BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N20, N26, B46, B48 Turbo Engine / Drivetrain / Exhaust Modifications > F30 328i Drivetrain Malfunction
Studio RSR
      08-30-2020, 04:33 PM   #1
NyquilusDilwad
NyquilusDilwad's Avatar
Drives: 2016 328i xDrive M-Sport
Looking for some advice on how I can fix a drivetrain malfunction issue on my 2016 328i. Only has 57k miles on it, the message first popped up about a month ago, I restarted the car and it went away, and then it showed up again last night as I was accelerating on the highway. I drove home slowly but nothing really felt weird about the car.
Drove the car again today everything seems to work normally no shaking or anything like that and the message went away again
I checked for codes today and found Error code 120308 - charging pressure control, plausibility too low. That is the only one there.
Recently changed out my spark plugs about 2 months ago, didn't change the coil packs though. Only mods I have on now are a muffler delete, which was done over a year ago, Injen intake, and BM3 stage 1.
I checked out the charge pipe and it seems to be intact, I also just did a datalog and boost pressure maxed out at 20.9psi, I can run other tests if that would be helpful.
I have a new charge pipe, intercooler, and downpipe that I was just about to install but now I want to figure out what this issue is before I go stage 2.
Any advice would be appreciated, I'm really trying to avoid taking it to the dealership if this is something I can fix myself.
      08-30-2020, 06:22 PM   #2
Chihuahua
Chihuahua's Avatar
4076
Drives: E30 329iS, E65 Alpina B7
Did your car go into reduced power mode?
      08-30-2020, 06:27 PM   #3
NyquilusDilwad
It had the drivetrain malfunction maximum output not available message on the idrive but it still seemed to drive normally, I didnt try to get on the gas heavy after that though.
      08-30-2020, 09:14 PM   #4
Luverse
Luverse's Avatar
Indonesia
179
Drives: BMW F30
read this
https://static.nhtsa.gov/odi/tsbs/20...41407-5981.pdf
https://bmwfault.codes/XMLDiagView?d...w%20A2ADAANAA=
Instagram: nightfall.f30
328i, bmw, charging pressure, drivetrain malfucntion, error code, f30
