07-05-2018, 03:25 PM | #23 |
Rep 2,382
Well, that's the point of the guide... Haha. It's there to guide the chain and provide the path, while the tensioner helps to remove slack. The issue isn't that it's supposed to last for 200k+ miles, but it going prematurely under 70k is pretty bad. If the car has been turned off for awhile (which it should be since you're going to touch the chain), the oil should be mostly gone from the tensioner and thus giving slack. The noise is pretty loud and best assessed without the belts as well. At least for me, the turbo noise would likely mask it while driving, so no load is also the best way to assess it. While some do just go without any warning, most will give that "dying cat" noise. The best thing you can do right now is to continue to check and ensure AS/S is turned off manually or coded out, as it rapidly accelerates this issue.
2013 F30 328i: MHI Big Turbo, GFB DV+, Mishimoto CAI, ER TIC/CP/Catless DP, AWE Touring Quad Exhaust w/ Resonated Midpipe, NGK LI Plugs, BM3 with PTF Stage 2 91 AGG Tune, Fuel-it Stage 2 LPFP, Solowerks S1 Coilovers, and DEPO/M-Sport Retrofit |
07-05-2018, 04:10 PM | #25 | |
Rep 3,680
Upon further review, like I said before I'm definitely not experiencing the dying cat noise. From here on out I'll do a thorough check for noise every 1k miles or so, hood open, out in front, having a friend or whatever rev for me. I've never used AS/S ever since I've owned the car (forgot to turn off here and there, rarely, but YKWIM). Hopefully previous owner didn't either.
07-05-2018, 04:22 PM | #26 | |
Rep 2,382
07-05-2018, 04:43 PM | #27 |
Rep 3,680
Same here, got mine at 46k. Likely was used before, just judging by typical 328i buyer demographics. Didn't code it out but turn it off everytime I step in the car. My mom's E84 X1's AS/S stayed off even after leaving the car, only had to turn it off on delivery day and never worried about it since. I wish
07-06-2018, 08:55 AM | #28 | |
Rep 2,382
Edit: Audio: Visual/Physical Inspection:
2013 F30 328i: MHI Big Turbo, GFB DV+, Mishimoto CAI, ER TIC/CP/Catless DP, AWE Touring Quad Exhaust w/ Resonated Midpipe, NGK LI Plugs, BM3 with PTF Stage 2 91 AGG Tune, Fuel-it Stage 2 LPFP, Solowerks S1 Coilovers, and DEPO/M-Sport Retrofit Last edited by BunkerJ; 07-06-2018 at 09:09 AM.. |
rjd_F302000.50 |
07-06-2018, 09:18 AM | #29 |
Rep 285
Drives: 2014 428i XDrive
your car sounds fine to me. the cars with issues sound like they have a supercharger on them...
07-06-2018, 12:18 PM | #30 | |
Rep 2,382
His car is good ATM.
07-06-2018, 01:40 PM | #31 |
Rep 3,680
Thanks for all the input guys and for calming my timing chain paranoia lol. BunkerJ thanks for the vids
07-11-2018, 07:32 PM | #32 |
Rep 396
Drives: 2022 X4MC - Marina Bay Blue
Well, I am going to disagree with the majority here. The scoring marks on his TC are indisputable and of concern. As to whether or not we can hear the whine (dying cat is a good analogy) probably depends more on the cell phone(?) microphone being able to pick it up or not. But the marks are there and OP is close to 70K, so absolutely no doubt he should go to the dealer ASAP. If for no other reason to document his concern BEFORE 70K in case the motor goes bad at, say 75K and he then is looking for BMW goodwill.
On one occasion, I have observed the seemingly excessive slack on my cold (N20) engine. At several other checks, the slack has been minimal.
'22 ///X4M Competition - fully loaded Marina Bay Blue.
Lowered on MSS springs. 20" x 10 ET20 Vertini RFS1.2 wheels wrapped in Firestone Indy 500 Firehawk 275/40 tires (square setup). Hers: '15 X4 2.8i - Glacier Silver - loaded M-Sport |
sspade2471.00 shubhammakharia8.50 |
07-11-2018, 07:51 PM | #33 | |
Rep 3,680
Regarding the noise, I can assure you I don't have the dying cat. The noise I was hearing is the natural whine/whirr of the engine, but I was paranoid and misinterpreted it. After further listening and analysis, I am 100% sure I don't have the dying cat noise. EDIT: this thread: https://f30.bimmerpost.com/forums/sh....php?t=1333666 also shows that almost all N20 owners (in that sample) had scoring on their chain as well.
07-12-2018, 11:37 AM | #34 | |
Rep 2,382
rjd_F302000.50 |
07-12-2018, 01:40 PM | #35 | |
Rep 396
Old thread - probably from before we knew what those scorings really mean. My N20 motor with about 18k miles on it has zero scoring marks.
07-12-2018, 03:16 PM | #36 |
Rep 1,049
I am not an expert on that engine or its timing chain problem, but the side-to-side movement is normal and necessary if the chain is to move over the sprockets. A loose timing chain has movement in the other direction. (the way the tensioner pushes).
07-12-2018, 06:42 PM | #37 |
Rep 2,382
Because 18k miles...
07-12-2018, 11:06 PM | #38 |
Rep 3,680
+1 I'd hope you don't have scoring at 18k miles. That thread isn't that old. If we discount 1 year old threads as non-reputable, than we slice our wealth of knowledge on the forums into a fraction of what it really is.
07-13-2018, 09:09 AM | #39 |
Rep 2,382
Seems scoring starts to appear around 40-50k on most. I'm not saying it's great but it doesn't appear severe on most engines.
07-13-2018, 10:40 AM | #40 |
Rep 230
1. 'Scoring' cause by traveling over the guides is normal, made by contact of 2 surfaces.
2. 'Scoring' cause by traveling over the guides can not be seen from the oil fill hole - it is on the inner edge of the chain (bottom if you look top down thru the hole) 3. Scoring on outer edge (the one you see thru the hole) is cause by 1 thing only (if I remember correctly) - tensionner boot. All it indicates that the tensioner works. If too much "scoring" - may indicate the chain is stretched. |
07-13-2018, 01:21 PM | #42 | |
Rep 63
BunkerJ1032.00 |
07-13-2018, 03:11 PM | #43 |
Rep 5,460
Drives: F30
My chain is as tight as can be and has ZERO play when ice cold as well as when hot. No visible scoring. 57k miles.
One thing I did notice was white smoke coming out of the opening when I went to check the chain after driving. Never done this before so not sure if that's normal or not? |
07-13-2018, 03:13 PM | #44 | |
Rep 2,382
