02-11-2017, 10:48 PM | #46 |
Rep 8,364
Nelson@BimmerTech271.00 |
02-12-2017, 02:49 AM | #47 |
Rep 183
Well iPhone 3 is 8 gernertaions old... a more accurate comparison is running iOS 10 on iPhone 6S; which runs perfectly.
04-05-2017, 02:20 PM | #48 |
electrified
32
Rep 127
Tried coding this today, set the value to iD6_lite, but on the my vehicle tile it showed a "G" series car, i think it was the 7 series. Is there any way to change this to the 3 series? Changed back to iD5 and now it is back to normal.
04-05-2017, 02:26 PM | #49 | |
Rep 8,364
Native ID5 is on on 4GB unit. What is your I-Step? F020-17-03-502 came with additional vehicle choices. |
04-05-2017, 02:55 PM | #50 |
electrified
32
Rep 127
04-05-2017, 06:00 PM | #51 | |
Rep 8,364
04-06-2017, 09:23 AM | #52 | |
electrified
32
Rep 127
04-06-2017, 12:54 PM | #53 |
Rep 4,724
FWIW, I do not like the new tile set up. It's clumsy.
Current: 2021 M340i xDrive
Previous: '18 340i xDrive; '15 335 xDrive; '14 435i xDrive; '09 335 E92 xDrive |
04-10-2017, 07:13 PM | #54 | |
Rep 342
WOW. 4.05 seems like going lot higher in the numbering. Have you noticed any significant new features? Maybe ID6 UI for stock ID5 cars?? Thanks. |
04-10-2017, 07:43 PM | #55 | |
Rep 8,364
I do not have ID5, nor have I flashed car with updated software. I just installed on computer. |
04-10-2017, 10:33 PM | #56 | |
Rep 512
Drives: 2020 Z4 M4Misano Blue
*It's iDrive 6 "light", most likely because it doesn't have the gesture features.
2004 E85 Z4 3.0 Sport - Sold to brother | 2004 E83 X3 xDrive3.0i - Gone | 2011 E89 Z4 35is - Gone | 2011 F25 X3 xDrive35i - Gone | 2014 E89 Z4 E89 35is - Gone | 2014 F25 X3 xDrive 30i X3 - Gone | 2017 F83 M4 Cabriolet - Gone | 2017 F25 X3 xDrive30i - Gone
2020 G29 Z4 M40i Misanoblau | 2020 G01 M40i Phytonicblau Casa Suzana, vacation rental villa in Cozumel, Mexico |
04-10-2017, 10:38 PM | #57 | |
Rep 8,364
HMI_VERSION: ID5 (01) <--- No change HMI_ID_VERSION: ID6_lite (03) <---- change ID6 Light is GUI over ID5. It is almost like both Google Pixel and Samsung Galaxy S8 both run Android OS, but have different launchers. |
04-10-2017, 10:43 PM | #58 |
Rep 512
Right. emulajavi asked about "Maybe ID6 UI for stock ID5 cars" which is more-or-less what this is: a different UI for cars that came with iDrive 5.
04-10-2017, 10:57 PM | #59 |
Rep 8,364
04-26-2017, 06:20 PM | #60 | |
Rep 451
Drives: 2017 X5 & 2020 X5
Thanks
Current: MY 20 X5 2.5d xDrive MSport
MY 17 X5 2.5d sDrive Last edited by Bambazonke; 04-26-2017 at 06:36 PM.. |
04-26-2017, 07:57 PM | #61 | |
Rep 8,364
My guess is you selected "Code" rather than "Code FDL." Sure, you can update firmware yourself, though it requires an external power source and is riskier than coding. You can always ask; but unless they can document some kind of fault, you will have to pay for programming work. |
04-27-2017, 06:15 AM | #62 |
Rep 451
Definitely FDL coded it as the main menu reverted back to "ID4 layout style". I had also activated VIM (up to 63kmph) and it retained these settings. If I had "coded" it would have been reset to the factory settings and I would have lost the VIM settings and the BMW Motorsport image at start up.
Was thinking of trying the full version of ID 6 but I don't have a touchscreen any reason not to try it?
MY 17 X5 2.5d sDrive |
04-30-2017, 01:41 AM | #63 | |
Rep 8,364
You downgraded ID5 to ID4++? ID6 does not display correctly. You only want to toggle between ID5 & ID6 Lite. |
05-01-2017, 06:16 AM | #64 |
Rep 451
No I tried to upgrade to 6 Lite but the main menu display ended up looking like the layout of ID4 No large 3 "active" icons as expected. Tried ID6 and as you said the display sort of crashed and looked similar to what I got when I attempted to code ID6 Lite.
05-01-2017, 05:50 PM | #65 | |
Rep 8,364
I have never seen it not work. It should have 5-6 large "flat" rather than curved ID5 icons. Yes, ID6 I have seen crash, look like ID4, or only display in a quarter of the screen. |
05-04-2017, 11:42 PM | #66 |
Rep 451
Do I have to reboot the HU? to get it to display the new layout If so how do I do it? I vaguely remember someone holding in the power button plus something else for a few seconds?
