BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > First F30 Limp Mode
      01-08-2013, 12:51 PM   #45
snowghost
snowghost's Avatar
Drives: '13 335i M-Sport 6MT
Originally Posted by ES_TRADER View Post
It might be logged in the ecu already, not sure if it goes in shadow memory but too many drive cycles can clear it. Personally I'm waiting for it to happen consistently before I let them take a swing at my new car. Rather not go in if I don't have to. I've driven the car about 10 times or so since the last fan incident and nothing yet. I wonder if it was a software glitch and maybe reset itself.
It happened to me this morning and one other time a couple months ago. I only have 1400 miles. There was no loud fan noise, but it felt weak accelerating in 2nd and didn't want to go above 3k RPM or so.
Nothing listed in the car's status menu. But wondering if I should take it in anyway as I'm taking a long trip this weekend and don't want this to occur on the highway.
Edit: decided to make an appt. for tomorrow and see if anything was logged.
      01-09-2013, 04:13 PM   #46
snowghost
snowghost's Avatar
Aux Cooling Fan
So I drop the car off today and explain to the SA about the fan perhaps being the culprit. She says she's not heard of this issue and asks another SA about it. He says the same.
I had mentioned it's a "known issue" on the Forums, whereupon she snidely tells me the Forums are a dangerous place.
Well, I just got a call from her and they are ordering a new auxiliary cooling fan as that's what kicked me into Limp Mode. Hmmm, dangerous???
F30 Sapphire Black M-Sport 335i 6MT
      01-09-2013, 06:07 PM   #47
TheObviousChild
TheObviousChild's Avatar
323
Drives: '23 M3 Comp xDrive - '21 X3M40
So how did they diagnose it? I mentioned it on my ticket and they said nothing was logged, no faults found on short test, etc.
Current: 2023 G80 ///M3 Competition xDrive in Atlantis / 2021 X3 M40
Previous: 2020 M340 / 2017 X3 / 2016 340xi / 2013 335xi / 2011 X3 / 2010 328i / 2007 328i / 2004 325i
      01-09-2013, 07:19 PM   #48
snowghost
snowghost's Avatar
It must have logged something on the ECU. I can verify when I pick it up tomorrow.
      01-12-2013, 02:51 AM   #49
steveL77
Drives: 2013 335i M-Sport
This limp mode happened to me for the first time tonight....car wouldn't rev over 3k rpm and when I stopped had the loud fan noise. I just hit 1000 on the odo. My car is also a 335i msport. Had no error message on the dash or idrive. Happens again and I guess I'll bring it in.
      01-12-2013, 03:15 AM   #50
nsquared
[Versatile]
nsquared's Avatar
378
Drives: (S)LOW.
Same problem. My radiator fan was out.
'02 TS E46 330xi - SOLD
'06 SGM E90 325i - SOLD
'13 AW F30 335i ///M-Sport 6MT. OEM(+) - SOLD
'20 AW F87 X3MC - Sold
Current: `23 Chalk G80 M3CX | Ordered: '24 M3CS - Week37 build.
      01-12-2013, 09:54 AM   #51
shivaswrath
shivaswrath's Avatar
Drives: 2012 335i
are these all 335i with M Sport line?
SOLD: 2012 335i Mineral Gray
      01-12-2013, 11:41 AM   #52
BimmerBrova
BimmerBrova's Avatar
Drives: F30 M Sport
I have also experienced this issue similarly. I have an August 2012 build 335 m Sport.
The first appearance was a little over a month and a half ago with the loss of power issue. Was on a highway on ramp when it happened, so it kind of put me in danger since i could barely get it up to highway speed. I pulled off at the next exit, checked the vehicle status in the iDrive menu, and noticed how high the fan in the engine area seemed to be running so shut the car off. After a minute it calmed down, so i tried to turn it back on, and it acted like nothing ever happened. There was no check control shown during or after this happened, but it hasnt felt the same since. Pretty much exactly how Cfichman's video depicts:
. I didnt feel any steering wheel vibration as ybbiz34 pointed out though. I did let my SA know about this, but I didnt make much effort to bring it in because as justinnum1 said, i have also found that unless you can bring it in with the problem, its likely a waste of time.
The loss of power happened to me again about 2 weeks ago in a different way, still going on an onramp again though, except this time it didnt really go into "limp mode", it just felt like it had less HP available or something. I didnt hear the loud fan or anything like before, but it was like this little Mazda 3 just zipped around me like my acceleration was weak (not cool). I brought in after that, additionally because I have also been noticing that she just seems to pegging 160 line for the oil temp, even after 15 to 20 miles on the highway. Heat doesnt really blow out the whole time either, even though its on max 84. Sometimes it does get to a little over 200, but that will be after alot of stop and go at traffic lights. I was hoping there would be some codes stored somewhere outside of the vehicle status view we have access to, but unfortunately they couldnt find anything wrong.
Now yesterday while driving home i noticed the Check Engine Light come on. Im like WTF, already?? No power loss or anything like that, just cruising, temp pegged at 160, kind of freezing my behind off on the way home, and this happens. But this could be a good thing because I pulled off and took it to autozone and had it scanned. They found a P0128 code, which apparently points to cooling/thermostat/fan/temperature sensor issues, so same suspected areas everyone has been pointing to. I havent driven it since it happened, but the light is staying on when turning the car on and off, so im going to bring it in again with this proof, and hope to start getting some traction on solving this problem.
      01-13-2013, 12:50 AM   #53
ES_TRADER
Drives: 328i, 335i, M3, 535i, X5, 36M
2014 Ford Raptor  [0.00]
2012 328i E92  [10.00]
2013 X5  [0.00]
2013 335i F30  [8.00]
1990 Toyota Previa  [0.00]
1997 E36 M3  [10.00]
2011 E92 M3  [0.00]
2011 535i  [0.00]
Most, yes
      01-13-2013, 12:53 AM   #54
ES_TRADER
2013 X5  [0.00]
1997 E36 M3  [10.00]
2011 E92 M3  [0.00]
2011 535i  [0.00]
Just as I suspected. Oil temp pegged to 160 after driving for a long while. Thermostat and or fan issue
      01-13-2013, 01:23 AM   #55
nsquared
[Versatile]
nsquared's Avatar
378
Drives: (S)LOW.
Most I believe.
      01-13-2013, 08:42 PM   #56
DarkTrigger
Professional
DarkTrigger's Avatar
Drives: 335i MPPK
My car just doesn't feel the same after that limp mode incident. It feels generally weaker now. Going to bring it in tomorrow for a checkup. I'll let you know how it goes.
      01-13-2013, 08:46 PM   #57
nsquared
[Versatile]
nsquared's Avatar
378
Drives: (S)LOW.
Keep us posted.
      01-14-2013, 10:27 AM   #58
BimmerBrova
Drives: F30 M Sport
One last observation around this....and im not sure if it could just be a precursor to loss of power or what, but I did a bunch of highway driving the last two days to see if I could observe anything since they couldnt work on it until today earliest anyway, and I did notice some strange behavior and wonder if anyone else has, or is willing to try this expiriment. I noticed that if I drive the car with no air on at all, it actually seems to warm up the engine properly. At about 45 degrees outside, and after about 3 or 4 miles, the oil temperature gauge started to move off of 160. After about 10 miles it was at 205 (the halfway to middle point). Then after several more miles until the end of a 50 mile drive it consistently stayed between the 220 and 235 marks.
I then did a second run with the air on (heat, 84 driver and pass), where the oil temp gauge started at 205 (shut it off for 10 min in between). The heat was actually working as i pulled off, nice and warm....but then the strange part was that after about 10 miles, the temp gauge was at 190, and the heat wasnt coming out as warm. Then after about 25 miles the gauge was at 175, and the air was coming out slightly chilly! Its like the engine temp was being robbed by the internal air. It stayed at 175 until the end of the 50 mile drive, and the air never rose above that chillness again. The kicker is that at the end when i was on the streets to go home, if I was at a stop light idling long enough, the heat would start to show signs of life intermittently even though the oil guage still never budged. Go figure.
      01-16-2013, 03:40 AM   #59
NordicBob
NordicBob's Avatar
Drives: '16 M4 Sapphire Black metallic
Originally Posted by NordicBob View Post
I brought our M Sport 335 to the shop today for the same issue. No power loss but a low reading temp guage. The service writer did mention a secondary fan on the M Sport 335, but said that the problem could be caused by a number of issues. I have our car scheduled to be checked out next week at our dealer and will report back then. However, we have had no issues since the one isolated incident.
Bob
UPDATE: Our car was brought to our local BMW dealer today to check out our problem. They are keeping it overnight. It has performed flawlessly since I originally posted my problem. Our car now has 1278 miles on it now.
I will post what our dealer finds, if anything, once we get our car back.
BTW, I am new to this forum but not new to BMW. I really appreciate forums such as these to learn and share our experiences about "The Ultimate Driving Machine."
Bob
335i M Sport to M4
      01-16-2013, 10:12 AM   #60
ES_TRADER
2013 X5  [0.00]
1997 E36 M3  [10.00]
2011 E92 M3  [0.00]
2011 535i  [0.00]
subscribed. lets keep this thread as the main one. i know there are a few out there but everyone please update their dealer findings here.
      01-16-2013, 11:25 AM   #61
DarkTrigger
Professional
Drives: 335i MPPK
This is the third day it's been in the shop. I'm starting to get a little worried now... Hope I can update soon.
When I brought it in, I went on a drive with the shop forman and he said they would run some fan diagnostics and it's been a common problem among the new 3 series.
Also, on an unrelated issue. He said someone had come in with a bad rust problem under the passenger seat too. I don't know what they plan to do about it though.
      01-16-2013, 11:51 AM   #62
snowghost
snowghost's Avatar
Guys contact BMW North America in New Jersey. In my case I was so pissed I emailed BMW Munich, who replied very quickly that the matter would be referred and politely asked that I be patient.
BMWNA has contacted me twice since then, the first time to tell me the seat pans have been ordered. The second time to see if they were installed. They have not arrived yet. I will post the results when they are replaced.
      01-16-2013, 12:21 PM   #63
ES_TRADER
2013 X5  [0.00]
1997 E36 M3  [10.00]
2011 E92 M3  [0.00]
2011 535i  [0.00]
which dealer is this?
      01-16-2013, 12:26 PM   #64
DarkTrigger
Professional
Drives: 335i MPPK
Long Beach BMW. They are replacing the rusted seat pans though.
They are still working on the aux cooling fan issue.
      01-16-2013, 01:03 PM   #65
kobechrome
kobechrome's Avatar
Drives: 2013 F30 335xi
Is this limp problem happening with only 335 M sports or are other lines/makes experiencing it also?
      01-16-2013, 01:30 PM   #66
snowghost
snowghost's Avatar
AFAIK it's only on the M-Sport due to different cooling configuration. After the fix I took a trip to AZ and she felt just fine. Nice pulling in 6th gear and climbing over the mountains.
It was fairly chilly (37F-40F) with the oil temp just under 250 the whole way.
