BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Wheels and Tires -- Sponsored by The Tire Rack > Factory OEM F30 Wheels Offsets (18, 19, 20 inch) and Brake Sizes
      05-01-2012, 10:55 AM   #1
E90Fleet
South Africa
1312
Standard factory wheels offsets:
  • 18" Double Spoke Style 400M (M Sport wheels) - 18x8" ET34 225/45-18 front / 18x8.5" ET47 255/40-18 rear
  • 18" Double Spoke Style 397 (Sport Line wheels) - 18x8" ET34
  • 19" Double Spoke Style 401 - 19x8" ET36 225/40/R19 front / 19x8.5" ET47 255/35/R19 rear
  • 20" Cross Spoke Style 404 - 20x8" ET36 225/35/R20 front / 20x8.5" ET47 255/30/R20 rear
  • 20" M Double Spoke Style 405 - 20x8" ET36 225/35/R20 front / 20x8.5" ET47 255/30/R20 rear
Brake sizes:
328i front brakes: 12.3" / rear - 11.8".
328i M sport brakes - front: 13.4" / rear: 13.6"
335i front brakes: 13.4"
335i M sport brakes - front: 14.6" front / rear: 13.6" rear
BMW if you are reading, I need a job, Please.
Appreciate 10
      06-06-2012, 10:08 PM   #2
clarence
Drives: F30 328i M-Sport
Pls also put the disc sizes of EU-spec cars on the list.
      06-19-2012, 02:41 PM   #3
LAnderson23
Drives: 2015 M4
What is the bolt pattern?
      06-30-2012, 02:53 PM   #4
remmib
remmib's Avatar
Norway
1568
Drives: 2013 F10 520d M-Sport
Standard BMW 5x120 bolt pattern.
F10 520d M-Sport Alpine White | HRE P43SC 20x9+20x11 | Michelin PSS 255/35+295/30 | KW V3 Coilover | M5 Front Sway Bar + M550d Rear Sway Bar | 3DDesign Front Lip | BMW M Performance CF Spoiler | BMW M Performance Diffuser | BMW M Performance Black Grills | BMW M Performance Pedals |
      07-15-2012, 11:08 PM   #5
adamsclubs
Drives: 2011 328i sedan
The widest OEM rims are just 8.5"?
      07-18-2012, 10:53 AM   #6
remmib
remmib's Avatar
Norway
1568
Yes, on the e90 it was 19x9 with same width tires, 255/30/19.
BMW kind of did the same with the F10, widest is 9" in the rear with 275 tires both on 18", 19" and 20", but on the e60 it was 9.5" in the rear wiht 19".
      07-26-2012, 02:08 AM   #7
Merlin93
The New Guy
Merlin93's Avatar
Drives: '06 Z4 3.0si Roadster
It may be worth noting the M Sport Package OEM wheels since I don't see an 18" staggered config listed yet...
  • 18" Double Spoke Style 400M - 18x8" ET34 225/45-18 front / 18x8.5" ET47 255/40-18 rear
2013 328i Sport Line-Alpine White w/Coral Red ZTP ZPP ZDA ZDB ZDH ZLP 494 5DF 5AC 5DP 688 302
2006 Z4 3.0si Roadster-Black Sapphire w/Black, Sport & Premium Packages, Xenons, Heated Seats, Nav
      08-08-2012, 02:58 AM   #8
tiltmode43
I plead the 5th.
tiltmode43's Avatar
Drives: '18 Frontier Pro-4X, '06 Z4MR
Great collection of OEM sizes! Interesting that BMW staggers the wheels by a mere .5" but staggers tire size by more than 1"!
-Matt
| Z4M Build Thread | @violetnites | flickr |
      08-09-2012, 11:46 PM   #9
Fugly M3
Fugly M3's Avatar
5070
Drives: 2023 M3CX
so the M-sport gets bigger brakes as part of the M-sport line?
      08-10-2012, 10:32 PM   #10
dcg71
72
Drives: F15 X5
Probably worth mentioning that the wheel lugs are different in comparison to the E9x. F30 uses a 14X 1.25mm thread pattern.
2015 F15 X5 25d Space Gray | Pure Excellence | Dakota Leather/Brushed Aluminium | Anthracite Head Liner | Fender Flares | Connected Drive + Real Time Traffic
2012 F30 335i Sapphire Black
2006 E92 325i Titan Silver
2000 E46 318i Cosmos Black
      08-10-2012, 10:58 PM   #11
Fugly M3
Fugly M3's Avatar
5070
Drives: 2023 M3CX
offsets and width aside, that shouldn't affect e90 spec rims fitting an f30 should it?
      08-10-2012, 11:05 PM   #12
metrickid
Dinosaur supervisor
metrickid's Avatar
Netherlands
3030
Drives: E91 318d
No, it is the optional M Sport brakes available on most markets.
      08-10-2012, 11:19 PM   #13
Fugly M3
Fugly M3's Avatar
5070
Drives: 2023 M3CX
that's what I thought
      08-11-2012, 04:37 AM   #14
dcg71
72
Drives: F15 X5
Wheels will fit fine. Spacers, or more specifically their extended length lugs, won't fit.
      08-11-2012, 10:55 AM   #15
Fugly M3
Fugly M3's Avatar
5070
Drives: 2023 M3CX
ok, so with f30 spec spacers (for the front) I should be fine then
      08-16-2012, 09:52 AM   #16
Stylz_2nv
Trinidad_and_tobago
Drives: 2012 BMW F30
Red face Brake n Rim Size
Just recently bought 2012 F30 Sportline just 2 months ago, also I just joined this site.
Can the M sport upgrades as per brake or brembo work on my series... also if I run Stagged - 18x8" ET34 225/45-18 front / 18x8.5" ET47 255/40-18 Rear Will it touch as I plan to run coilovers pretty soon
Just wanting someone to direct me where I can source all my aftermarket parts. Thanks.
      08-19-2012, 07:29 PM   #17
Fugly M3
Fugly M3's Avatar
5070
Drives: 2023 M3CX
so I was using the wheel/tire size calculator over on e90post.com because for whatever reason there isn't one here yet. but here's some interesting information
stock base wheels: 17x7.5 et37
ZSL/ZML/ZLL wheels: 18x8 et34
ZSL/ZML/ZLL 19" or all ZMM staggered set ups: 18x8 et34 or 19x8 et36 front and 18/19x8.5 et47 rear
Going from the standard 17s to the 18s pushes out the wheels at all four corners by 9mm
Going from the standard 17s to the 18 staggered set up pushes out the front wheels by 9mm but the REAR BY ONLY 3mm!!!
Going to the 19 staggered set up pushes out the front by 7mm and the REAR BY ONLY 3mm!!!
interesting stuff. given this I am really starting to think that a 235/50 17 or 235/45 18 square setup is best. Maybe 245 but the tire sizes will be a bit shorter. Yea the 235 is taller, but it should fill up the wheel wells better.
      09-30-2012, 09:23 PM   #18
Snakerog
Drives: 2013 328i Modern Line, Orion S
BMW X5 wheels on F30
First off let me apologize if this post is in the wrong place. I am new to posting on forums. I would like to know if you can mount X5 five spoke wheels on a 2013 328i. Thanks. Ben
      12-17-2012, 10:08 PM   #19
milgaussf30
Drives: 2013 328i xDrive
I apologize if i'm sabotaging this thread.. but i think it's in line with the topic(wheels). I just purchased an F30 w/ xDrive Luxury line .. are there any special considerations when going to 19" wheels? I heard that xDrive limits wheel size.
      01-01-2013, 01:44 AM   #20
7 4 7
7 4 7's Avatar
India
127
Drives: E46 328i, F30 328i, G20 M340i
Originally Posted by E90Fleet View Post
Standard factory wheels offsets:[LIST][*]18" Double Spoke Style 397 (Sport Line wheels) - 18x8" ET34
^ I am currently running on the above Style 397 rims square setup on my 328i - Sportline
Thinking of upgrading to non rfts ( staggered setup )
Have 2 Questions ;
1) Can i go staggered setup on the existing (OE Sportline - Style 397) rims ?
2) If yes, What Size ?
BMW F30 328i (A/T) | Toyota Fortuner 4x4 (M/T) | Toyota Hyryder Hybrid (e-CVT) | BMW G20 M340i | Skoda Kushaq (A/T) | Kia Seltos (DCT) | BMW E46 328i (M/T)
      01-01-2013, 05:10 AM   #21
dcg71
72
Drives: F15 X5
I think 245 is about the widest you could go on an 8" wheel, so you could potentially stagger with 245s on the rears. May look a little beefy though. 235 all round might be a better solution.
      01-01-2013, 12:58 PM   #22
shivaswrath
shivaswrath's Avatar
Drives: 2012 335i
Great info, subscribed.
I think BMW lowered the width because of EPA standards...the farther out a rim is from the hub, the more drag and less efficient it'll be aerodynamically. Additionally, less wide=less weight.
SOLD: 2012 335i Mineral Gray
f30 3 series wheel offset, f30 3 series wheel offsets, f30 328i wheel offset, f30 328i wheels offset, f30 328i wheels offsets, f30 335i wheel offset, f30 335i wheels offset, f30 335i wheels offsets, f30 offets, f30 offset, f30 wheel offset, f30 wheel offsets, f30 wheels offset, f30 wheels offsets, wheel offset f30, wheels offset f30, wheels offsets f30
