02-06-2016, 07:57 AM | #46 |
Rep 195
I don't know what to say. Apparently, aspects of my personality deem me ineligible to the clauses contained within the BMW Service and Warranty Book, according to some on this forum. I thought it was utterly clear that I brought in the vehicle for service complaining or warped rotors and was told flat out and without explanation that they would not be covered "because of rust." Since I did not post the service record(s) for this issue some thought that I brought in my car complaining of rusty brakes (). From that point on, and after BMW NA's investigation, they too sided with the dealer because "the rotors were rusty." The investigation, which lasted for over a month, was ended with the same individual leaving a voicemail stating that (paraphrasing), "BMW was more than fair in this case and that the rotors were indeed not covered because of rust. Therefore, I have closed the investigation... thank you and have a great day." Upon a follow up call to the customer relations number, I was informed that I was not allowed access to details over the phone or in writing of the "investigation," and that there is nothing that can be done because the case is closed. Step forward to this new thread where I have individuals attacking my personality and intelligence, writing that water causes metal to rust and so I mustn't worry, and so on and so forth. Regardless, thanks to all who put forth an effort in discussing this with myself and the other posters on this forum.
02-06-2016, 09:13 AM | #47 |
Moon Parasite
654
Rep 1,336
So which dealer is it in Chicago that you have been dealing with ? I noted in your letter you omitted the name.
2020 X4M Comp. (currently stock) - Was 2015 335 MSport -MPPK -Borla ATAK -Dinan Sport+ - E.R. Charge pipe / 2013 X1 35i Sport - Dinan tune / 2009 X6 50i Dinan badged |
02-06-2016, 09:34 AM | #48 |
Rep 247
I think I understand your issue now. I mistakenly thought the brake issue you had could also be caused by excessively corroded brake discs. You are positive that the sensation is due to warped discs that can occur whether or not the discs are also rusty.
I think a fellow poster gave some great advice if this were to happen again which you already mentioned in your posts and complaints to BMW NA. That is, if the discs are only being replaced because they're rusty, that you should've been at least provided with confirmation of the disc runout and thickness to confirm that those two items were still within spec. The takeaway for everyone else should be this. At our first brake pad replacement, we should demand to have the runout info shown on our service record vs. the minimum spec. It is most likely that the discs are just barely serviceable after the first set of pads which means at some point during our second set, the discs will be dangerously thin and will be prone to warping. At least that's my theory. |
02-06-2016, 12:09 PM | #49 | |
Rep 105
I understand and empathize with you that your points weren't being understood. I've had that issue as well, but consider some of that is your presentation, as mentioned above. You can't post six times in a row and expect reading comprehension to improve. I'm sorry this happened and I hope the rest of your car experience is better, truly. If this is how you acted with BMW, however, it's no wonder you don't have more answers. |
02-06-2016, 05:48 PM | #50 |
Rep 195
02-06-2016, 06:04 PM | #51 |
Moon Parasite
654
Rep 1,336
02-06-2016, 09:32 PM | #52 | |
Just Copacetic!
177
Rep 616
02-06-2016, 11:28 PM | #53 | |
Rep 195
02-06-2016, 11:34 PM | #54 |
Rep 195
Also, please stop trying to lecture me on how I deserved to be treated poorly because I insist, as a loyal customer and enthusiast, that BMW et al. have their sh*t together. You're wasting your time. I was over it at the point (which this thread explained to me and I am thankful for) that the boneheads at BMW NA customer relations didn't realize that I brought the car into service for excessive wheel oscillation when braking, which was highlighted (literally) in the information I mailed to them. I'm sorry I didn't consider the idea of this, as troublesome rust on a 2013 car without major body/collision work is really unheard of.
02-07-2016, 02:39 AM | #55 | |
Rep 5,087
02-07-2016, 04:42 AM | #56 | |
Rep 195
02-07-2016, 07:25 PM | #58 |
Rep 195
I finally received a respectable response with somewhat of an explanation. This is the response from the BBB complaint I sent to them:
"It was found that this customers brakes were rusty, which is outside influence. BMWNA covered 100% of the parts as a goodwill gesture." Besides the missing apostrophe, this is much more information than I received from the dealership or the guy on the phone... Regardless, I responded by writing this: "I am not accepting this response because [BBB verbiage, not mine]: The service records indicate that the vehicle was brought in for service because of excessive oscillation (i.e. it felt as if the rotors were warped) at highway speeds, which I thought to be a safety hazard when braking. It was more difficult to control the vehicle because of this and slowing times felt longer. The front discs were already replaced because of this same issue, at no cost to me. The dealership did not follow protocol by measuring the thickness of discs and any variation of thickness at different points on the discs. I did not request that the rotors be replaced because of rust- I asked them to explore the excessive oscillation by driving the vehicle on the highway at 65mph to try to slow the vehicle. They did not measure the thickness of the rotors or take the vehicle on a test drive to investigate this safety concern. I have several dealers vouching that they would have replaced the rotors, if warped, at no-cost to me. However, I needed the car that day to travel out of state. Respectfully,..." |
02-07-2016, 07:27 PM | #59 |
Rep 195
There are several in the 'burbs, but often times it would take an hour and a half to get there in traffic. This is time I did not have at the moment, and I needed the brakes working safely before traveling on the highway.
02-07-2016, 08:01 PM | #60 |
Rep 195
Here are the service notes. Notice how there are no measurements of the discs, yet I have record of this on the service notes when the front rotors were replaced at no-cost. Also, they did not test drive on the highway to address my safety concerns before they began replacing the rear brakes.
02-07-2016, 11:08 PM | #61 | |
Rep 216
Take some personal responsibility and go find another Chicagoland area dealer to do your service and warranty work... |
02-07-2016, 11:35 PM | #62 | |
Rep 195
02-07-2016, 11:37 PM | #63 | |
Rep 195
02-08-2016, 06:08 PM | #64 |
Rep 165
02-08-2016, 07:50 PM | #65 |
Rep 195
Thanks for your help. I have purchased my BMWs from Laurel BMW of Westmont, and they are excellent in the sales department. I did not accept the lease deal from the other dealership- it was simply a starting point for my car search. As I stated earlier, I have used the other dealer for service out of convenience on a leased vehicle- if they fu*k it up it's not my problem. I didn't think I was out of bounds for driving to an authorized BMW dealer for brake service and expecting a level of quality for the amount of money it costs to buy or lease these vehicles. Also, excuse me for expecting the terms of the no-cost maintenance program to apply at said dealership.
02-10-2016, 08:50 AM | #66 |
Too much is never enough
655
Rep 3,079
Stop riding/overheating your brakes. Brakes should never wear this quickly. "Warped" rotors are a myth. "Warped" rotors won't lead to accelerated pad wear. My vote is that you're overheating your brakes and that you've got pad deposits all over the rotors causing the vibration. Rotors that have been excessively overheated rust much more than those which haven't. I think the rationale provided by the dealer regarding rust being the cause was inaccurate. But, any signs of significant rusting are a telltale sign of overheating which, along with your absurdly rapid pad wear, are definitely indicative of "outside influences" and not indicative of a material defect or flaw.
And, as noted already by many, when ten people are confused by your comments and you need to resort to yelling in an attempt to get your point across, it's time for some inner reflection and a review of the message you've been attempting to convey. You need to remember that even though it's "simple and clear" in your own mind, we can't read your mind... |
