01-17-2018, 11:26 AM | #23 |
Rep 274
What OS did you use? And did the script run OK (no errors)? Did you run it elevated? Have you tried the latest version? Are there multiple user accounts on your system?
01-17-2018, 11:36 AM | #24 |
Rep 60
I am using windows 10 x64. This is what I get when i run script:
I run it as administrator. I have downloaded your latest verison. Only one user in OS. |
01-17-2018, 11:40 AM | #25 |
Rep 60
I got it working! It looks like problem was finding the right path to the folder due to virtual windows.
Then I copied rearm folder to "Program Files(x86)\TokenMaster\E-Sys Launcher Premium" and it is working now. OK, so I am playing with it now and for me it seems to be working only when I enter date: 01.04.2017. If I put like 17.01.2017 it says date manipulation. On other thing: Manual entered date automaticaly changes to real date after 2 minutes in winodws 10?!? Last edited by BimmerSI; 01-17-2018 at 11:50 AM.. Reason: Added date findings. |
01-17-2018, 02:36 PM | #28 |
Rep 3
I can't do nothing :/
Program is still showing "date manipulated"... What can I do with that ? Maybe my version is not ok - I have 2.7.1.135 instaled. Esys version - 3.28.1 Windows 10 Pro x64 Last edited by maciek49912; 01-17-2018 at 03:40 PM.. |
01-17-2018, 04:01 PM | #29 | |
Rep 274
Looks like you didn't read the Readme.txt in the package very well.... It is stated that the package should be installed on your desktop or local system. Hence the UNC path error in your screenshot. About predating to 17.01.2017, please reread note #2 in your screenshot... Good that it's working now for you. |
BimmerSI29.50 |
01-17-2018, 04:09 PM | #30 |
Rep 274
Updated version
Version 1.3 is out! I needed to update the script again to fix a bug in 32/64-bit support. Compatibility with Launcher 2.7.1, Windows 10 and 32/64-bit should have improved. Please download again to avoid future issues.
Also, as I have no 32-bit OS to test in, I have no way to be sure whether the script works the same. Would be nice to get some feedback on that. Cheers, Tony ----------- Tony Twoclicks Last edited by Tony Twoclicks; 01-17-2018 at 04:09 PM.. Reason: typo |
01-17-2018, 04:11 PM | #31 | |
Rep 274
There was a bug in the last version. Please retry with the latest version 1.3 |
01-17-2018, 04:14 PM | #32 |
Rep 616
Launcher 2.6.2 and esys 3.24.3, script (1.2) runs fine but still get date manipulated warning, esys worked fine beforehand, well before the time bomb anyway, any ideas?
Uninstalled esys and launcher with the date set back and with the proper date but it made no difference. |
01-17-2018, 04:26 PM | #33 |
Rep 616
1.3 doesn't work either, script runs fine but end up getting this...
Pic off Google, mine doesn't have anything filled in, with 1.2 I was just getting the date manipulation warning and nothing else. |
01-17-2018, 04:27 PM | #34 | |
Rep 3
I don't know where is problem (still) I have esys in this direction C:\EC-APPS\ESG\E-Sys Esys launcher premium in this direction C:\Program Files (x86)\TokenMaster\E-Sys Launcher Premium\ Maybe this is the problem ? Last edited by maciek49912; 01-17-2018 at 04:37 PM.. |
01-17-2018, 04:42 PM | #35 | |
Rep 274
What happens when you fill in the form? Do you get the car model selection screen, or just the same form again (but then empty)? Once you've created a token, open Explorer and go to the folder you selected in the 'Path' field of the form. There should be a file "freetoken.est". Open this in Notepad. What start- and end-dates are mentioned there in the header? Does your adjusted system clock fit in between these dates? |
01-17-2018, 04:59 PM | #36 | |
Rep 274
Looking good to me... It could be there is another check that I haven't found yet. Also, as a general thought, revert the system clock BEFORE you run the script. When you do it after, it might negate the actions of my script by changing system folders back to the wrong date(s). For Launcher version 2.7.1 you could also try to set the date a bit higher (towards 2018) to see if that makes a difference. |
01-17-2018, 05:06 PM | #37 | |
Rep 3
I don't know where is problem all files and time are good :/ |
01-17-2018, 05:15 PM | #38 | |
Rep 616
The headers shows a NotValidBefore date of 2016-11-30 and a NotValidAfter date of 2017-12-31, I've set the system date to 01/12/2016. After selecting a model, launches esys and looks to be working but not tried it with FDL coding, finger corssed it looks to be working. |
01-17-2018, 05:26 PM | #39 | |
Rep 274
That initial screen that you get is for token generation. This is normal. Everytime you run my script you'll see this screen again because it resets the Launcher. Normally, it would show up only once upon first use. Cheers, Tony |
01-18-2018, 06:36 AM | #41 |
Rep 98
Thank you very much. It worked perfect here.
I made my donation to get the Master token on January 4th. I already emailed him the same day. I already sent 3x email and until today 14 days later I had no response. So your solution is very welcome.
01-18-2018, 07:26 AM | #42 |
Rep 40,635
PM me your email address that you send TM email from.
01-18-2018, 07:44 AM | #43 |
Rep 43
hi there
I've tried 2.5.3 launcher with your script on date november, 15 2017. No good - just looping launcher at token generating moment. then, I've deleted old FreeToken.est - same - no good where should i go? what's wrong? hmmm Last edited by spudvti; 01-18-2018 at 09:34 AM.. |
01-18-2018, 08:28 AM | #44 |
Rep 17
clock, date, esys, launcher, premium |
