BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N55 Turbo Engine / Drivetrain / Exhaust Modifications > Burger Stage 1 N55 installed!!!
      02-06-2013, 03:17 PM   #23
stom_m3
Drives: Sequoia
Originally Posted by tdizzle View Post
But you said you weren't really trying to get the best times so that and the probably inaccuracy of the app is probably why the times seem slow (especially the first time without the tune). Good display in showing the pretty huge difference with and without though. ALthough, I dont think we should expect to get a 1 second difference 0-60 while giving it maximum effort in both cases (the car would be putting down 4 second flat 0-60s or less)
Completely agree. I only did 1 run with and without. I wasn't trying all that hard to have optimal shifts, though it's an automatic tranny. But I still wasn't consistent on shift points. In the end, it's the ease of the difference as opposed to the raw time itself. I wouldn't doubt if the car was a 4.5 - 4.7s, 0-60 car post stage 1 add.
      02-06-2013, 05:35 PM   #24
Seagull
Seagull's Avatar
Drives: F87 M2, E84 X1
What do you think your gut feel on the distribution would be if you tried more times?
1s +/- 0.35s?
BTW, I like this thread as it is more real world than the typical drag time that can be posted.
Current: F87 M2 MT MPE, E84 PP SP LP
Previous: F30 - 335i AT, E90 - 335xi MT, E90 - 330i MT, E46 - 330i MT
      02-07-2013, 09:50 AM   #25
tdizzle
Drives: 2017 F80 ZCP
1s +/- 0.35s?
My "guess", would be about .3 seconds off your 0-60.
      02-07-2013, 10:45 AM   #26
nsquared
[Versatile]
nsquared's Avatar
378
Drives: (S)LOW.
the 335i needs to be a 10 second car.
'02 TS E46 330xi - SOLD
'06 SGM E90 325i - SOLD
'13 AW F30 335i ///M-Sport 6MT. OEM(+) - SOLD
'20 AW F87 X3MC - Sold
Current: `23 Chalk G80 M3CX | Ordered: '24 M3CS - Week37 build.
      02-09-2013, 01:53 PM   #27
inChargeOfIT
Drives: 2013 335i Sport
I got my stage 1 today (2 days after I ordered it!) and it literally took less than 5 minutes to install it on my 13' f30 335i sport. This is the best video instructions I have found:
      02-28-2013, 08:19 AM   #28
spideypm
Drives: 2013' 335i M Sport
Testing with JB stage 1
Finally return my car to stock mode and was able to do some baseline testing. Got 0-60 in 5.5 in stock and 5.2 with JB. I thought BMW claims that 5.2 can be achieved with stock car and most magazines are testing to be around 5 seconds? I would expect at least 5 sec with JB. Did my car just happen to be slow?
      02-28-2013, 08:20 AM   #29
spideypm
By the way I did throttle break at around 2k rpm.
      02-28-2013, 08:53 AM   #30
shivaswrath
shivaswrath's Avatar
Drives: 2012 335i
Traction/tire pressure can heavily impact this. Don't be to disappointed, you gained .3 seconds on a street car for <$400!
SOLD: 2012 335i Mineral Gray
      02-28-2013, 10:01 AM   #31
tdizzle
I'm assuming this is auto? Did you spin the wheels at all?
It does seem slow. Wonder if the calibration is off or if your car is 'gasp' slow?! I'd expect high 4s fairly easily achievable with stage 1. A good driver with summer tires should actually be able to get 4.8-5.0 in stock form.
I would expect to run about 4.7ish with the tune. There are alot of factors to consider though. Did you happen to dyno it? I think it should be putting down 300 hp to the wheels and around 315ish tq.
      02-28-2013, 10:13 AM   #32
sydande
Drives: F30 335i
just a quick question, could u switch maps on the fly with jb4 stage 1?or do u need stage 2 for that? thanks
      02-28-2013, 11:21 AM   #33
tdizzle
I know for sure you can do it in stage 2, but for the F30 they don't have the in dash stuff available yet. Really not sure for stage 1. I'm guessing no, but I'd ask someone who has it to one of the JB4 guys. The other forum could probably get your answer the quickest.
Edit went and looked myself, straight from Terry:
"Stage1 is a single map, +3.5psi."
      03-01-2013, 08:54 AM   #34
spideypm
Yes it's an 8-speed. Throttle brake to 2k rpm. I never dyno the car and i wonder if the power mode on P-Box will tell me something. Unfortunately i suspect that my car is just a slow one of the batch......
Next up I will put back the Challenge HFC downpipe and run another test...
      03-01-2013, 08:56 AM   #35
NICKTENN
NICKTENN's Avatar
Drives: 340i M Sport
I'm interested to see what effect the HFC has on your time. We appreciate your efforts!
2016 340i M Sport Alpine White, BMS Intake, JB4 Beta
2012 335i Sport Line, RIP
      03-03-2013, 04:42 PM   #36
tdizzle
Jb4 and Challenge HFC DP is the two mods i was thinking about. I'd be interested in seeing the gains you get from the DP than just the JB4 alone (and if you have any issues with CELs for that matter)
      03-04-2013, 03:40 AM   #37
spideypm
I've tried it before I took the DP off. I didn't get to measure the 0-60 time. The numbers I had told me that DP made quite a bit of difference on 60-160 time(more than JB). However, after I put on JB, it didn't improve my 60-160 time. This time I will measure the 0-60 time. Talked to Terry, he emailed over the updated firmware for the JB. Perhaps it makes a difference now. I should be able to make the switch some time this week. In the part of the world where I live, people are more interested in 60-160 time than 0-60 time.
One thing I should point out about the HFC DP is that the CEL did not come on for me for the 3000 miles or so that I had it on my car. However, when I plugged in the computer to scan for error code, one error code did come back regarding the catalytic converter. I don't know if it would be an issue getting the car serviced.
      03-04-2013, 09:01 AM   #38
tdizzle
Was there a reason you took off the DP?
      03-04-2013, 09:16 AM   #39
spideypm
Just felt like I should do a baseline test so I can understand better what each mod was doing to my car.
      03-04-2013, 09:21 AM   #40
spideypm
Came across this thing called TMC Tuning Box... A new friend threw it at me and I gave it a try... It is said to have 9 maps?? Apparently the map 9 supports an aftermarket downpipe.... Wasn't expecting much but did a test run... Launch at around 2K rpm again and got 5-sec flat.... best time I've gotten so far.... about 0.2 sec faster than my JB stage 1. I'm excited about upgrading to JB stage 2 but for now the TMC is staying under my hood.... at least until after I have another run with the Challenge HFC DP!
      03-04-2013, 02:44 PM   #41
Jeff_in_Oviedo
Delivered!
Jeff_in_Oviedo's Avatar
Drives: '13 F30 335 M Sport
Just got my F30 N55 stage 1 today...now if only I had the car to install it on! Another ~4 weeks to go...
Delivered!: 2013 F30 335i M Sport, 8-speed Sport Trans, Estoril Blue/Coral Red, 403M, Premium Pkg, Dynamic Handling Pkg, Driver Assist Pkg, HK Sound, Enhanced BT & USB
      03-04-2013, 03:35 PM   #42
tdizzle
Nice, pretty impressive. Never heard of it, now you have me wanting to check it out. I still think your stage 1 JB4 should put you under 5 seconds!
I forget if I asked already, but are you getting any wheelspin with 2k RPM launches? May be worth it to launch at about 2.25k or 2.5k if you're not. Granted if you're running the stock all seaons the car may not hook up as well as decent summer tires, but I think the best launch should get a bit of squeel but not total spinning.
Edit:
Just looked them up, they're claiming a 76hp increase! That seems really high. I'm wondering if they're running a safe boost for that gain. I dont know if anyone has used them or has dynos/boost info on it so I'd be hesitant on it. I think the JB4 is closer to +30 hp to the wheels, so 76 hp is really high. That's like a DP+ Tune.
Also found a thread that touches on it from last year:
http://www.f30post.com/forums/showthread.php?t=688854
      03-04-2013, 09:21 PM   #43
4DRS55
Drives: GTF80,718GT4,TVG80,G05X5
is there any way the dealer can see if you have the tune even if u get the bms cable?
I was told that some how bmw can see there was a tune even if you have the bms cable and deleted codes. I spent extra $$$$$ on extended warranty and did not want to avoid anything.
      03-05-2013, 09:30 AM   #44
tdizzle
Only way they could tell (that I can think of) is: 1) You left it on and they just happened to open up where you 'hid' it or 2) they checked the logs and saw abnormal boost levels.
With a flash tuner, if you returned it to stock, they could look for elevated boost levels (I presume they can do this) and see how many times the car has been flashed which would throw up a warning if it was higher than expected.
