09-29-2014, 07:49 AM | #23 | |
Mmmm... Bavarian
2129
Rep 1,690
Dunlop Direzza ZII Hankook RS-3 Toyo Proxes R1R Federal 595RS-R Bridgestone RE-11A Continental Extreme Contact DW (dominant wet tire, not as good dry) BFG g-Force Rival Kumho XS The Toyo's are getting a new compound for next year with a treadwear rating of 200, so it is unknown what their performance will be next year. The Federal tire was a big surprise the last two years, but next year it also sufferes from the treadwear rule (have to be 200 an above I believe) and will not be legal for stock classes. I believe Bridgestone is planning to bring back the RE01R since the RE-11A has not been a good performer - it's a distinct second tier tire right now. There are certain cars though that the RE-11 and the Kumho XS are the only size options for though, so they have hung in there in a few spots. Hope that helps!
M2 CS
2023 CB X5 45e 2018 i3 94 2014 Cayman S |
09-29-2014, 08:39 AM | #24 | |
Rep 704
Drives: 2014 328d
2014 328d SportLine
09-29-2014, 09:39 AM | #25 |
Mmmm... Bavarian
2129
Rep 1,690
Correct. That said, comfort and durability are pretty good on most of the newer generation tires. Road noise is pretty bad on most, but frankly isn't that much worse I don't think than run-flats create to begin with.
M2 CS
09-29-2014, 01:18 PM | #26 | |
Diligentia Vis Celeritas
558
Rep 1,477
Drives: 335i
the Hankook RS-3 version 2 with the revised tread compound came out at the beginning of this year.
09-29-2014, 01:22 PM | #27 |
Mmmm... Bavarian
2129
Rep 1,690
Direct knowledge based on SCCA Nationals this year and various very competitive racers in quite a few classes.
The new RS-3 definitely performed very well. The softer sidewall (although better than previous gen) pushed it down a touch in preference against the Direzza's for some of the guys. The Toyo's have a few "magic" sizes that they are hard to beat, and they have the best lateral grip, just not as good longitudinally. Federals performed VERY well and was a big surprise to a lot of people. So the top 4 are really very close and driver skill can easily mask the variance between them. Additionally, car weight/drive/suspension filter that order as well. Surface type (concrete versus asphalt) and general temperature also mess with it. Some overheat more than others, some respond better to spraying etc. Lots of factors. That's why there really is never a specific "ONE" tire.
M2 CS
09-29-2014, 01:35 PM | #28 | ||
558
Rep 1,477
Drives: 335i
Not sure I understand why you say that a relatively weaker rear sway bar would be MORE effective at fighting weight transfer in the rear to keep the rear inside tire down (?)
09-29-2014, 01:40 PM | #29 | |
558
Rep 1,477
Drives: 335i
My interests are for the track rather than autoX, so that may change things a little though. For example, I've read that the Direzzas get very greasy after about 15 hard minutes. For that reason, I was leaning toward the Hankooks. Of course I'm also considering going with a streetable track tire like the ContiForceContacts as an alternative as well...
09-29-2014, 01:42 PM | #30 | |
Mmmm... Bavarian
2129
Rep 1,690
For the tires - there is a brand new ZII compound (star spec) that JUST came out about a month ago. So that is also being looked at and I believe the main difference is temperature profile. The old RS-3 was nearly impossible to overheat, the newer one does overheat occasionally. The Kumho XS is very heat tolerant though, but it's ultimate grip isn't keeping up anymore. Track DEFINITELY changes a few things though and I don't have strong exposure there.
M2 CS
09-29-2014, 01:49 PM | #31 | |
Mmmm... Bavarian
2129
Rep 1,690
http://www.turnfast.com/tech_handling/handling_antiroll Put another way. A roll bar is like putting a stiffer spring on JUST that axle's outside corner. More load goes there, but with less deflection, hence less roll. Less roll then also changes the weight transfer distribution to the whole car. This works up until you exceed the limit of traction developed mechanically and geometrically at that corner. THEN the reverse kicks in - you get more and more traction issues as you put more and more load in to that corner. Again, I'll try to provide some math to show it and again make sure I'm not miss stating things. In general if your rear is already loose - you put on a front bar to stabilize it, if you understeer too much, you usually put a rear bar on. However, braking traction versus acceleration traction versus mid-corner all end up requiring other variations/considerations due to how weight is re-distributed.
M2 CS
2023 CB X5 45e 2018 i3 94 2014 Cayman S Last edited by sdhotwn; 09-29-2014 at 01:56 PM.. |
09-29-2014, 02:02 PM | #33 | |
558
Rep 1,477
Drives: 335i
09-29-2014, 02:11 PM | #34 | |
Mmmm... Bavarian
2129
Rep 1,690
Additionally, on our cars you can get bad inside wheel spin (although an LSD or the eDIF may eliminate this to some extent) it can be from too much rear stiffness allowing the rear inside wheel to get pulled up. This then kills your acceleration. Those two items are why I recommend a front bar on our cars with our geonmetry.
M2 CS
09-29-2014, 02:11 PM | #35 | |
558
Rep 1,477
Drives: 335i
09-29-2014, 02:16 PM | #36 | |
Mmmm... Bavarian
2129
Rep 1,690
Z1 - Japan only Z1* - the first Direzza to the States ZII - the "new Direzza most ran this year ZII* - the new, new direzza that came out in the last month or so.
M2 CS
09-29-2014, 04:16 PM | #37 |
558
Rep 1,477
Drives: 335i
I just ordered the Direzza ZII Star Specs... Thanks for the heads up!
09-29-2014, 04:24 PM | #38 |
Mmmm... Bavarian
2129
Rep 1,690
I did also verify that the mechanisms/logic behind the sway bar info I was posting is correct. One of the guys I work with is an SAE certified suspension engineer from his previous job.
M2 CS
09-29-2014, 04:25 PM | #39 |
Mmmm... Bavarian
2129
Rep 1,690
Cool! When you going to get to try them out?
M2 CS
09-29-2014, 06:37 PM | #40 |
558
Rep 1,477
Drives: 335i
10-06-2014, 12:58 PM | #41 |
Mmmm... Bavarian
2129
Rep 1,690
So I got to autocross the car for the first time this past weekend. Was rather interesting and generally surprising to me.
I ran it completely stock - SP001 runflats, no alignment changes, nothing. I ended up winning the class for the day (not a lot of people though), but more specifically beat a guy with a prepped E46 330i ZHP that I had struggled to match previously in our prepped E90 325i. Overall, yes it understeers, but it was surprising how close to neutral you could get with some added throttle during sweepers. I fought most of the understeer off with harder braking on entry and avoiding trail braking almost entirely. I did have rear wheel spin pretty regularly as expected, but the car recovers very nicely when you pull out a little throttle. Overall I was shocked at how well the car ran in stock form on the crap stock tires. Surprising amount of potential there! I wish the guy that runs an E90 M3 had been there to compare against as he usually sets the class time, and I believe is about 1.5 seconds ahead of the guy I beat to take the win. I could easily imagine proper tires, sway, and alignment closing down that gap quickly.
M2 CS
10-06-2014, 02:02 PM | #42 | |
558
Rep 1,477
Drives: 335i
