04-22-2017, 01:57 PM | #155 |
Rep 4
04-22-2017, 02:31 PM | #156 |
Rep 8,364
04-23-2017, 02:31 PM | #159 |
Rep 4
04-23-2017, 03:11 PM | #160 | |
Rep 8,364
There is actual procedure run using one of the following:
fe7565552.50 |
04-29-2017, 02:00 PM | #161 |
American European Motorsports
30
Rep 65
Coded SAT
I managed to VO 2TB today with no issues. Thanks for all the help on this thread and others for showing the easy way to do it. Works great!
KGB_123_99403.50 |
05-13-2017, 11:38 AM | #162 |
Rep 4
Follow up to my original post. I'm 1 month into the dealer recode and my shifting problem has not returned. Looks like my transmission coding to add SAT/Sport+, was causing the strange shifting behavior. It was either the error from the car thinking I had paddles or something else related to coding SAT. Will probably shy away from trying the SAT on my 320i again, not sure it gave me enough bang for the buck to risk having to have the dealer recode the car again. They probably won't do it for free next time.
05-14-2017, 12:56 PM | #163 | |
New BMW owner
139
Rep 621
Drives: BMW 316d, BMW F40 116d
Non of them had any issue with it. Maybe you just had bad luck? |
05-20-2017, 10:07 PM | #164 |
Rep 6
Consensus on coding for SAT
So is there any consensus on what actually needs to be coded for SAT and what does not, or what the best approach is?
Moreover is there a way to do this without risking throwing error codes? I have a 2014 328i (build 7/13) luxury line with NBT idrive. No paddles, no m wheel, no leather shifter. No sport+ mode. But it DOES show S1-S8 when shifter to the left. What would be the most effective way to code 2TB without getting carried away changing a buncha stuff unnecessarily? Moreover, considering I'm not adding the leather shifter or paddles, will I get error codes from it looking for the shifter and paddles? I do not want to show up or my 30k service with a buncha error codes. I'm only seeking sport+ and improved shifts, no launch control. Any feedback appreciated... an accurate, conservative list of the necessary codes would be golden. |
///CSL13.00 |
05-23-2017, 08:37 AM | #166 |
Rep 2,653
Would be so nice if we can get clear, step-by-step instructions with pics via E-SYS on how to do this properly without changing unnecessary items.
EDIT - Am I the only one who has absolutely no idea on what to do when someone says "VO Code EGS, ICM and KOMBI"? What EXACTLY do you do here? |
06-04-2017, 10:12 PM | #167 |
30
Rep 65
Start here learn first and then try something like this.
http://f30.bimmerpost.com/forums/sho...d.php?t=696777 |
06-04-2017, 10:14 PM | #168 |
30
Rep 65
The easiest way is to replace 205 with 2TB and then push to the 3 Modules that need the new code. That's all, your simply rewriting the vin to make the ECU think it has the SAT 2TB option you then have to code the individual modules to support the change I.e. The dash screen options and so on.
07-09-2017, 07:43 AM | #169 |
Rep 25
Tried to add launch controle to an 205 transmission.
Sport + menu was enabled stock 1st time I checked and changed the FDL coding, no result. Never did FA coding but followed the tutorial and changed 205 tot 2TB. When VO coding e-sys gave me an error: "vcm update is deactivated" Is VCM needed for this? |
12-12-2017, 06:57 PM | #170 |
Rep 5,457
Drives: F30
Can you do any transmission coding with BimmerCode?
12-21-2017, 12:42 AM | #172 |
Rep 1
Hi,
I have a 2016 F36 318d, i coded SAT but i don't feel a real difference in shifting, what is the best way to check ik? I change 205 to 2TB in the FA, and VO code EGS, ICM, and KOMBI. Thakn you |
12-27-2017, 09:43 AM | #173 |
Rep 2
Please help guys! I successfully added The 2tb option But i don’t have dynamic drive buttons and i get error Because of that. After i coded back 205 the error disapeared. Please help! Can i code 2tb without dynamic drive buttons ? Thx
01-20-2018, 01:12 PM | #174 |
Rep 5
Hi at all, today I retrofitted at my F31 (335d xdrive) the shifter paddles at the steering wheel.
After installation of the paddles I change vo (delete 205 and add 2TB). In next step I code the Kombi and ICM but if I try to code the EGS I get an error message. EGS [18] cdDeploy FinishedWithError cafd_0000023f-016_016_035 FinishedWithError Does anybody know what could be the root cause of this problem? Until now the shift paddles doesn't work. |
01-21-2018, 06:59 AM | #176 |
Rep 5
