07-11-2015, 07:56 AM | #45 | |
Rep 2,013
http://www.bimmer-tech.net/shop/bmw-...tech-smartview |
07-13-2015, 06:06 PM | #46 |
Rep 389
Finally have my smartview
Hello guys
I finally got my rear view cam and smartview device from customs and installed it phew Just wanted to confirm very happy with the results and tested a few scenarios You can watch you phone or tablet screen while listening to the in car entertainment source. Then if you like you can switch to the aux and listen to the audio coming from the phone or tablet ( you have a choice as well here you can listen to the phone / tablet audio and see any screen you like for instance your idrive nav or just watch the audio / video from the phone ) In my case I needed to connect two RCA cables from the smartview device with a hidden cable into my AUX in located in the side drawer next to the USB.still audio and video are transferred wirelessly from the phone or tablet. Also since my car has CIC and nav there was not much space in the idrive area to install the device so I ended up installing it in a space just beside the idrive access able from above the driver side kick panel. From there all the cables going to the idrive will reach with ease. All in all looks very OEM and thanks to Patryk from bimmertech and his quick answers to my questions it was a successful install. Pairing is automatic as your phone or tablet connect automatically to the smartview wifi as you enter the car and all you have to do to see your mirror is enable mirroring from the device. In my case iPhone or iPad I select airplay mirroring. And then press the number 8 button on the dash. Was able to watch moviebox , listen to music , google maps, I guess possibilities are endless. Coupled with my purchase from bimmertech of the incredible bimmertech DSP for hifi enabled cars I believe I have moved my car after 70,000 km to an awesome entertaining driving machine
07-13-2015, 07:49 PM | #48 |
Rep 389
Actually no my 3G is operational with data while it uses wifi for airplay only. Don't know how that happens though but it just worked
07-30-2015, 02:57 AM | #50 |
Rep 82
Can you stream Pandora on your phone (or any internet radio) over bluetooth to your car and mirror at the same time?
2015 /// F82 M4 AW Cloth DCT Adaptive HK 19" Black
2013 911 S PowerKit CCB Burmester Duct Tail PDK Techno 20” Black Previous: '07 BMW 335i Sdn || '07 Corvette Z51 || '01 BMW 330Ci || '01 Corvette Z06 |
07-31-2015, 05:44 PM | #51 | |
Rep 389
If want want the audio to come from aux rather than Bluetooth you will select Aux in as audio source from idrive then press the button for video mirroring. This smartview device mimics Apple TV and uses airplay. The audio in car is chosen via idrive. The smartview device is linked to the aux in. Hope I managed to explain clearly
08-01-2015, 02:41 AM | #52 |
Rep 349
Not sure what you mean by
In my case I needed to connect two RCA cables from the smartview device with a hidden cable into my AUX in located in the side drawer next to the USB.still audio and video are transferred wirelessly from the phone or tablet. Did you mean the aux in the center console of the car? |
08-01-2015, 03:29 AM | #53 | |
Rep 389
Let me know if there is still confusion and I will get some photos for you
08-01-2015, 02:28 PM | #54 | |
Rep 349
Someone from the 1 series forum was saying that he was able to attach those rcas to the audio in on the main harness. Since they are both males, connectors were probably used. Glad that BT works for you while you are mirroring. I have an android device and screen mirroring and BT streaming doesn't play well together. How do you find the quality? |
08-01-2015, 04:56 PM | #55 | |
Rep 389
I sometimes mirror my iPad while using bmw apps for my iPhone music for google maps. In my opinion wired sound will always out perform a wireless sound But then again the mirroring is wireless technology and you shouldn't expect a high audio quality out of it. It's good for movies and google maps but not music.
08-02-2015, 12:24 AM | #56 | |
Rep 349
Or is it purely streamed from USB? |
08-02-2015, 02:42 AM | #57 | |
Rep 389
The aux connection dose not have to be connected. But mind you the device that is running the app cannot do mirroring since the app has to be open. That is why I use another device like my iPad mini to get google maps with music being played from my iPhone via bmw apps.
02-05-2016, 09:24 AM | #58 |
BMW newbie
Rep 61
Installation instructions pls
Bimmertech guys (Nelson or Partryk)
Please send me the install guide. Its snowing here & Its perfect to stay indoors (garage) & finish this project today. I have the front & rear cam with the mirroring kit. Thanks in advance!
2014 F30 335i M-Sport Estoril Blue
02-08-2016, 09:02 AM | #59 |
Rep 112
I have a BMW F30 2012 model with 606 Business nav champ2 head unit, it also has front & rear PDC. I want to install a reversing camera with moving lines (when parking) as well as mirroring my iPhone onto idrive screen. http://www.bimmer-tech.net/shop/bmw-...tech-smartview is this the right one to go for and add multimedia interface + rear view camera options on the drop down list? do i need anything else?
Thank you. |
04-03-2017, 02:22 PM | #60 |
Rep 125
I have been wondering if I should retrofit this to my small non-nav CIC iDrive or invest in a NBT screen instead? I am not sure what will make more of a difference to me, to be quite honest.
