08-27-2023, 08:52 AM | #1 |
Rep 2
Remove EGR cooler or keep it there?
Hi everyone
This is my first time posting here as have been a long time lurker For awhile now I've been wanting to sort out the egr system and finally getting around to it. Have read many threads on it where people are doing different things. Some are keeping the cooler to help with coolant circulation while others are taking it out to prevent any problems down the road. The question is, which is the best option? It could also be coded out and keep everything there although I'd rather remove egr valve / cooler than worry about it breaking further down the line. |
08-27-2023, 09:37 AM | #2 |
Rep 8,508
Leave in place.
In the UK it’s a mandatory MOT fail if any of the OEM emissions control hardware is removed or tampered with. Code-out the EGR and install a blanking plate if you want to, but leave everything looking original.
08-27-2023, 01:02 PM | #3 | |
Rep 2
I am not that worried about it passing an mot as I know a guy. For engine health purposes and longevity would it be better without the cooler or with it do you know? Would be looking at getting the darkside developments kit as its only like £65 or so and then get it mapped out at the same time. |
08-28-2023, 06:54 AM | #4 | |
Rep 8,508
If a registered MOT tester certified a vehicle as roadworthy when they can clearly see that it should fail the test, the responsibility lies with them. How many other vehicles have/do they certify as roadworthy when they know that they have worn dampers, inadequate brakes, failed headlights, high emissions (i.e. particulates), compromised structural components due to rust, cracked windscreens, etc ? Dodgy MOT testers should be banned from the industry. I’m out.
