BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N55 Turbo Engine / Drivetrain / Exhaust Modifications > F30 JB4 Stage2 Dyno Testing
      04-01-2013, 06:10 PM   #287
tdizzle
Drives: 2017 F80 ZCP
Originally Posted by mikew2069 View Post
Damn, I didn't have mine plugged in either... So did he say what kind of difference this would make?
Probably blow up your engine if you don't plug them in, no big deal as you can just find a M3 engine and drop it in instead. (I have no idea if you can't tell but assume it will perform better)
      04-01-2013, 06:30 PM   #288
Jeff_in_Oviedo
Delivered!
Jeff_in_Oviedo's Avatar
Drives: '13 F30 335 M Sport
I am going to guess that if you don't hook up the boost solenoid, then you cannot regulate boost. If anything, it is probably safer to not hook it up, lol. Of course, you do want to hook it up and get the increased boost levels and power.
Delivered!: 2013 F30 335i M Sport, 8-speed Sport Trans, Estoril Blue/Coral Red, 403M, Premium Pkg, Dynamic Handling Pkg, Driver Assist Pkg, HK Sound, Enhanced BT & USB
      04-01-2013, 06:39 PM   #289
mikew2069
mikew2069's Avatar
413
Drives: F30 335i MSport
Well I just plugged it in and also hooked up the jb4 interface. What's really wierd is my Map was set to 0. I wonder if since my car has been off for 3 days maybe it reset or something? .... I dunno but I'll get on it on my drive in to work tomorrow.
      04-01-2013, 06:47 PM   #290
anelson524
Drives: '15 AY F80
2015 BMW M3  [0.00]
2014 Audi SQ5  [0.00]
I hooked mine up and drove him and didn't feel much at all. Got home and checked and was on Map 1 for some reason so same situation. Haven't really gotten an opportunity to see much of a difference yet.
      04-01-2013, 07:00 PM   #291
TreDirtyFive
Drives: X3 M40i
the solenoid makes the most difference for top end boost and you will feel it distinctly at WOT at the upper RPMs but it does make a difference.
X3 M40i G01, M235i F22, 335 F30 MSport, 135 DCT, 335 E92, Audi A3
      04-01-2013, 07:28 PM   #292
mikew2069
mikew2069's Avatar
413
Did you have it set to Map2 before and it changed to Map1 on its own?
      04-01-2013, 07:53 PM   #293
anelson524
Drives: '15 AY F80
2015 BMW M3  [0.00]
Well it was definitely set at Map 2. There is no telling if it defaulted back to 1 or if I somehow had a combo streak of volume up and down to change it.
      04-02-2013, 02:12 AM   #294
RollingLower42
RollingLower42's Avatar
71
Drives: 2012 BMW 335I
So you need to have the solenoid plugged in?
      04-02-2013, 07:02 AM   #295
mikew2069
mikew2069's Avatar
413
For stage 2, yes.
2013 F30 335i ///M-Sport
Forgestar/Challenge/BMS JB4
Wagner/Evo Race/M-Performance
2016 F15 50i ///M-Sport
BM3/H&R/Borla
      04-02-2013, 08:25 AM   #296
spideypm
Drives: 2013' 335i M Sport
Anyone running maps other than 0,1, and 2? I saw on N54Tech someone ran Map 7 with racing fuel..
      04-02-2013, 08:38 AM   #297
spideypm
Originally Posted by tdizzle View Post
Have you fixed your issues? I think you were the one that mentioned you had basically limp mode issues right?
Haven't had a limp mode issue since last time. I did seem to locate the source causing the acceleration problem - my aftermarket intake. I think that might've triggered the limp mode with stage 2. I did have the engine light came on also believed to be caused by the intake and my sudden jump in acceleration was getting worse and worse. Removed the intake and am now running back on Map 2. Fingers crossed and hopefully no more issue.
      04-02-2013, 10:26 AM   #298
NICKTENN
NICKTENN's Avatar
Drives: 340i M Sport
What intake? Are you auto or manual trans?
*edit: Never mind, if you're running stage 2, you gotta be auto trans.
2016 340i M Sport Alpine White, BMS Intake, JB4 Beta
2012 335i Sport Line, RIP
      04-02-2013, 01:59 PM   #299
Monstr6
Drives: 2013 335i M sport
i thought the intake didn't work with Auto??
      04-02-2013, 02:01 PM   #300
NICKTENN
NICKTENN's Avatar
That's what I was getting at.
      04-02-2013, 02:37 PM   #301
TreDirtyFive
Drives: X3 M40i
Is this a drop-in filter or a full intake as i was sure there are no full intake applications for the f30 N55 yet outside of the overpriced Injen one?
also, Terry has dynoed the F30 N55 numerous times with and without intake; with and without tune and even with maximum flow (ala no intake at all) it made absolutely no more power and he was adamant that an intake for this application was a waste of money. you can find those dynos on the "other" site.
      04-02-2013, 03:13 PM   #302
RollingLower42
71
What "other" site? N55tech?
      04-02-2013, 04:30 PM   #303
tdizzle
Basically.
Apparently part of the reason was the higher flow didn't counter act the hot engine air it was sucking in to actually make more power. I think in some instances it actually made LESS power (negligible but still...)
      04-02-2013, 06:11 PM   #304
TreDirtyFive
Drives: X3 M40i
Basically.
engine hood was open with a fan(s)...
"image from top of the post"
      04-02-2013, 09:02 PM   #305
Mike@N54Tuning.com
Drives: 2007 335i, 2015 M3
That is the F30 328. The F30 335 is a different story all together and has power potential with intake changes. Not huge, but at higher boost levels significant enough to justify intake development. More on that in the coming weeks.
Mike
      04-02-2013, 10:16 PM   #306
NICKTENN
NICKTENN's Avatar
Mike
Oh you tease!!
      04-02-2013, 10:45 PM   #307
J-boogey
J-boogey's Avatar
Drives: F30 335xi Msport
2 weeks with stage2 running.. loving it but theres no comparison to my old N54, ER catless downpipe going in next week.
2013 F30 335i xdrive | Estoril Blue | Black Dakota Leather | Aluminum Hexagon trim | M-Sport | Cold weather | DHP | Premium package | Tech package | Harmon Kardon | PDC | Rearview Cam | IND Painted reflectors | BMW performance grills | JB4 stage 2 | ER downpipe | BMS Intake | H&R sport springs
      04-03-2013, 09:35 AM   #308
tdizzle
That will be a 'noticable' difference. Adding a DP and swapping to Map 2 should feel more dramatic than stock > Map 1 on stage 2.
That's like 100 wtq over map 1.
