02-16-2015, 05:48 PM | #1 |
Rep 688
Comfort Access Not Working?
So yesterday, my comfort access refused to work. I couldn't unlock the door by pressing my fingers to the inside of the handle, nor could I locked the door by touching the top of the handle.
I was about ready to bring it in to be looked or (or check to see if there's some setting I somehow disabled). Then this morning, it mysteriously started working again. Has this ever happened to anyone else? And is there a setting to disable it or configure it?
2014 Carbon Black 535i M Sport - Bootmod3 / M Performance Exhaust / Carbon Graphite Vorsteiner V-FF 103 / KW V2
Retired- 2013 MG 328i Sport Line 6MT - BMS Stage 1 / M Performance exhaust / M Performance steering wheel / M Performance shift knob/boot |
02-16-2015, 06:16 PM | #2 |
Rep 3,089
I wonder if your key fob is low on battery or if something in your pocket was interfering with it? Sometimes I have to try twice for CA to work. Not sure what causes this.
02-16-2015, 09:39 PM | #3 |
Rep 140
Drives: F80, G01
My CA was working on both doors, after a few months of ownership, and only using the driver door, I was opening the car via the passenger door and it didn't open. I had to dig around for my keys, to unlock the car. When I got home I tested it and it seems that driver side was working, passenger side was not.
Took it into the dealer to have it fixed. They replaced some module and had the car for a few days. Works fine now. |
08-04-2015, 01:03 PM | #5 |
Rep 1,231
this is now happening to me, comfort access been working when it feels like it for the last couple of months and now stopped working altogether, now the trunk wont even pop up when I sweep my foot under the bumper, guess back to the dealer...starting to get annoyed now...every two months is a new issue with something
10-10-2015, 03:38 PM | #9 |
Rep 918
Mine always UNlocks the car but only locks it when the car is "home." If I drive it anywhere, it refuses to lock and I have to use the damn remote.
My neighbor has a 2010 335 and his has been doing it for 5 years but ONLY when he drives it, not when his wife does. Maybe it's a genetic thing because the same thing happens at this house. Different remotes at his place but the same remote used here so that indicates there's likely defective remote - he says with crossed fingers. Anyway, I dropped mine off yesterday with both remotes and asked them to fix this little problem. Of course there aren't any tech types there today or tomorrow so the earliest anything will happen is Monday. The good news is that at least it "failed" numerous time in a row for both the SA and the Service Manager. We shall see and I'll post what happens. |
10-13-2015, 01:28 PM | #10 | |
Rep 918
10-13-2015, 01:35 PM | #11 | |
Rep 288
Drives: 2016 328i xDrive M Sport
10-13-2015, 02:19 PM | #12 |
Rep 918
10-13-2015, 03:29 PM | #13 |
Rep 288
You're not the only one. :P I'm having issues with the comfort access on my wife's car. The foot waving trunk thing doesn't work. not sure why..
10-16-2015, 07:20 PM | #14 |
Rep 918
OK, here's the deal on the Comfort Access. I got the repair sheet today when I picked up the car.
There were no "faults," no "Bulletins" and all the wiring and connectors were OK. As a result, they concluded it had to be the driver door electronics had to be faulty and in need of replacement. I am So glad the Service Manager and the SA saw it with their own eyes! It's worked six times so far so I guess that was it. |
10-16-2015, 07:27 PM | #15 | |
Rep 918
When I bought the car, the guy was trying to demonstrate that function and I thought his foot was going to fall off from all the waving - I tried the in and out and it worked fine. Just a simple in and out motion should do it. It doesn't open instantaneously so be a little patient. Likewise, once it "pops," if you wait another couple of seconds, it will actually open all the way so there's no need to touch it. (I presume that's the same on all of them?) |
10-17-2015, 12:44 PM | #16 |
Rep 918
Not trying to beat this subject to death but CA is still working this morning. What has changed though is that before the "fix" (as in since day one) I had to actually pull on the door handle to have it unlock. Now all I have to do is slide my fingers into the door handle and it unlocks - no pulling at all - I like that!
10-17-2015, 02:06 PM | #17 | |
Rep 288
10-17-2015, 02:07 PM | #18 | |
Rep 288
12-07-2015, 12:06 PM | #19 |
Rep 918
I cannot believe this! I am once again having trouble locking the vehicle. Took it in and they confirmed it was inconsistent. I think I need to create some sort of "log" on this malfunction. I can get it to work at home but it fails if I drive somewhere.
Hmmmm - it dawned on me that it only seems to happen after the car has been started and driven elsewhere. When I go to the dealer, I have obviously done that and fails to lock in the presence of the SA (at least once). Last visit, I got out of the car and it wouldn't lock. As SA went to get new batteries for the remotes (just rolling the dice) I noticed my parking lights were on opened the driver door, and turned them off and did what any other insane person would do - pressed the lock button and it locked. I'm starting to wonder if this is a "start and drive somewhere issue" or, perhaps, something to do with opening and closing the damn door issue." SA is off this week so I'm waiting for his return and then make another appointment to see if they can find the problem. ETA The hyper sensitive UNlock function continues to work just fine - weird stuff. |
12-07-2015, 01:24 PM | #20 | ||
Rep 1,476
Drives: 2022 G01 X3 M40i (Black/Black)
2022 G01 X3 M40i (Black Sapphire/Black), HK, DAP, PAP, Shadow Line
2014 F30 335i (EB) 6MT, M Sport, Premium, Tech, DHP, HK, CW, M Brakes, M Exhaust 2006 E90 330i (Silver) 6MT, Sport |
12-07-2015, 01:42 PM | #21 |
Rep 614
Drives: 2016 F36 M Sport
Slightly off topic and I'm sure the answer is somewhere else on this forum, but when you touch the inside of the door handle to unlock the vehicle, does it unlock all the doors, or just the one you touched? I don't have CA, so I'm just curious...
2016 BMW 428i Gran Coupe, M Sport, Glacier Silver Metallic
