05-13-2013, 05:35 PM | #1 |
Rep 89
What is that noise - 6 Speed Manual Transmission Owners
Hi all,
So I brought my vehicle in for two noises that I can reproduce on demand. I just hit 1200 miles in a brand new 2013 335i sedan M-sport 6MT and brought the vehicle in just to make sure these noises were "normal". To preface: I took the shop foreman for a ride and reproduced both noises. He confirmed he could also hear the noises clear as day. 1. First Noise: If possible, go to an enclosed parking garage where you can hear the engine noise reverberate off the concrete walls (if not possible to get to a garage, I could also hear the noise bouncing off building walls). Now park the vehicle, roll down all windows, turn it off, and let it rest for a good couple minutes. After the engine has rested (off), do the following within the first 10-45 seconds: Fire up the car, keep it in first gear the entire time, and start driving slowly/gently by accelerating to no more than 20mph, then release your foot from the gas and let the vehicle coast. Do you hear the sound of metal plates spinning/grinding against each other? It's fairly high pitched and sounds close to that of a miter saw winding/spinning down. It is most noticeable from the passenger side window. Do this process again. For me the sound happens every time I start the car and lasts the first 1 minute in first gear (at less than 20mph). Shop Foreman has had the vehicle all day and compared it to another Service Tech's 2013 335i Sedan with 6-speed. They also hear this noise in the test vehicle. I would like to know if any of you 6MT M-sport 335i Sedan drivers also hear this. Please post back if you can! 2. UPDATE: THIS WAS FIXED. Second Noise: Accelerate hard enough to 3000 RPMs where you can hear the engine being "worked". At approximately 2200 RPMs in 1st, 2nd, 3rd, or 4th gear, there is a raspy/buzz/rattle noise that comes from the dash and lasts from 2200-2500 RPMs and then is gone. I can reproduce this in any gear under those conditions. Tech found something loose in the center stack - apparently it is now fixed. Hopefully it never comes back. Last edited by itwasepic; 05-14-2013 at 10:56 AM.. Reason: Second noise fixed. |
05-14-2013, 01:15 PM | #3 |
Rep 89
05-14-2013, 06:59 PM | #4 |
Rep 525
05-15-2013, 09:35 AM | #6 |
Rep 525
05-15-2013, 09:44 AM | #7 |
Rep 2,148
Drives: F87 M2 BSM MT
I guess you are hearing the exhaust flap actuator opening and closing. Just unplug it in the open position and forget about it.
05-21-2013, 09:40 PM | #8 |
Rep 188
1200 miles on my m sport 335 and I also hear the noise you are talking about OP. sounds like a clutch chatter type of noise. In neutral, push clutch in and out no noise. Put in first hear and sure enough every time I hear the noise. I thought I was the only one that it happened to
11-16-2013, 02:08 PM | #9 | |
Rep 1,267
11-17-2013, 07:53 AM | #10 |
Rep 77
I had a similar/same problem with my E90. Took some time to reproduce the problem at the dealership, but eventually they found that a heat shield was the issue. Once tightened or whatever, problem went away.
The clutch does chatter ever so slightly at very low RPM, and there is a bit of gear lash noise under certain conditions. The chatter is a bit disconcerting given low miles (just 30 K), but every car I've owned with a manual transmission has emanated some gear noise so not a surprise that my E90 does the same. |
11-17-2013, 09:03 AM | #11 |
Too much is never enough
655
Rep 3,079
It may indeed be a heat shield. But a resonance, not rattle. The fact that it only presents when you first start/drive the car would support the concept of it involving something exhaust related. Even if recently driven, exhaust components cool quickly. The thermal expansion during the initial drive may be sufficient to prevent the noise once fully warm. Try starting the car and letting it idle for a few minutes to allow the exhaust to fully heat/expand. Then see if you can produce the sound.
11-17-2013, 10:54 AM | #13 |
Rep 214
I have the noise 1 and dropped it to the dealer. They said it is wastegate rattling but it is normal operation. The loaner they gave me had the same noise and their test vehicle also had it. I think all of our F30s have that metal grinding/spinning noise.
For the second noise, I still have it on mine and couldn't reproduce it to the tech so they did not diagnose it. Can you tell me more details about #2 please? What was it, how it sounded ( is it same as the video one of the guys posted? because that is exactly what i have ) and how they fixed it. They should have details on how they fixed it. Oh and are you all South Africa build? Or any Germans? Thanks!
Current: 2019 G05 x5 50i M-Sport
Past: 2016 F10 550i M-Sport ~ 2015 F83 M4 Convertible ~ 2013 F30 335i M-Sport ~ 2006 E85 Z4 30i |
11-17-2013, 11:08 AM | #14 |
Super Spectacular Awesome Dude
69
Rep 577
The only noise I hear is when I turn off the ignition and wait for a minute. I hear things possibly closing??? And when I hit "unlock" in the morning, I hear mechanical razzle dazzle as well.
11-17-2013, 10:57 PM | #15 | |
Rep 1,267
11-18-2013, 08:42 AM | #16 |
Rep 214
Yes. I also figured it is coming from the dashboard. But cant figure out where. I tried playing around with the HK grill in the middle that kind of reduced the noise. Need to drive more to see if it effected anything.
08-03-2016, 06:37 PM | #17 |
Rep 128
Picked up my 2013 335i x Drive 6mt on Saturday. This afternoon I noticed a rattling grinding noise in sport and sport plus mode. The noise happens when I'm in 3rd gear and take my foot off the accelerator. Made an appointment with the dealer for Monday. Is this a noise im going to have to live with? Or is it fixable. It's a CPO win 42,500 miles so I'm still under manufacturers warranty. I shouldn't have to pay for this right? Thanks
08-03-2016, 08:53 PM | #18 | |
Rep 1,476
Drives: 2022 G01 X3 M40i (Black/Black)
The video someone posted earlier in this thread now has a dead link, so I don't know if what's described earlier is what I'm experiencing. Any update on this issue (Noise #2)?
2022 G01 X3 M40i (Black Sapphire/Black), HK, DAP, PAP, Shadow Line
2014 F30 335i (EB) 6MT, M Sport, Premium, Tech, DHP, HK, CW, M Brakes, M Exhaust 2006 E90 330i (Silver) 6MT, Sport |
08-10-2018, 03:29 PM | #19 |
Rep 29
I have both the whining/high pitched noise(that changes pitch 1500-2500k - most audible around 2000) coming through the central vent and the rattle noise from the hud area when 3000+ and under load.
Any updates on how to fix them? |
