05-13-2013, 07:43 PM | #1 |
Rep 68
M performance Carbon Fibre Shift knob auto
Heres a pic of a before and after. If you need help with a DIY just let me know is pretty simple once you figure out what to do.
BMW M perf. gloss black kidney grills, BMW M perf. Carbon f mirror caps, Superbright led front turn signal white plasma projector, Weather tech digital mats front back and trunk, BMW rear entertainment system, 7000k white 18 smd led foot area,M perf. carbon f shift knob, Front lip carbon f, HID fog lights 6000k h8, front and back reflectors to match ,Pair of carbon f side grills, License plate carbon f. cover and error free smd lighting.
05-13-2013, 08:12 PM | #2 |
Rep 1
05-14-2013, 01:33 AM | #3 |
Rep 68
Bmw dealership. But i seen them online ranging from $180 to $260 plus whatever shipping will cost you.
05-15-2013, 01:17 PM | #6 |
Rep 79
yes i have the same shift knob on mine and it's "raw" carbon fiber... in other words they didn't put a layer of clear coat or whatever they use on the external CF parts to protect it from the elements... the same can be said for the M-perf interior trim.
05-22-2013, 01:36 AM | #8 |
Rep 68
To start first take the middle black piece (where R, N, D, - +, M/S is located ) thing off with a really small screw or something pointy like the one in the pic from the side. Is glue stick on theres no bolt or screw holding it doesnt matter which side theres a slight little gap all around it. Ignore the P button just chilling there for now. I will get to that later.
05-22-2013, 01:45 AM | #9 |
Rep 68
When the middle black piece is removed youll be left with the first picture. It is a very tiny screw with 6 stars if thats what you want to call it. That is what holds most of the knob together. After that screw is removed you will get second picture take it out completely but remember the middle whole you took out the screw from from the frame because when you put it back it has to go back on the same spot. The P button comes out off automatically after this screw is taking off. As you can see i cracked it from the sides a little and i scratch the bottom, because at the beginning i was trying to force it out because i didnt think there was a screw holding until later that i discovered the middle black piece came out and underneath was the screw. Make sure you take out the screw and the rest will be a breeze no need to force it. Don't make my mistake, you can potentially sell that part or put it back for next owner if carbon is not there style.
05-22-2013, 01:48 AM | #10 | |
Rep 10
05-22-2013, 01:54 AM | #11 |
Rep 68
After that install the M performance carbon fibre knob making sure is align properly with the Parking button as well then put the screw back in the middle hole so it holds it together. After that, peel off the tape from the Middle black m performance part and then put it in the middle and then bombazo you are done. Pretty much putting it back the same way you took it out. Make sure you are very careful with the unlock button on the side it has two tiny little clip on legs(top and bottom of it) that break off easy... i unfortunately broke one of mine when i was trying to force it at the beginning and now the top dents a little in, and i believe its just the bottom leg clip on holding it. It gets annoying so just be careful with that.
05-22-2013, 01:57 AM | #12 |
Rep 68
Hope that clarify it a bit.
1. No clue why my pics always come out sideways. 2. Any other questions just let me know.
05-22-2013, 02:12 AM | #13 |
Rep 68
Youll be rolling with this now. Now just admire those 5 min of your hard work lol ... Initially 40 min but with a DIY should be 5 10
06-03-2013, 11:54 AM | #14 |
Rep 664
Drives: 2013 BMW 335i
hey can you post more pictures of your car. I like what i see in your sig... What to see the headlights... can i get a link to the projector bulb? and pics of the led foot area.
06-18-2013, 01:53 AM | #16 | ||
Rep 68
06-18-2013, 01:47 PM | #17 |
Rep 195
06-18-2013, 02:06 PM | #18 |
*Bimmerpost Plasti Dip Guru*
82
Rep 1,174
Drives: E53, E46-M3, E70, F25-X3
Im curious, so the black transparent plastic is held together by Glue?
is it the same as the non sport shifter? Thanks!
06-19-2013, 10:29 AM | #19 | |
Rep 68
08-14-2013, 10:56 PM | #22 |
Rep 68
No its not i tried already with the loaner i had... it is not the same if someone can show how to do it yourself without the sport shifter would be great
