09-02-2022, 05:19 AM | #1 |
Rep 2
BMW F32 glove box light wont work
I bought a used BMW F32 coupe recently and everything functons fine except for the glovebox light. I thought it was out so I changed it but still nothing, even with the ignition on. Perhaps one of the fuses? Would anyone happen to know what fuse it might be?
09-02-2022, 05:27 AM | #2 |
¯\_(ツ)_/¯
945
Rep 1,762
I would check every one related to lighting. I can't find the F32 diagram but a quick search shows it's the same as an F30 from what I saw.
I would check; 20, 28, 40, 42, 53, 57, 100, 153, 161 20/28/42/53/153 look like the right ones that would affect the glovebox light. Do your footwell lights turn on? If the fuses are good I would check the voltage at the connector to see if the light is getting juice.
09-06-2022, 06:44 AM | #3 |
Rep 2
Thank you Solidjake I'll check the fuses later this week, last time I checked most of those they were fine but I was missing one 5 amp fuse from spot 153 if I remember. And I think its supposed to have one.
