08-08-2014, 06:22 PM | #1 |
Rep 233
need new tires/wheels
i have a 2012 335i sports line and its time to get new front tires due to impact bubbles and a new wheel because it has been bent(previous driver damages :/)
i have been to the BMW dealership and they are charging me a lot!! so i decided i was just going to buy the tires and wheel and do it myself, with the help of my mechanic friend. but i have come across two questions. 1. should i buy 2 new run flat tires OR 4 new conventional tires? all the places i have been to tell me everyone chooses conventional tires after the runflats go bad. 2.What are the wheels called? im pretty sure i have found them on a website but i want to be 100% sure. again, the car is a 2012 335i sport line and i believe they all come with the same rims but if im wrong please let me know and i will post a picture of it |
08-08-2014, 08:35 PM | #2 |
Rep 3,341
Drives: 2022 M3, 2022 X5 40i;
1. Buy whatever you want. If you want the peace of mind, get run flats. If you want a better handling experience but get stuck with a flat get standard tires.
2. They are called rims, they are the part that the tire mounts to. |
08-09-2014, 02:11 AM | #3 | |
Rep 262
1. If you do not buy run-flats, then make sure you have a tire repair kit in your car. Something like this : Slime 70005 Safety Spair 7-Minute Flat Tire Repair System 12-Volt . It'll get you where you need if you really get a nail / etc and don't want to be towed to the dealer. Drawbacks of runflats are 1. price 2. generally less comfortable and average performance. I suggest you buy one of the following tires: Continental DW Continental DWS Hankook V12 Bridgestone S-04 Pole Position Or , in my opinion the best bar none - Michelin Pilot Super Sports . You not only have pretty much the best non special order tire out there, it also looks badass. 2. Buy a set of wheels from someone in the classifieds section, or on ebay. If you want, you can look into aftermarket wheels. Just ask a vendor in the classifieds section. Used OEM wheels run from 800, while new aftermarket wheels run 800 - 10,000+. |
08-09-2014, 07:41 AM | #4 |
Rep 596
@willpower - agreed the Michelin Pilot Super Sports are an excellent tire. I am also going to replace my (stock) runflats with the Michelin's and a tire repair kit.
Don't get the Conti DWS - they're not that great! I've never been thrilled with the Conti. brand, they make average tires. OP - check out Tire Rack, and do some research first. You can just shop around, check out what tires you want (All-Season, Snow/Winter, Performance, etc.), and read reviews on the tires. The F30 has lots of different tire options, so you want what's right for your car. You car either came with the same size tires on all 4 corners (square setup), or it could've come with 2 smaller front tires with 2 larger rear tires (staggered setup). If you're unsure, just go to a tire place, and they'll help you out.
2013 BMW 335i xDrive Sport Line
08-09-2014, 11:03 AM | #5 | |
Rep 262
08-09-2014, 12:26 PM | #6 |
Rep 300
Have had the Conti DW on several cars (WRX & S2000) and they are great tires. The fact that they are reasonably priced is a bonus.
Next set for the F30 will be the Michelin PSS to see if the tire matches the hype Jimbo |
08-09-2014, 12:35 PM | #7 |
Rep 227
Replaced my Pirelli RFTs with Michelin PSS and loving it. Got a "slime kit" that's similar to what they provde in the M cars in case of minor flats.
