08-21-2018, 05:24 AM | #133 |
Rep 9
Hi everyone
I have coding problem with FEM BODY of many F-series FDL coding too Esys PRO from TokenMaster Last data from Shawn (Thanks again) Error: cafd ....... Not Executable Any idea? Last edited by jakim8; 08-21-2018 at 05:54 AM.. |
08-21-2018, 06:05 AM | #134 | |
Rep 2,302
Then choose at the connection menu "Target Selector .... VehicleInfo=F020" |
08-21-2018, 06:23 AM | #139 |
Rep 2,302
Yes, VIN is right.
But did you choose F020? Edit: Du bist doch aus der Schweiz, dann verstehst du Deutsch evtl. besser. Wenn du einen M4 hast, dann musst du beim Verbindungsfenster F020 auswählen und unten Verbindung über VIN. Lt. deinem Bild von oben hast du aber F001 ausgewählt. Und das verursacht solche Probleme. |
08-21-2018, 06:32 AM | #141 |
Rep 41,011
"Object with name not found" means you choose incorrect E-Sys Launcher PREMIUM Car Series or incorrect E-Sys Connection Target.
08-21-2018, 09:13 AM | #145 |
Rep 41,011
09-18-2018, 12:29 AM | #146 |
Rep 65
hi i got this error below. My car have cafd_00000794_012_034_013. I have done the vcm and the cafd read as exact above. When i try to read code, it give me error below.
File for "cafd_ffffffff-255_255_255" not found! [C012] I tried Shawn method of injection like below but i don't see the detect CAF for SWE. ct => Read FA (VO) => Activate FA (VO) => Read SVT (VCM) => Left-Click on desired ECU => Click on "Detect CAF for SWE" => Select the replacement CAFD from above => Select OK => Right-Click on ECU (the ECU itself not the underlying CAFD) => Select CODE. frustating tyring to follow step but i don't see it. i believe my esys version is 28. What can i do to fix this. Bummer that i spent two weekend trying to get this work. i can't pm shawn directly cause i am noobie. Please help. Thanks. |
09-18-2018, 01:10 AM | #147 | |
Rep 41,011
09-18-2018, 11:12 AM | #148 |
Rep 65
02-14-2019, 12:29 PM | #149 |
Rep 2
Hy.
[QUOTE=shawnsheridan;17039011]These two CAFD are not part of any PSdZData release. You can inject the following replacement CAFD's into the ECU's, VO Code them, and then you can FDL Code them:
FEM_BODY - cafd_00000794.caf.012_035_116 HU_NBT - cafd_00000ded.caf.003_013_024 Connect => Read FA (VO) => Activate FA (VO) => Read SVT (VCM) => Left-Click on desired ECU => Click on "Detect CAF for SWE" => Select the CAFD from above => I have a Problem with fem body on my f 30. Please help |
02-14-2019, 12:30 PM | #150 |
Rep 41,011
What is the specific problem or am I to guess?
02-15-2019, 01:15 PM | #151 |
Rep 120
Hello guys, i did the retrofit from my 6wa to 6wb. Now i would like to code some things in Dkombi but when i read the coding data, this error appears to me |
02-15-2019, 01:37 PM | #153 |
Rep 41,011
Are you using latest v.4.15.31_PSdZData?
02-20-2019, 06:53 AM | #154 |
Rep 3
Hello to everybody! I need CAFD file "CAFD_00001EF6_006_27_002" for NBT Evo coding, could someone help me to find it?
I tried with PSdZdata 63.3 and full PSdZdata 4.15.31 Thanks in advance |
