BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Mechanical Maintenance and TSBs: Break-in / Oil & Fluids / Servicing / TSBs and Service Bulletin > Just did trans fluid change, FMIC, CP, Intake install..
      03-24-2017, 09:03 AM   #1
tgmsocal
Drives: 2016 M235i 6MT
Posted a thread in DIY section about my experience, happy to answer any questions there if you're about to do any of these yourself:
http://f30.bimmerpost.com/forums/sho....php?t=1367228
-tgm
      03-30-2017, 03:16 PM   #2
zcspec
zcspec's Avatar
212
Drives: 911/Boxster/Model Y
Thanks for the post...I just turned 30K on my 335 and may opt to perform a transmission service @ 35K. I may ping you on directions on using ISTA as I also have the program but don't know how to use it.
      03-30-2017, 06:10 PM   #3
tgmsocal
Nothing to it, tbh. Don't really need to dig through ISTA, just check out the DIY thread that has the torque specs and the bolt pattern. Really is as simple as make sure you can access fill plug -> drain -> remove pan -> bolt up new pan -> follow torque instructions -> fill -> start car and go through P-R-M1-M2 10 sec each while continuing to fill -> torque fill plug.
It took literally an hour and a half, tops.
-tgm
      03-31-2017, 10:32 AM   #4
tgmsocal
Also just realized you said 35k. This is likely much too early to worry about the transmission fluid - ZF recommends 60k miles (100k km) for maintainenance. Based on how my fluid looked (65k miles), I could have probably waited a little longer but it was definitely much dirtier than the new fluid with noticeable debris from the old filter.
-tgm
      03-31-2017, 10:36 AM   #5
zcspec
zcspec's Avatar
212
-tgm
I am a bit obsessive with my preventative maintenance but yeah, 35K miles might be too obsessive. I think I'll wait until 50K.
      03-31-2017, 10:52 AM   #6
jgoens
jgoens's Avatar
3788
Drives: 2013 335i msport
-tgm
Do you have a tune on your car?
ISTA is really easy and if you have it and the cable hook it up and try it. You can check for codes and see info about your car.
Last car: 2011 335i Msport. JB4. Vrsf CP
      03-31-2017, 10:53 AM   #7
tgmsocal
No, no tune yet but planning on bm3 at some point. The FMIC and CP were both in anticipation of this.
-tgm
jgoens3787.50
      03-31-2017, 09:52 PM   #8
etinifni
etinifni's Avatar
Drives: 2012 328i Modern Line
-tgm
Installing ISTA is a pita. I have yet to try and hook up my laptop to my car when using it.
:wave:
      03-31-2017, 10:19 PM   #9
Polo08816
Drives: 2014 335i M Sport
It is a pain to set it up on a host machine.
I set my ISTAD, ISTAP, ETK, and KSD within a Oracle VirtualBox virtual machine.
The VM takes up about 260gb but could expand to 500gb.
See: http://f30.bimmerpost.com/forums/sho....php?t=1339348
      03-31-2017, 10:44 PM   #10
jgoens
jgoens's Avatar
3788
Huh?
http://f30.bimmerpost.com/forums/sho....php?t=1312102
      04-01-2017, 08:24 AM   #11
Polo08816
There are a few pre-requisite steps that can be annoying such as modifying the registry in a fairly specific way.
It's far easier if you just set up a VM dedicated for ISTA. Also, you're never really sure about the source of such software and therefore not sure if it contains malware. Given that, it's safer to set it up in a VM so it doesn't affect your host machine directly.
