BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Cosmetic and Lighting Modifications (exterior & interior) > Need help on changing Xenon bulbs
      12-12-2012, 10:10 PM   #23
awhk
Drives: 2023 iX M60 SBM
That what I was wondering about you Blake!
How are you doing? You still got your B8?
      12-13-2012, 01:18 AM   #24
Blake P
Kinda Like A Big Deal
Drives: F31 on order
Yep, planning on picking up an F31 when they're finally released in the US.
      12-13-2012, 06:30 PM   #25
m5 guy
m5 guy's Avatar
Drives: 2020 M5 Comp
Replaced mine with Osram CBI's. They are 5000k with the illumination of a 4300k. Best bulbs on the market hands down. A pure wight light without any loss in visibility. Had them in my previous M3 and had to get them for my 335. They are absolutely
Install is super easy though it will be easier removing the wheel first. The E90 section here has some DIY's. It is the exact same minus getting to the bulb. On the F30 you simply pop off the plastic fender cover in the liner to gain access. Everything else is the same from then on.
2020 F90 M5 Comp Oxford Green Metallic II-Aragon JOURNAL
2016 F10 M5 Space Gray-Black SOLD
2012 E70 X5M Monte Carlo Blue-Silverstone SOLD
2001 E46 M3 Oxford Green Metallic II-Cinnamon SOLD
      12-13-2012, 07:51 PM   #26
awhk
Looking forward to see your mods again!!
Thanks for the info, I was able to access the fender cover and also the circular cover for the low beam. Just couldn't figure out how to release the clip holding the D1S bulb due to limited space (the clip seems quite a bit different when comparing to E90's). I guess removing the wheel is the way to go.
      04-01-2013, 02:18 PM   #27
eclipsisNA
Drives: 2013 Estoril 328i M Sport
2014 BMW 428i  [7.76]
Has anyone put different temp HIDs in their F30 yet?
      04-01-2013, 06:39 PM   #28
stu14t
stu14t's Avatar
Scotland
451
Drives: 330i MSport Pro
I'm about to try this on my F30. I salvaged the D1S Osram CBI's (my retrofit not standard) from my 2011 E87 LCI , a far superior whiter light.
The retaining socket on the E87 was a plastic type tag on the side of the bulb holder that you rotated counter clockwise to release the bulb. There was also these metal tabs that located around the square base of the bulb.
Is the arrangement the same on the F30?
      04-01-2013, 07:54 PM   #29
ad78
Yr1OfD1
ad78's Avatar
Drives: 2015 F34 M Sport
Stay with stock. Yes 6k are coll and blend with led AE's but you will get in trouble at night with rain
      04-02-2013, 03:04 AM   #30
stu14t
stu14t's Avatar
Scotland
451
ad78 - I'd agree with you on the 6k bulbs. I did try them and your eyes are just not good with light at that end of the spectrum in the dark and rainy conditions. Also, the more blue/white the bulb the less light output there is.
However, I have been using the Osram CBI's, rated at 5k, for over a year now. As m3 Guy has said they are fantastic. Same amount of light as stock and just enough white/blue light too.
Does anyone have pictures of the HID bulb socket?
      04-02-2013, 08:49 AM   #31
AWMSPORT
1ST CLASS AWMSPORT
AWMSPORT's Avatar
Drives: 13' 328 MSPORT
I heard you just go thru the wheel well ...I am doing a change as well to 6500-8000
'13 328i MSport, AW, Black Dakota leather, Premium Pkg, xenons, ///M Perf, side skirts,Front Lip, Fully coded, CF roundels, Matt Black Grillz, Painted reflectors (front & rear) Smoked tail lights, Plazma l.E.D White PY27W front turn signal,trunk spoiler, Matt Black roof, 8K D1S HID,Custom Exhaust,!
Soon:
JB4,DP,H&R sports,rear diff,!
      04-02-2013, 09:40 AM   #32
ad78
Yr1OfD1
ad78's Avatar
page 197 on the manual..
      04-28-2014, 08:03 AM   #33
funky_chilli
*burp*
funky_chilli's Avatar
Drives: '13 328i Sport Line
Hi I'm interested in these osrams, r they much whiter than stock? And how do they match with the angels? I'm after just pure white, don't want blue, or at most a slight tint. Thanks!
wils
'13 F30 328i Sport Line
Moved on from:
'09 E90 323i M-Sport | '08 MKV GTI | '02 MINI Cooper | '99 E46 318i Exec
      04-28-2014, 01:13 PM   #34
stu14t
stu14t's Avatar
Scotland
451
Much better than stock if you want a whiter light. I upgraded my 1 series and they were great. I did try some 6k's in but there was a noticeable drop in light output but the light output of the CBI's are the same as stock.
I have a the set out my 1er but not got round to fitting them yet
Current - 2021 G20 330i M Sport+
Gone - 2017 F30 335d M Sport + in San Marino Blue
Gone - 2015 F30 LCI 320d M Sport+ Step Auto
Gone - 2012 F30 320 ED
Gone - 2011 E87 118d
      04-29-2014, 09:48 AM   #35
funky_chilli
*burp*
Cheers. I may try out a set then. I used to have 5000k bulbs in my old GTI and miss the whiter light.
Although they were just some cheapo eBay xenon bulbs that I changed my oem bulbs for, I never had any problems with them.
I'm tempted to just buy the same ones but thought this time I should try better quality ones just in case
wils
Moved on from:
      04-29-2014, 09:54 AM   #36
stu14t
stu14t's Avatar
Scotland
451
Yes, Invest in the Osram CBI's they are a quality replacement and close to OEM
      05-05-2014, 07:11 PM   #37
casualDIYer
Drives: 340i xDrive M Sport
Imagine for a moment a multi billion car company that knows a bit more about headlight bulb temps than Joe X on ebay selling discount bulbs. Stick with factory.
      05-08-2014, 10:25 PM   #38
nyczyar
Drives: F30 335i
I changed my 4300k bulbs to 6000k, bought the after market ones for $27, lifetime warranty on eBay. If you want to remove the bulb, you have to squeeze the clips and turn left to unlock.
