07-10-2014, 08:48 PM | #6887 |
Rep 40,650
///M Hud is only possible with ///M Kombi.
07-11-2014, 12:19 AM | #6888 | |
Rep 67
Can you please see what is in the picture? |
07-11-2014, 02:28 AM | #6889 | |
Rep 16
My cable is OK but nothing... can you send to me another files for F30 please? |
07-11-2014, 01:42 PM | #6890 |
Rep 802
Hi All ... its been a while since I've been on the forum. Took my car in to correct the "limp mode" which has now happened again (already took it in to have the fan swapped out once), but this time they said its a new fan model + they reprogrammed my DME.
Needlesstosay, they wiped out all of my settings/programming, so I once again have to go in and re-do everything. Can someone pls tell me how I determine what ESYS and PSDzData I will need? Can I use the original versions I had (Sept 2012 build), or have the versions I need changed since my DME was reprogrammed. Any help here would be appreciated. Many tghanks. I guess my question is - how do I determine what versions I need?
2020 X5 M50i | 2015 X3 28i xLine | Retired 2013 335i M Sport
07-11-2014, 02:03 PM | #6891 |
Rep 40,650
They reprogrammed your car, so you need the latest PSdZData, and if you are using E-Sys version older than 3.23.4, then you need to update it too.
PM sent.
07-12-2014, 11:16 AM | #6893 |
Rep 40,650
PM sent.
07-12-2014, 01:20 PM | #6894 |
Rep 40,650
Normally this is from Incorrect Target selection or corrupt PSdZData.
07-12-2014, 09:31 PM | #6895 |
Rep 67
07-12-2014, 09:53 PM | #6896 |
Rep 40,650
F20, without the Direct is correct Target.
What PSdZData and E-Sys versions are you using?
07-13-2014, 04:47 AM | #6897 |
Rep 60
Hey Shawn
Feb 2013 build 320D M-Sport, I guess I am going to need the newest E-Sys and data files, along with patch and token? If yes, then can I get a PM with the details please? Jerry |
07-13-2014, 04:52 AM | #6898 |
Rep 40,650
PM sent.
07-13-2014, 11:15 AM | #6899 |
Rep 16
07-13-2014, 01:12 PM | #6900 | |
Rep 40,650
Until you are getting a 169.254.xxx.xxx IP adress on your Network Adpater, you will not be able to connect to car.
07-15-2014, 06:35 AM | #6901 |
Rep 883
Any one know how to "code-out" DHP? I'm thinking if doing coilovers and have the adaptive suspension.
If I disconnect the damper it gives me an error. They've been doing this with the E9X M3 with EDC and I thought I saw on this forum or another forum some people internationally doing this with success.
07-15-2014, 12:56 PM | #6902 |
Rep 41
hi shawn,
can you send me a link to the latest PSdZData version. My "I-Step" is F020-14-07-502. is there already a new PSdZData version for? thank you |
07-15-2014, 01:21 PM | #6903 | |
Rep 40,650
PM sent.
07-15-2014, 02:54 PM | #6905 |
Rep 40,650
PM sent.
07-16-2014, 04:46 PM | #6908 |
Rep 40,650
PM sent.
