05-29-2016, 05:55 PM | #23 |
Rep 305
I just finished doing the install on the ER Charge pipe, so I figured I would explain a few things about the install.
First step 7 wasn't hard at all, that is the factory charge pipe removal from the intercooler. I say this, because the instructions said it was tricky. Second I did not remove that coolant line off the frame. I was unable to remove the clips from the frame so I just skipped that step. Also I pulled the charge pipe through the top and not the bottom as the instructions say to do. It did require that I removed the MAP sensor from the charge pipe prior to removal of the charge pipe itself. When trying to get it through the top I did need to go underneath the car to push the pipe out of the things blocking it. However, it is very easy to pull through the top if you take your time and worm it through. The hardest part for me was the lower charge pipe installation. It was a pain to fit into the silicon hose, it was a pain to get it into the intercooler. I had to take the upper pipe off the throttle body in order to get it to fit on the intercooler correctly. Final thoughts, I would recommend a friend to help with this. It can really help to line things up with the intercooler. Also the directions have all the correct tools listed, except a 4mm allen wrench for the new screws for the Map Sensor. |
05-29-2016, 07:02 PM | #24 | |
Rep 367
I did not remove the intercooler or that coolant line to install the charge pipe...don't think think it was necessary for my car (RWD). I had to put the upper pipe in but didn't clip it in place, then I had to put the lower pipe in place and clip it, then clip in the upper pipe to the throttle body. This allowed me to maneuver both pipes into the silicon hose easily with out dropping the IC at all. If you remove the intake, your hand can also easily reach down to remove the lower IC clips...this is what i ended up doing for that black clip. It should also be noted that the OEM black clip you remove on the lower part that connects to the IC is not used for the ER pipe. A little WD-40 or glass cleaner also works great for lubricating the silicon hose so you can slide it over. The time estimate is more or less correct. I installed my DP and CP in around 4 hours. |
06-02-2016, 09:14 AM | #25 |
Rep 34
Worked on replacing my charge pipe last night, since the OEM charge pipe broke and blew off the throttle body after moving to map 2 two days prior. The OEM charge pipe was missing the clamp and O-ring on the throttle body side.
Anyone know the part number I need for the throttle body side of the charge pipe? Thanks!
2012 F30 335i |Alpine White/Dakota Red|m405|MPE|MP Brakes|er charge pipe|vrsf catless downpipe|jb4
06-02-2016, 10:39 AM | #26 | |
Rep 115,980
Mike |
07-26-2016, 02:25 PM | #27 |
Enthuisiast
93
Rep 423
35k miles on my car and the intake pipe blew off today. I'm going to talk to the dealer about replacing them with metal units to feel them out. I really don't want to worry about having to fix this.
AW F80 M3 / RAYS / TOYO TIRES / BMS
IG: @hybrid_david |
07-26-2016, 02:37 PM | #28 | |
Rep 115,980
Mike |
07-26-2016, 03:23 PM | #29 |
Enthuisiast
93
Rep 423
Yea, it seems like a no brainer to me but they may still be sissys about it.
IG: @hybrid_david |
08-07-2016, 02:25 PM | #30 | |
Rep 373
Having done this last weekend, I'd definitely recommend a friend to help with this installation. Start to finish, took less than 2hrs. I'd also agree that the lower charge pipe installation to the intercooler was the toughest part. I had to remove the IC so I could fit the lower clip easily. I also skipped step 8. |
08-08-2016, 10:37 AM | #31 |
Enthuisiast
93
Rep 423
Dealer replaced my cracked charge pipe without any fuss. The service adviser specifically mentioned that he had not seen this issue before. Yea... right. hahahaha
IG: @hybrid_david |
08-08-2016, 01:15 PM | #33 |
Enthuisiast
93
Rep 423
IG: @hybrid_david |
09-01-2016, 12:44 PM | #34 |
Rep 172
09-01-2016, 02:09 PM | #35 |
Rep 115,980
10-01-2016, 02:18 PM | #37 |
Rep 6
Thanks for posting this thread and the DIY, I was able to get the chargepipe installed in a matter of a little over an hour. I didn't remove the intercooler and was able to easily pull it out the top, and installing the bottom section from up above before installing the bellmouth.
10-02-2016, 07:38 AM | #38 |
Rep 22
I did this install yesterday, and it was a pain!! Most of that seems to be due to having x-drive, since this install seems a lot easier on a RWD vehicle. I have some tips and questions to ask from others who have done the install. Questions first. How do you get the retainer clips reinstalled on the intercooler connection? I put the clips on, but I made a few attempts to reinstall the retainer clips and didn't even get close. ER's directions just say reverse steps on install, so I am assuming for max reliability that includes the retainer clips. Also, for the x-drive, who feels confident with their lower t-clamp? I finally found an angle from the bottom that I was able to tighten the t-clamp, but it is right on the edge of the flex connecter and at a slight angle. Optest was sat for road test, but I would definitely like to make it a little more reliable.
For tips and tricks. If you have the money and desire, do both TIC and Intercooler to Manifold chargepipes and Intercooler all at the same time. You are going to have the intercooler out so now is the time to get all these parts installed. I am kicking myself, because I will have to drop my new intercooler back out in order to install the TIC chargepipe and DV+ at a later time. For the black retainer clips, I found that it was easier to push it a little forward then take a small screw driver and pry the visible side up. This removed the clip without snapping any of the small plastic pieces on it. If you have an xdrive, try pulling the stock chargepipe out from the top, not the bottom. I was able to pull it out from the bottom, but it seems a lot easier going the other way...realized that when it was too late. In my opinion, the hardest part of the whole process is installing the new chargepipe, securing it to the intercooler and tightening the lower t-clamp. Once again, this is made harder for x-drive models. The directions tell you to start by securing the flex connecter to the upper chargepipe and to install to the throttle body. In the next step, you will then need to connect the lower section AND install the lower t-clamp. Don't be a moron like me and install the lower t-clamp before you secure the upper section. I would put it into position and tighten it snug with just enough give to push the lower section in. This will save a lot of headache. I found the best position to not interfere with surrounding wires, steering shaft, etc. was facing down and slightly towards the driver front wheel. This allowed room to get an extension and pivot up to tighten it. When installing the lower chargepipe to the intercooler, be sure to put the clip on right before you get to the groove in your intercooler. I was dumb and put it on right away and could not get the pipe down to the groove. After much frustration and cursing and being convinced that ER didn't make the pipe long enough, I realize that the clip had slipped back into the notch where it ultimately rests making it drag along the intercooler connection. I pulled the chargepipe back, got the clip out, and I was able to easily slide it down into place. If I were to do this install again with these lessons learned, I could cut a good 2 hours off the install time. I hope this helps, and feel free to ask any questions.
2014 BMW 435XI w/ MT - Injen Intake - BMS JB4 - Wagner Tuning HFC DP - Wagner Performance FMIC - ER Chargepipes
11-27-2016, 11:19 PM | #39 |
Rep 78
ER CP Installed. 3 hours.
Problem. Note: Could be that my mechanic cracked the part. But. I left the shop and shortly after the engine ran rough and I have an engine light on. Also. My turbo appears to be out as the car feels like my old 07' 328i. I went straight back and he showed me that a hose has popped off and is cracked. He's not saying he didn't do it but the hose connected to the intake to the CP is cracked in half. I'm headed to see if I can find the part tomorrow. Anyone know what this part is officially called ? Part #? Thanks!
///M3 2015 F80 6MT Moonstone Metallic
- 8 UR V8 - www.AppalachianDrive.Club Last edited by Sandmansc; 11-27-2016 at 11:21 PM.. Reason: Adding info |
11-29-2016, 11:24 AM | #40 |
Rep 78
The part is called "sucking jet pump with lines"
It's 93.00 The closest one is in Florida at a dealer so I'm guessing this isn't common ? The upper CP connection to this hose is angled so that there is a lot of tension on this hose and I'm guessing that's why it snapped. |
05-30-2017, 12:22 PM | #42 |
BMW n00b
26
Rep 116
Drives: 2012 F30 335i Melbourne Red
when installing boostpipe and chargepipe is cutting away plastic from other pieces necessary? Sorry for lifting an pretty old thread.
05-30-2017, 12:27 PM | #43 |
Rep 5,776
05-30-2017, 12:50 PM | #44 |
BMW n00b
26
Rep 116
Thanks. Heard otherwise in another forum. Though they were refering to a 2 series.
