BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics > Carly for BMW (F3*) - anybody used it?
      04-24-2016, 03:16 PM   #1
wilbur_the_goose
Drives: 2018 330ix Gran Turismo
Question Carly for BMW (F3*) - anybody used it?
I see that Carly for BMW now supports the F3* series with their iOS app ('Droid is on the way).
Has anybody tried using Carly on the F3*?
http://support.mycarly.com/knowledge...t-is-possible/
      04-24-2016, 08:08 PM   #2
Arthurrs
Drives: 2017 430i xdrive Gran Coupe
Interesting!! Bought the app, and ordered the wifi adapter. Will let you know when I get it and have a chance to try it out! Their website seems to be very slow!
2017 430ix Gran Coupe
NBHD3.50
      04-24-2016, 08:16 PM   #3
gds52
gds52's Avatar
886
Drives: BMW Z4M Coupe, BMW 328i E93 Co
Yes, I've been using it on my E93 and it works good. It's quick and easy to use.
There are some in-app purchases like battery registration.
I will say go ahead it's good.
      04-24-2016, 08:56 PM   #4
HFW003
HFW003's Avatar
Australia
5685
Drives: 2024 M340i xdrive
What does this do that Esys (free) cannot?
      04-24-2016, 09:25 PM   #5
jgoens
jgoens's Avatar
3788
Drives: 2013 335i msport
I had the full version and used it on my e90, however as of a few months ago it was not available, for android at least, for the F30. Even the e90 version does not have many of the coding options like esys. To do all the coding that most people want you need to go the esys way.
Last car: 2011 335i Msport. JB4. Vrsf CP
      04-24-2016, 10:22 PM   #6
dalto
Drives: 2016 F80
2016 BMW 340i  [0.00]
2016 BMW M3  [0.00]
I think the benefit of Carly is not in functionality but in ease of use.
Honestly, I think e-sys is pretty east to use once you get through the initial learning curve. It is just not super intuitive.
      04-25-2016, 09:02 AM   #7
RoundelM3
RoundelM3's Avatar
2022 BMW X3  [9.83]
2015 BMW M3  [6.50]
I have been using Carly on my F30 for over a year, but not for coding, as that's still not supported on Android. Carly can read and clear diagnostic codes and a host of other things that E-Sys isn't meant to do. I recommend going to their website and checking on its capabilities there. From what they've told me, their F-chassis coding will probably be limited to the KOMBI module (dashboard items), but it may expand to include HU-ENTRY/CIC/NBT/NBT2 and FEM_BODY in the future.
It's a simple connect (via their BT adapter), read coding data, select features to activate or deactivate (or change values), then push back into the module. Same as E-Sys but with a much more simplified interface. It allows you to save the module coding data as a backup, just like E-Sys. It worked great for coding on E-chassis cars, so I'm hoping it will be the same for F-Chassis, although they've had quite a bit of time to get things working and so far, coding with Android still isn't fully tested yet. I've since used E-Sys for coding my F30 and the wife's F23.
2015 F80 ///M3 Sedan 7DCT Tanzanite, 2022 X3 sDrive30i 8AT Brooklyn Grey
      04-25-2016, 10:40 AM   #8
weiln12
Drives: 2008 135i Conv, 2013 328xi
Yes, did this the day it was released last week. They had an update yesterday to fix E-series coding they broke when they released F-series coding. I have both, and it works. I've used Carly on several E-series of mine and my brothers with no ill effects, using both iPhone and wifi adapter and Android with both bluetooth and usb cables.
A couple issues on the F-series: coded my defaults such as 5 blinks vs 3, and some wiper changes. Also coded folding mirrors with comfort access, and closing windows/sunroof with comfort access. Everything supported worked, but with some issues. When I coded, it did all the settings but kind of turned them off. I had to turn on 3 blinks and unlock all doors through iDrive, then the 5 blink setting kicked in and all my doors unlocked again. Weird, but that was the only issue I had so far.
I believe there were a lot of settings to turn off the light checks, and some other things. There were only 2 modules for me to code, whereas my E88 has 7, not sure if that's a change for the F series or just limited functionality of Carly right now. Carly works, and it's easy, but it's not nearly as thorough as other coding options. Sometimes it's hard to understand exactly what they mean too, but that's not the end of the world.
The parameter stuff is also flaky as the engine temp, coolant temp, and some others were all way off. A couple other things are also odd in the parameter stuff so I wouldn't trust any of that at all.
Just my experience since last Thursday for the F-series.
Nathan
2008 135i Convertible - Wife's
2013 328xi - Mine
      04-26-2016, 12:57 AM   #9
_JL_
Drives: F30 320i Sport
Their website is down atm. Can one code the F30 ASS using Carly? Thanks.
      04-26-2016, 10:55 AM   #10
Orion4
I get this when attempting to access their site:
"If you are seeing this message, the website for www.mycarly.com is not available at this time.
If you are the owner of this website, one of the following things may be occurring:
You have not put any content on your website.
Your provider has suspended this page.
Please login to https://www.mycarly.com:8443 to receive instructions on setting up your website."
Not good to see!
      04-26-2016, 11:53 AM   #11
wilbur_the_goose
From their FB page (https://www.facebook.com/CarlyForBMW/?fref=ts)
"Our provider is currently being switched ...
Our website www.mycarly.com and our support pages are down at the moment. They will be back online tomorrow or thursday, hopefully.
E-Mails may experience a slight delay as well.
Our Apps and Adapter Shop work as usual:
www.ivini-tech.de/en
Very urgent matters can be directed to bmw@ivini-apps.com.
Sorry for the inconvenience. Safe drive!"
      05-08-2016, 06:24 PM   #12
phattbam
Drives: '17 Protonic Blue i3 REx
Found this thread this morning. Subscribing for updates.
      05-08-2016, 11:15 PM   #13
Fronzdan
Drives: '24 M240 xDrive
Are you saying Carly supports F30 for coding? I don't think it does yet according to the website.
      05-09-2016, 12:52 AM   #14
_JL_
Yes it does F30 coding now. I bought it for coding the ASS in my F30 and it works. I also coded the turn signal from 3 to 5 blinks.
Some coding options seem not working as expected, e.g., the Gear Shit Indicator 1 & 2. My F30 has Indicator 1 active and 2 inactive. I tried coding Indicator 2 active in the hope to display the current gear in the instrument cluster but that ended up eliminating the gear indicator (P, R, D) altogether. Perhaps it only works in the extended instrument cluster? Anyone knows?
Btw, the first time I used it I only turn ignition on. Halfway during coding the instrument cluster turned off (due to timer I suppose) and the coding failed - scared me a bit but fortunately nothing bad happened. Now I always code with the engine running.
      05-09-2016, 12:54 AM   #15
Fronzdan
Cool. So to code F30, you need the paid app? Do you HAVE to use their dongle? I have a different wifi one.
      05-09-2016, 03:03 AM   #16
_JL_
Yes, need to purchase the ios app (Android doesn't support F30 coding yet).
I bought their Gen2 WiFi dongle as I don't have one. Not sure if it will work with others. You may want to check with Carly to see if your dongle is supported.
      05-09-2016, 08:19 AM   #17
RoundelM3
RoundelM3's Avatar
2022 BMW X3  [9.83]
2015 BMW M3  [6.50]
I'm still waiting for Android Fxx coding - so far, they're 6 months behind and still doing "thorough testing". Meantime, I've used E-Sys and an Fxx-compatible cable to code both of my F-chassis cars. Not for amateurs, though - the interface isn't nearly as friendly as Carly's. So far, Carly has been great for reading/clearing codes on Fxx cars, but not much else.
Can anyone verify what the limitations (if any) are for coding with their IOS version? I heard it was KOMBI module only, and nothing yet for FEM_BODY or HU-xxx (Head Unit).
      05-09-2016, 09:03 AM   #18
_JL_
It can code the KOMBI and FEM modules but not all codes are supported. Their web site has the full list of codes supported.
      05-09-2016, 09:47 AM   #19
IndotagSwizz
IndotagSwizz's Avatar
525
Drives: F30 320i
I want to get this but some of the reviews on amazon claim the F30 is not well supported. what have you coded using this so far?
AGONXF30270.50
      05-09-2016, 11:15 AM   #20
RoundelM3
RoundelM3's Avatar
2022 BMW X3  [9.83]
2015 BMW M3  [6.50]
Thanks for the update. Kind of a moot point now that I've coded everything I need with E-Sys, but I do own the pro version and would like to get full functionality.
      05-09-2016, 11:16 AM   #21
Fronzdan
Verified that you MUST use their OBD adapter to code F30. The software must do a query of the hardware. I have another brand Wifi adapter that works well with other software and SHOULD work with Carly, but it won't accept it for coding.
The cost of the dongle is cheaper if you could buy direct, but they seem to force you to use Amazon if you're in US, which is $16 more.
      05-09-2016, 03:17 PM   #22
RoundelM3
RoundelM3's Avatar
2022 BMW X3  [9.83]
2015 BMW M3  [6.50]
Yes - you must use their Gen. 2 BT adapter with Carly if you want to code anything (IOS or Android), although Android coding still isn't available.
