03-04-2017, 04:44 PM | #1 |
Rep 2,152
staggered 20s xdrive wide
need help please. I'm looking at wheels that are 9inch front 10.5 inch rear 20s.
the problem is I have xdrive bmw say 225/35/20 fronts and 255/30/20 rears. these i think will be to much stretch. what are my options on 9f/10.5r?
Current: BMW M4 F83 - Mods : Pedal Covers, LCI Stereo facia Retrofit and Carbon Rear corner covers
Old: F32 435d M Sport - Mods : HR Sport Springs, 20" Veemann V-FS23 in Gun Metal, M Performance Body Kit, Pedal Covers, Eurspec CF Mirror Caps, More-BHP remap 364 BHP 741 NM, M4 Under Chassis Brace, 15mm Rear ARB, 8.8" Screen Retrofit and LCI Stereo facia Retrofit |
03-04-2017, 05:29 PM | #2 | |
Rep 4,327
on x-drives, the difference between the front and rear diameter needs to be less than 1% (closer to zero = better) 245/35/20F(26.80), 285/30/20R(27.00), 0.75% diameter difference 245/30/20F(25.79), 285/25/20R(25.61), 0.15% difference there may be other combinations you choice of specific brand, tire, size become limited so you should consider this prior to purchasing your wheels. |
03-04-2017, 05:48 PM | #4 |
Rep 4,327
03-04-2017, 07:29 PM | #6 |
Rep 4,327
fwiw a 1/2" stretch is not much, it's stretching only 1/4" at each bead and angling the sidewall just slightly
245 is 1/2" stretch on 9", 255 is no stretch on 9", 265 slight bulge. 275 is 1/2" stretch on 10.5", 285 no stretch, 295 slight bulge. the problem is finding aspect ratio/tire width combinations that is close to the OEM diameter of 26", difference in F and R diameters less than 1% and finally tire brand, model, size that exist for your chosen combination. tbh i suggest you change the size of wheels, i.e. different width/offset, or look for different wheels that have width/offset more suitable to your needs. Last edited by alohasurftoad; 03-04-2017 at 07:36 PM.. |
Smee505.00 |
03-05-2017, 12:42 PM | #8 |
Rep 2,152
Cheers so what size am I looking at for 225 front 255 rear?
cheers
03-05-2017, 01:54 PM | #9 |
Rep 4,327
for the F3x series, OEM 20's are 20x8F, 20x8.5R with 225/255 respectively. start off with this in mind.
i suggest 20x8F, 20x8.5R or 20x9R with 225/255 OR 20x8F or 20x8.5F, 20x9.5R with a 235/265 combo if you want the staggered look. since you are x-drive you may also consider going square. the car will handle better by reducing understeer, there will be no transfer case issues since all four tires are the same and you will be able to rotate however you desire. 20x8.5 with 245 or 255 or 20x9 with 255 all four wheels. 225 best fit on 7.5" wide 235 best fit on 8" 245 best fit on 8.5" 255 best fit on 9" 265 best fit on 9.5" 275 best fit on 10" please use these or other similar sites and mess around on them. it's better that you do this and learn a bit than rely totally on forum responses. https://tiresize.com/calculator/ http://www.discounttiredirect.com/di...170305201407:s Last edited by alohasurftoad; 03-05-2017 at 02:22 PM.. |
Smee505.00 |
03-06-2017, 05:58 AM | #10 |
Rep 2,152
sorry one more 255/30/20 and 275/30/20
03-07-2017, 08:05 AM | #12 |
Rep 5,140
These wheel widths, 9" front and 10.5" rear, in combination with xDrive and without stretching the tires is almost impossible.
The only tire spec that fulfills those requirements would be 245/30-20 front and 285/25-20 rear. But you need to chose offsets very carefully, or else those tires will rub (at least the rear)! |
03-12-2017, 04:42 PM | #13 |
Rep 2,152
sorry been away and just got back so hadn't had a chance to reply.
so I am looking at velgen vmb6 in gun metal. f9 r10.5 I know the ET is 35f 45r on these wheels but I think if I get them I'm going great to go 235/35/20 and 275/30/20 as this seems the closest match. would you agree ? and shouldn't get the rub on rear?
