03-06-2017, 11:30 PM | #1 |
Rep 462
First of all, I would like to give a special thank you to @mike@x-ph.com for hooking it up with a great deal!
I had taken comparison pics of the FMICs but for some reason they didnt save. For those of you who are not familiar, the Phoenix FMIC is roughly $300 (without any promotion).... And i will let the logs say the rest. San Francisco 50F, Full-Bolt ons, E40. Hard to do log during 9pm at night. But ill post more logs on this thread as needed. http://www.datazap.me/u/jmenis/fbo?log=0&data=1-4 - 3rd to roughly red line. http://www.datazap.me/u/jmenis/fbo-spin?log=0&data=1-4 - 2-4 with wheel spin. Feel free to check out my datzap account to compare logs from before the FMIC. and even my last car lol #23psi.
@Menis_F32 2015 435I Msport EWG - Muffler Delete, JB4, E30/40, VRSF Catless DP, Resonator Delete, BMS Intake, H&R Super Sport Springs, VRSF CP, Phoneix FMIC, BM3 STG2 OTS 91 - JB4 BEF
03-07-2017, 01:45 AM | #2 |
Rep 37
The temps on many of the recent logs are increasing quickly. With an aftermarket IC, the temps drop immediately when getting on it even a little as air starts moving over and through it, then steady out and begin their increase. Compare longer runs, not single gear runs, and compare what the IC bottoms at and how much it rises. Cruising and stop and go temps are relatively similar to stock, it's how the IC performs when under WOT, and how much it's increasing that I would think shows how well it works. If the temp is bounding up quickly the last half of the one-gear run, I think that's something to be noted.
It performs better than stock, that's what's relevant. Outside of that, it's up to the owner to decide if their spent money was worth it. For $300 to get any notable increase, I'd say that's a good deal. 50F outside though, I'm jealous...
'13 IBM 335i
Dinan Intake, ER IC/TIC/CP/DP, JB4/MHD, xHP, etc... '08 AW 335i Money pit... |
FSociety3812.50 |
03-07-2017, 09:51 AM | #3 | |
IG @bmwF9xG80
3813
Rep 7,593
60-130mph 6.5s X4M #HCP
wakeofdeath70.50 |
03-07-2017, 10:48 AM | #4 | |
Rep 462
While temp is increasing slightly, the stock FMIC would of been heat soaked by my 3rd pull or so. Not to mention before the FMIC map 5 wouldn't hold 15 psi, instead it would hold around 12. IMO this FMIC is perfect for someone looking to drive spiritedly and save money. Definitely would recommend something else for track oriented people. However, after adding the FMIC I can't hook my MPSS from 1-3 anymore (used to be able to even with this weather) . So the butt dyno shows improvement
03-07-2017, 11:06 AM | #5 |
Rep 462
For those who can't view the logs
Log 1: 2-4 gear with a ton of wheel speed (explains boost) Log 2 : Without FMIC 2-4 gear roughly 60F
EDWYER1672.50 |
03-07-2017, 04:47 PM | #7 |
Rep 98
I am trying to figure that out. Can one of you guys get a measurement of the fin density?
M Performance mirrors, spoiler, and exhaust, BMS wheel spacers (10mm F 15mm R), ER kittyless DP.
Need a tune and intercooler |
03-07-2017, 04:49 PM | #8 | |
Rep 693
03-07-2017, 04:50 PM | #9 |
Rep 98
Then it sounds like it may be.
03-07-2017, 06:38 PM | #10 |
Rep 462
I have the m sport bumper
03-07-2017, 07:12 PM | #11 |
Rep 37
I think the cheaper options will be better for most people, as most don't have the climate or mods to necessitate something larger, especially when considering the price differences now available. My choice was based on climate first, then perceived quality next based on the upper end options available. Crappy gas lent to that as well. I definitely wouldn't have bothered with the ER if I was still stuck in Oregon, but I'm pretty happy with it here.
'13 IBM 335i
Dinan Intake, ER IC/TIC/CP/DP, JB4/MHD, xHP, etc... '08 AW 335i Money pit... Last edited by 1stupidsailor; 03-07-2017 at 07:18 PM.. |
03-07-2017, 07:17 PM | #12 |
Rep 37
Agree wholeheartedly. I finally picked up my M-sport bumper from the paint shop today and took a couple quick measurements. The open area to the front is almost 3 times larger on the M-sport, I'm sure that accounts for some cooling while in motion as well as the containment of heat. I noticed I also have like a large rubber flap that runs the length of the IC attached to the old bumper that sits over top of the IC. Seems like another heat trap as well, so I'm going to leave that off when I do the swap.
'13 IBM 335i
03-07-2017, 07:20 PM | #13 | |
Rep 693
03-07-2017, 08:37 PM | #14 |
Father of Frankenfold
299
Rep 531
Drives: Yo daddy's 2014 X3 M Sport
That "large rubber flap that runs the length of the IC attached to the old bumper that sits over top of the IC" and the other pieces around it are designed to direct flow and pressure through the intercooler, rather than around it. Anything you can do to duct the maximum frontal area open in the bumper through the intercooler core, without offering a bypassing flow around it, will help with intercooler efficiency.
03-07-2017, 09:52 PM | #15 | |
Rep 693
03-07-2017, 11:19 PM | #17 |
IG @bmwF9xG80
3813
Rep 7,593
I think the Black Powder Coating in the Phoenix/Rev9 might not be helping ?
I thought they were similar too and I went on and bought from CTS Turbo because its a well known brand (VW/Audi contender). Comparing a friends Log from July (we went to dyno together) his IAT weren't impressive vs my stock one but def 20-30F difference only. I' just saw some VRSF Race Logs and for $700 doesn't look like its doing a "$700 job" to be honest I spent about 6 months looking at FMIC and comparing logs, even was ready to go with Rev9 (only if i could get it for $200) cuz it was an upgrade over stock but not worth $300+ Then sicmadek got Rev9 and while I had already seen my buddy's IAT in the summer with Rev9 too i wasnt impressed (DynoDay), sicmadek temps were a bit better. Then I saw the CTS Turbo went on tax return sale and badbread thread that has a really good review + logs made a good impression i knew it was a sign. About 10 of us joined a GroupBuy and got the FMIC for $360 shipped (Sale on website $384 shipped ends on the 10th of this month). I didn't wait no time, installed it the next day took stock FMIC logs same day same 16-19psi boost map (aggressive). This was last week. now today I was on a Dyno for 2hrs tweaking and seeing where my car is on a Mustang dyno "Heartbreaker". Just want to let everyone know I dont care which IC you go with, but CTS Turbo may or not look like my neighbors IC, the difference is, its really working guys. Now I understand if the IC were $300 vs $450+, but in this case the Phoenix/Rev9 is a $200-$250 IC and being marked up $300-$400 (is not worth it). Heck, buddy of mine bought a VRSF for $300 on black friday LOL. I'm not the only guy with logs and proof; the vendors dont want another brand to sell if it aint there's ;-) Here's some IAT logs from my 2hr Dyno session today, Ambient 60F ; Not the best AirFlow in the Dyno (only 5ft from the wall) and a small door open (back). Fans weren't on highway but hey whatever i dont care i wanted to see what it would do; going to Dynojet in a week for my comparison to my last year run. Stock run in 5th gear (2nd pull of the day) Starting temp 75F Under Wide Open Throttle: 73F At Redline: 84F Did about 15 pulls total and without more than 5mins of cool down The difference with what we're seeing being compare is JB4 cars on map2/5 (boost not consistent) and not map7 (absolute) 18psi target My flash is (holding boost through the range, unlike piggyback that does not hold boost consistently) look at the IAT for yourself guys, when car is heat-soaking, pulling time your jb4 drops boost. check out my signature for logs and will be adding more this week. What we mostly see is 2-4th gear, but most of the heatsoak occurs in back to back 3-5th gear and most of it 5th gear from my logging. Redline the car and don't shift early is where I see all my heatsoak Since i'm running jb4 map4 (DME_BT is my true DME boost) http://datazap.me/u/fsociety/log-148...1-5-6-15-19-23 (see how under WOT my temps drop) http://datazap.me/u/fsociety/log-148...=1-4-5-6-15-19 Last but not least, go see my comments on http://f30.bimmerpost.com/forums/sho....php?t=1322795 when I was asking badbread for more logs, info etc why? because i wanted to see if he can duplicate the results. I know am seeing it for myself. I have no favorites just letting you guys know, research before spending $1 or $1000
60-130mph 5.0s G80 M3 #OrlandoAutowerks Sauce IG: @bmwF9XG80 Last edited by FSociety; 03-09-2017 at 07:41 AM.. |
wakeofdeath70.50 |
03-07-2017, 11:22 PM | #18 | |
Rep 198
I have someone to email or call, btw you also said in the other thread that PTF/Bm3 takes 30mins to flash (You're wrong here), can I see the proof of CTS saying this to you? But i do notice VRSF/CTS Turbo/Wagner/Phoenix/Rev9 all look alike, logs will speak for themselves. Last edited by wakeofdeath; 03-07-2017 at 11:33 PM.. |
03-07-2017, 11:26 PM | #19 | ||
Rep 462
(I will post my map 7 wot log I took right when my clamp blew.) so people can see the FMIC under heavy booost All in all, I haven't done any digging for logs. But it seems the 2 are almost similar. However there is more available data for the CTS out I believe. Which may be a contributing factor to why people are favoriting it more. It also depends on what mods people have and how much boost their car is making. And a bunch of other factors
wakeofdeath70.50 |
03-07-2017, 11:37 PM | #20 | |
Rep 198
With this review itself http://*************/new-intercooler/ made my decision easy, then seeing FSociety and the other guys in the CTS Turbo Intercooler thread I couldn't pass it. Don't mean to hi-jack your thread and yes a lot of ppl dont have high boost logs, happens that the CTS turbo logs are running more boost and higher gears than the other folks. |
FSociety3812.50 |
03-08-2017, 12:03 AM | #21 | ||
Rep 462
However without the discount it is about $500 or so. And this thread was for those who were looking to for a cheaper FMIC
wakeofdeath70.50 |
03-08-2017, 06:03 AM | #22 | ||
Rep 693
