04-05-2019, 04:32 PM | #1 |
Rep 377
Osram D1S Cool Blue Intense vs. Cool Blue Boost comparison
A few months ago I changed the factory HID bulbs (Philips?) to Osram CBIs. Based on what I've seen a lot on these forums, it seemed like the CBIs have been a top choice for replacement bulbs. Output was noticeably improved, and color was slightly whiter but not extremely different or as much as I had expected given the "up to 6000K" claim by Osram. But, I still loved the enhancement compared to the OEM bulbs.
Recently though, I looked into Osram's CBB bulbs. Most reviews I've seen have said that the CBBs are brighter than CBIs, while being whiter. I've only driven with the new CBBs on for a couple hours, but initial impressions match what I've seen in reviews - feels just as bright, if not slightly more, than CBIs along with a whiter color. I've not driven much in rainy weather at night, but I suspect the CBIs would perform better in adverse weather given the warmer color. Below are some output comparison shots between my CBI (top) vs. CBB (bottom). My iPhone picks up a lot more blue than there actually is, especially in the pictures farther away from the wall. In reality the CBB looks closer to being pure white (think slightly warmer than LEDs) whereas the CBI looks a little warmer. The close up shots better reflect the actual color difference, imo. When I took these photos, the CBIs has about ~65 hours of run time on them, whereas the CBBs were brand new so it wasn't at its full potential yet. I've also done a clear lens swap, which is why my cutoff is sharper and with a slight blue band. Anyway, here are the pics. Hope this is helpful for anyone debating between the two:
2014 BMW 328i, 6-speed Prem / Nav / Drivers Assist / Heated Seats / Lighting |
04-05-2019, 04:34 PM | #2 |
Rep 377
Also, here's a link to a startup / warmup video:
09-01-2020, 10:37 PM | #3 |
Rep 1,934
How was the clear lense swap? Was it on oem xenon housing or aftermarket?
09-02-2020, 10:47 AM | #4 | |
Rep 377
The swap was done on an OEM xenon headlight housing. The resealing of the lens wasn't as clean as I had hoped but so far no leakage.
09-02-2020, 03:29 PM | #5 | ||
Rep 1,934
09-04-2020, 01:14 AM | #6 | |||
Rep 377
I noticed you're out in Boston? If you don't mind the drive, Lightwerkz out in NJ seems to do a lot of great work. You could pay them a visit. Before I found Bayoptiks, I was seriously considering mailing my headlight housings to them.
12-27-2022, 10:30 PM | #7 | |
"Salud"
13980
Rep 4,689
Drives: F01 & F15 / Mineral White
12-29-2022, 03:00 PM | #8 |
Rep 377
Yeah, just replacing with a CBB bulb is an easy DIY, just switching the bulb out. If you put in the CBIs then it’s the same process. A clear lens swap of the projector though would be really involved and not an easy DIY, but I think you’d see the performance improvement of the CBBs even without the clear lens swap.
12-29-2022, 06:18 PM | #9 | |
"Salud"
13980
Rep 4,689
12-30-2022, 10:57 AM | #10 | |
Rep 377
I followed the instructions on this thread - check it out, there are some pics and good instructions on how to remove the clips. https://f30.bimmerpost.com/forums/sh....php?t=1324989
01-30-2023, 11:56 PM | #13 |
Rep 377
I swapped them out with LED bulbs as well
02-02-2023, 08:16 AM | #14 |
Rep 45
I recently noticed the car I just picked up also has LED turns. But want to see how these halogens look.
02-03-2023, 04:22 PM | #15 |
Rep 377
If the purpose is just to get rid of that orange color in the reflector, then the LED bulb does the same. LED bulb also gives that instant on/off effect that the halogen bulb won’t have. My guess is that halogen bulb is also prob dimmer given that the silver coating probably cuts some output, but I haven’t actually tried it.
02-17-2023, 05:07 PM | #16 |
Rep 1
Angel Eyes
At a crossroads between the CBIʻs and the CBBʻs. After a break in, which one do you notice matches the angel eyes temp more? Itʻs a very small detail, but my OCD kills me lol.
