ykau
Drives: F30 320I
hi shawnsheridan, I think i have corrupted my FEM_body while doing the angel_light setting.
while reading code, error as followed:
FEM_BODY[40] [yyyyyyy]
readCPS o.k.
cafd_fffffffff-255_255_255 Fehler:
file for "cafd_fffffffff-255_255_255" not found! [c012]
any solution. thanks 9-:
      01-14-2013, 08:12 AM   #2006
ykau
Drives: F30 320I
not inside mine either. Since your 335I has every codes, curiously what is inside your wish list?
      01-14-2013, 08:17 AM   #2007
kon
Singapore
readCPS o.k.
You need cafd file, you get the error while reading the code or while writing? Seems to be reading.
No corruption yet
When are we going to have sg f series coding session?
      01-14-2013, 08:18 AM   #2008
shawnsheridan
readCPS o.k.
Well, the first step is to prevent it from happening by making sure your car has power while you are coding it.
Try this:
Connect => Read FA => Activate FA => Read VCM => Left-Click on FEM_BODY => Click on "Detect CAF for SWE" => Select the CAFD matching your I-Level => Select OK => Right-Click on FEM_BODY (the ECU itself not the underlying CAFD) => Select CODE.
To determine your I-Level, go to VCM Module => VCM Master Tab => click Read under I-Steps. The I-Step (current) is the one you want to match when you select the CAFD from the "Detect CAF for SWE" options (e.g. F001-08-09-550).
      01-14-2013, 08:19 AM   #2009
kon
Singapore
6wb, hu_nbt, Asian language... Preferably a new m car to go along
      01-14-2013, 08:22 AM   #2010
ykau
Drives: F30 320I
HI Kon & Shawn , thanks i will try out now.
      01-14-2013, 08:29 AM   #2011
shawnsheridan
Well, that really depends on the retrofit.
If you do an OEM Retrofit, with 6NF base plate and run the 6NR FBAS Video Lines from the Base Plate to the Head Unit, you will not have Video on the USB Port.
If instead you replace the OEM 6FL Aux-In USB Port with the AV-In USB Port from the Mini Cooper, and run FBAS Lines from the USB Port to the Head Unit, and rewire the Combox, then you can have Video on the USB Port.
      01-14-2013, 08:34 AM   #2012
kon
Singapore
Thanks but skipping this as I hardly stay in the car long enough for video. Like you, if I do 6nr is purely for apps, like radio etc. the amount it cost to retrofit video, iPad/mini with bracket waaaay easier and cheaper
      01-14-2013, 08:46 AM   #2013
shawnsheridan
Exactly. I have all of 6NR except Video, and that was fairly cheep, and no hardware modification was needed.
      01-14-2013, 09:05 AM   #2014
ykau
Drives: F30 320I
Try this:
Hi Shawn, problem solved and new thing learnt. thanks man!!!
      01-14-2013, 09:09 AM   #2015
shawnsheridan
Alright brother. FYI, You can code your whole car except DME module with the car running, and you never have to worry about maintaining proper voltage to it.
      01-14-2013, 09:15 AM   #2016
kon
Singapore
Is there a dictionary of some sort that explains what each of the ecu abbreviations mean? I'm starting to get familiar with a few, combox, Hu, kombi, ihka, fembody. But still generally clueless about the rest
      01-14-2013, 11:43 AM   #2017
dos1973
[QUOTE=howiegu]
Originally Posted by avgor123
Originally Posted by howiegu View Post
All the experts:
Will enable this setting enabling a brighter "angel eye" ring when headlight is on?
Maybe you will try this:
Fem_body>3062
MAPPING_STANDL_V_L_PWM_LEVEL_1
MAPPING_STANDL_V_R_PWM_LEVEL_1
set to 100% instead of 8%
Did you mean to change the "werte" to 64 from 08 (in hex term it's 100)?
Have you done that to increase the brightness if the rings?
Thanks.
Did this work?
      01-14-2013, 06:33 PM   #2018
ramonE90-NL
Netherlands
35
Drives: bmw F30 320iA
Is it possible to code dvd movie play on the business navi? Or do you really need the pro nav.
Im hoping to recieve my cable this week, but if i would have some information about this i know if i have look for this or not
      01-14-2013, 09:10 PM   #2019
clarence
Drives: F30 328i M-Sport
The business nav unit doesn't have a dvd drive.
      01-14-2013, 09:15 PM   #2020
shawnsheridan
Not that I have ever seen, but I have never looked for one either.
DME is Digital Motor Electronics, which is why the motor can't be running when DME is coded.
      01-15-2013, 01:20 AM   #2021
ramonE90-NL
Netherlands
35
Ah oke, thanks
      01-15-2013, 02:01 AM   #2022
estragos
TUGA
estragos's Avatar
84
Drives: F30 320d M Sport
It is part of BMW Standard Tools (EDIBIAS, INPA, Tool32, and NCS Expert).
ok thanks, I found it and it is allready installed,but:
when I launch INPA or Tool32, I have an warning message from registry:
"registry value failed in subkey:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Servic es\Serial
May be there are problems!"
just for info, I run the software on a Windows Vista Laptop. I has to launch the installation of the software by select the Windows Xp compatibility.
perhaps it is because I select STD:OBD and Com1 during installation?! wich port I must select, to use INPA and Tool32 with a ENET cable on the LAN port?
I get my new F30 only on March 15, so I have to wait for test!
Thanks again for your help!!
      01-15-2013, 03:49 AM   #2023
avgor123
avgor123's Avatar
Russian Federation
Drives: F30 320D Sport
I think CHAMP has a DVD drive, but it can read only navigation DVD, not video or audio DVD. For audio CHAMP use audio and MP3/WMA CDs.
      01-15-2013, 07:33 AM   #2024
fsfikke
Drives: 330e
[QUOTE=dos1973;13306310]
Did this work?
Would be interesting just to change one of them to spot if that results into a (big) difference between left and right.
