02-06-2023, 03:55 AM | #89 | |
Newbie with some skills
22
Rep 70
Drives: BMW F30 318D Luxury
And Ground on PIN16
Retrofit : S676A, S3AGA, S481A, S488A, S459A, S5ACA, S5DCA, S6NKA, S8THA (emulator), S710A |
02-07-2023, 02:24 PM | #90 |
Rep 271
Just to get this straight in my head. Do you have to take the larger grey box off the underneath of the original seat and put it on the new seat going in? Even if the new seat going in is of a higher spec?
02-07-2023, 03:52 PM | #91 |
Rep 25
804365 Fond stratification control: Short circuit to ground
E58C47 Seat heating, front passenger: missing LIN component E58C49 Seat heating, driver: missing LIN component this errors i have? any help? heating goes on its green then after 4-5 sec button is off what i did is: car came with CS seats, full electric. I tooke them out and put leder full electric from M2. Module is from new car... Everything coded |
02-08-2023, 09:54 AM | #92 | |
Rep 817
Drives: bmw M3 F80
Have you installed your original modules on the new seats? |
03-02-2023, 05:15 AM | #94 |
Rep 6
I guys sorry to refresh old trend.... I just got a bmw f30 330d msport. Vehicle came with manual seats with only lumber support it is the 2013 vehicle. Looking at doing a electronic memory seats retrofit. Just purchased seats from 435i, only has a white box on the driver side. Can some please help me? Also i would like to know if its possible to get the electic function and memory function both working... Please not my current seats have no heating or white modules under the seat
03-25-2023, 02:55 PM | #95 |
Rep 57
Finally got round to doing this retrofit with the awesome instructions david51 sent to me over a year ago. Makes a huge difference to my touring and will be modifying the back seats to fit next.
My car had the manual heated sports seats with rear width adjustment, 2018 340i F31. Both seats had the small black module as stock. Only needed wiring in to kcan on drivers side, couple of wires for badge illumination, and then power from fuse box to pin 15 on both sides. A little VO coding on e-sys and everything is working perfectly! |
david51539.50 |
03-28-2023, 11:31 AM | #96 |
Rep 271
So did you use kcan or kcan2? It seems that cars (or seat module) up to a certain year use lin, then some use kcan and the latest stuff uses kcan2. I connected mine to kcan (pins 51 & 52 on FEM) and the SM doesnt show in insta or esys. I believe mine need kcan 2(yellow/red and yellow/brown)
03-28-2023, 11:42 AM | #97 |
Rep 817
Drives: bmw M3 F80
For heated seats
K-lin (for those who have the small black modules) For large white modules Connection according to the year of the seats For seat after July 2013: 5 to Pin 49 /K-CAN2_L (yellow/brown) 6 to Pin 50 /K-CAN2_H (yellow/red) For seat before July 2013: 5 to Pin 51/ K-CAN_ L (green) 6 to Pin 52/ K-CAN_H (orange/green) |
03-28-2023, 01:38 PM | #98 |
Rep 271
Thanks Dave.
It has to be the seat module on the seat that is the deciding factor of which Kcan to use then as I my car is 0313. The F80 seats are 2016. I used k-can on pin 51 and 52 but the module doesnt show up. Everything works on both seats other than drivers heated element and the memory. Im going to try it on kcan next. Hopefully that will sort it. |
03-28-2023, 03:37 PM | #99 | |
Rep 817
Drives: bmw M3 F80
check if you have not reversed pin 5 and 6 |
03-29-2023, 06:30 AM | #100 |
Rep 271
Ha ha. No, fortunately I haven't done that. If I had done I might have to resign from my career in Civil Gas Turbine manufacture. Wouldn't want to fly again, that's for sure. :-)
10-21-2023, 09:01 AM | #102 |
Rep 3
Hey david51
I just bought a full leather electric interior for my bmw f31 2015. I saw your post from some years ago, but I couldn’t see the pictures you posted. Do you think you can help retrofit this interior? Right now I got heated fabric seats, with manual adjustments. Sincerely Frederic |
10-23-2023, 03:46 AM | #103 | |
Rep 817
Drives: bmw M3 F80
No problem PM sent |
10-25-2023, 03:25 PM | #105 | |
Rep 1
10-29-2023, 06:50 AM | #106 | |
Rep 817
Drives: bmw M3 F80
11-03-2023, 03:33 PM | #107 |
Rep 4
Hello hope some one can help me I have some M2 f87 seat that I am useing as a sim racing seat I have put 12v dc to pins 15+ and 16- and 12v to pin 1 all works fine but it stops work after about 1 min if I unplug then for a bit then plug in it starts working again for a bit then stops. Can someone please help 😢
11-03-2023, 04:32 PM | #108 |
Rep 648
Drives: 2018 F48 X1 xDrive 18D
Did you read out any errors?
11-03-2023, 05:31 PM | #110 | |
Rep 817
Drives: bmw M3 F80
