BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Mechanical Maintenance and TSBs: Break-in / Oil & Fluids / Servicing / TSBs and Service Bulletin > Fan/Whirring Noise Front of Dash: Acceleration
Studio RSR
      03-22-2018, 10:12 AM   #1
bimmer813
Drives: 2023 M4, 2024 X5 M60
Hey guys, I just got the girlfriend a 2016 328i and noticed a noise coming from the front of the dash.
Under throttle (and only under throttle), there is a fan/whirring noise coming from in front of the instrument cluster. It seems like it may be coming from the engine compartment, but it almost seems artificial.
Also, the auto start/stop sound seems quite loud (and comes from the same location).
Any thoughts/experiences with this? I appreciate your help!
      03-22-2018, 10:16 AM   #2
BunkerJ
BunkerJ's Avatar
1032
Drives: 2013 328i
I would say this sounds like the timing chain issue, but I believe that was fixed on these models.
2013 F30 328i: MHI Big Turbo, GFB DV+, Mishimoto CAI, ER TIC/CP/Catless DP, AWE Touring Quad Exhaust w/ Resonated Midpipe, NGK LI Plugs, BM3 with PTF Stage 2 91 AGG Tune, Fuel-it Stage 2 LPFP, Solowerks S1 Coilovers, and DEPO/M-Sport Retrofit
      03-22-2018, 10:25 AM   #3
bimmer813
Thank you for the quick reply! That was my thought as well, from what I have read the new timing chain was installed on cars post January 2015, and her car was produced October 2015.
I can always take it to the dealer as it's under warranty but we both work pretty crazy schedules.
      03-22-2018, 10:57 AM   #4
BunkerJ
BunkerJ's Avatar
1032
Drives: 2013 328i
Yeah, I would see if you could drop it off and get a loaner while they check it out. If it were just whirring at idle and whatnot, probably a noisy fan, but under acceleration causes some concern.
      04-08-2018, 11:34 AM   #5
amulos
Drives: F31 330d M Sport Touring
i had exact same noise- it was the air conditioning system. if you are using climate turn the ac button so its not on and see if it persists, if it doesn't continue then a re-gas of the AC might be required- that solved it on mine.
sound like the fan in the cabin is working overtime when you rev/accelerate? almost in sync with engine revs?
      04-08-2018, 11:39 AM   #6
badbread
not good, but bad
Drives: 2013 335i
I have this noise, definitely related to the HVAC system, I've found it depends on the position of the hot/cold air mix dial on the top center of the dash. I'm going to bring it up next service visit. Thanks!
      04-23-2018, 09:36 PM   #7
madmortar
Drives: 2013 BMW 328i M-Sport
I have this noise too!
Actually just got back from a drive to investigate more. Seems to come on during WOT mostly 4K - 6K. I can hear it the best with windows up. I tried and it does it both with a/c on and off. Only does it when I'm WOT. Doesn't matter which gear.
Any tests you recommend I do ? Or just bring it into dealership?
      04-24-2018, 12:24 PM   #8
madmortar
FYI, made an appointment to ride around with tech to have them listen for this noise.
I will be out of town for 2 weeks so unfortunately, wont be able to have them look at it until May 16th.
      11-14-2018, 01:10 PM   #9
amulos
Do you have an update on this anyone?
While a regas solved it on mine 10 months ago, the noise has returned. The condenser was found to have a hole in it so it was replaced. About a month after the noise has returned ever so slightly ( turning off the ac stops it ) its in with bmw at the moment, they have drained the system checked it and regassed again, they say they can’t hear it !
cross9032.50
      12-14-2018, 03:09 PM   #10
amulos
Further update: the technician eventually heard the noise and diagnosed an air leak on the compressor.
The compressor has now been replaced and all appears well, so far!
cross9032.50
