06-18-2012, 04:20 PM | #1 |
Dejan
1753
Rep 4,197
Drives: 2018 Audi S3
Garage List 2013 BMW 335i [10.00]
2015 BMW 228i M Spo ... [0.00] 2013 Ford Focus (DD) [0.00] 2001 Alfa Romeo 156 [0.00] |
Removing Front Bumper / Fascia and License Plate Bracket
I just want to start of by saying, if you are attempting this and you damage or break something, I am in no shape or form responsible. So be careful take your time and have fun with it. If you get frustrated walk away for a while and have a beer.
The reason I did this was even though I live in a state where a front plate is not required for some reason they mounted a bracket on my fascia so I wanted to remove it. Plus this will help the future M-Sport fascia upgrade if anyone chooses to do so... Dont try to drill out the rivets, because they are not rivets! They are T-25 screws shot from the inside of the fascia, I just by chance wanted to do it the harder way and remove my fascia, plus I was curious to how its done. Tools: Really all you need is screwdrivers and ratchets, but i have a right angle Makita so I prefer that. 8mm socket and ratchet T-25 bit T-30 bit Pin Puller or pick tool Start on Top I would protect the bottom of the fascia with something, and lay some sort of tarp blanket what ever you have underneath it so you dont scratch it. Remove the weather strip from the hood/facia. PIC 2. You will see the exposed T30 on top 6 total. The 2 t25's are already visible they are located on the right and left sides there are only 2 of them. Undo all of these and place in ziplock bags for safe storage. PIC 3. Then move to the wheel well splash shield. You will need to start the car a few times and turn the wheel to create space. This is where the 8mm's are (4) note you may not need to remove the inboard 8mm but I did. Unscrew the 8mm's in the splash shield and (2) long 8mm's in the shoulder of the fascia screwed into the fender. Do this to both sides. NOTE PIC 4 shows 2 shoulder 8mm screws. Move underneath the fascia. You will see 8-8mm screws and 6 push pin style scrivets. Remove all of these. Pretty straightforward you may need a pin puller to take out the scrivet, I used a pick just pull straight down. Its almost ready to come off. But 1st there are some electrical connections to undo and the washer hose. PIC 5 shows the camera disconnected, do this on both sides if you have a camera. Both sides, Left and Right. Directly Underneath that will be your fog lamp connection undo that as well. PIC 6. Now on the Right side of the car is the washer hose connection if you have this option. Locate the little spring like device on it and push down while pulling up on the hose it will pop right off. CAUTION washer fluid will start to pour out, so immediately stow it up, I used the fender as a stow and no fluid will come out, shown in picture. Again dont forget to disconnect the camera on this side if you have it. PIC 7 Disconnect the fog lamp connections on the RH side this one has 2 connections shown in picture. You are ready to start pulling off the Fascia. PIC 8 This shows you where the plastic arrow tab is still holding the Fascia on, gently pull up on it with your finger, you may have to do it from underneath the car. Then slowly start pulling the Fascia off, DO NOT FORCE anything! Just play with it and it will come right off. Place it somewhere aside and you are ready to reove the plate bracket. Just unscrew the 6 t25 screws and it pops off. Unfortunately now there are holes, but maybe a vendor can chime in here and provide us with some painted push pins of some sort to cover the holes . Also they used 4 way locators for the bracket so there are 2 extra holes to cover up. To reassemble just follow in reverse and take your time. Good Luck, and have fun. Make sure to reconnect everything and start the car make sure your cameras work, and fog lamps work. This took me maybe an hour. I do work on cars alot, its my life. I can say that this was one of the easiest front bumpers I have ever removed. Hope this helps you guys in the future. EDIT: Added a few more photos, just for the visual. Last edited by Jadar; 06-19-2012 at 02:29 AM.. Reason: Adding INFO |
06-18-2012, 09:52 PM | #2 |
Administrator
40860
Rep 21,240
Great writeup, thanks for sharing!
Check on the Latest BMW News
Become a fan of Bimmerpost Facebook Follow us on Bimmerpost Twitter Subscribe to Bimmerpost Youtube Channel |
06-20-2012, 02:48 AM | #3 |
Rep 1,659
Drives: 2022 WRX World Rally Blue
Yes you do
If you are from Chicago. Illinois law requires you to display a front and rear plate. The section is 625 ILCS. 5/3-413.
06-20-2012, 11:35 PM | #4 | |
Dejan
1753
Rep 4,197
I work in Chicago, and I also grew up in Chicago. My car was also purchased by my Indiana dealer from Germany, I'm not sure why the put the bracket on this particular car because all other brand new cars at this dealer did not have the brackets pre installed.
FBO-PS1 and stuff
06-20-2012, 11:58 PM | #5 |
Rep 1,879
Drives: 2012 F30 328i
lol they have a law for that here in HI as well but I do see lots of people who simply do not care about it
Note: Many PM me for links to the software needed to code. Please note that I do not have download links to this software. Your best bet is using the search function in the coding thread |
06-21-2012, 10:16 AM | #6 |
Dejan
1753
Rep 4,197
Yep, I see alot of people in Illinois runnin only the rear plate. I mean in all honesty if I lived in Illinois I would def run a front plate, its just not worth the hassle by the cops.
FBO-PS1 and stuff
06-21-2012, 03:48 PM | #7 |
Rep 497
Required here in Ohio too, but I've never installed a front plate on any car I have ever owned since my very first car 17 years ago. I've never been pulled over for it, and it was never mentioned the handful of times I have been pulled over for other reasons. Same with window tinting- the law is 50%, but I have had 20% on every car with no questions. I will continue to take the risk until I actually get a ticket.
killit9.00 |
06-21-2012, 03:52 PM | #8 |
Rep 1,879
That's a bit how I feel about it. I know people who don't have front plates here and never get into trouble with the cops but I just know I would get into trouble... I don't know why but I just attract that I guess
06-22-2012, 02:27 PM | #9 |
Dejan
1753
Rep 4,197
I hang out downtown alot, I know Id get a ticket, they dont play there. One minute late on the meeter and youre getting a fine! Thats mainly why If I lived there id just follw the rule cuz it be too much trouble.
FBO-PS1 and stuff
06-22-2012, 03:56 PM | #10 |
Rep 1,879
That's probably what's my problem. I often visit certain areas such as Waikiki, or the airport, and those places are crawled with cops xD
06-22-2012, 04:07 PM | #11 |
Dejan
1753
Rep 4,197
Yeah but urban life gets boring so fast whats the point if you cant take a nice ride in your nice car....ya know.
FBO-PS1 and stuff
06-23-2012, 02:24 AM | #12 | |
Rep 1,879
Now, not so much lol.. I have covered pretty much every inch of the island and all you can really do here is just drive around the island. It's a nice drive, I have to agree when someone say that, but to be honest, it does get a bit boring sometimes
06-23-2012, 02:37 AM | #13 |
Dinosaur supervisor
3030
Rep 4,214
You deserve a smack in the face for complaining about living on Hawaii!
06-23-2012, 02:56 AM | #14 |
Rep 1,879
Haha nah, don't get me wrong, it's really great living here, but the grass is always greener at the other side. When I'm in Europe I miss Hawaii, when I'm in Hawaii I miss Europe lol
06-27-2012, 02:04 PM | #16 |
Dejan
1753
Rep 4,197
8 stupid holes! I figured I take it off otherwise all that work was for nothing.
FBO-PS1 and stuff
07-16-2012, 08:17 PM | #17 |
Rep 882
Drives: 2013 ///M3 E92 DCT ZCP
Done and it looks 100% better, I installed the m performance grilles as well. I wanna thank you for taking the initiative and posting all the steps. The inner shoulder long 8mm was the hardest to take off.
Did you find any solution to the holes left in the front bumper. My car is black and the holes r hard.to notice but I was just wondering.
07-16-2012, 09:11 PM | #18 | |
Dejan
1753
Rep 4,197
As far as for the holes, I had leftover black saphire touch up form my e90. I found the smallest possible push pins and was able to prime and paint them. You can buy these from a few vendors on here already painted, but I just did my own. No chipping or peeling issues. Im still not 100% happy with the way it looks, I may take it to a shop and get them filled. This is what it looks like with the pins installed. It would have been ok if it was 4 holes like they do on the e90 but some genius got the idea to secure it with 6 screws and on top of that use 4 way locators as if the screws werent enough. I wanna beat the guy that did it!
FBO-PS1 and stuff
07-29-2012, 10:04 AM | #20 | |
Rep 580
*NO LONGER ON ORDER* '12 328i Mineral Grey Metallic w/black leather/aluminum&black gloss trim/ZSL/ZPP/Xenons |
10-18-2012, 01:33 PM | #21 |
Rep 286
Live in New England area and all of the states require it, but I think of them more as guidelines, I mean the cops are only going to see the back of the car anyways
'12 335i Sport Apline White w/black... Totaled
'14 535i xdrive M-Sport Carbon Black w/Mocha Nappa |
10-18-2012, 02:42 PM | #22 |
Rep 1,659
