BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > Active Sound Design (ASD) Retrofit progress
proTUNING Freaks
      07-31-2017, 07:29 PM   #133
hsk1610
Drives: 2013 328i xDrive
Originally Posted by hsk1610 View Post
So I received the ASD wiring harness and one end plugs into the ASD amp but the other two that plugs into the Hi-Fi amp and the line from the vehicle don't match. I specifically mentioned that I had the Hi-Fi Amp.
Doesn't look like the harness is for the Harmon Kardon amp either. Does anyone know if they sent the harness for a different model type? Here are the pics.
Heard back from the vendor. With the harness they provided, i need to install the ASD and connect it directly behind the head unit since they used the connectors for the headunit to build the harness. Screen shots they provided shows that the ASD still will be recognied under eSYS.,
So Hi-Fi Amp from trunk to dash- unplug from headunit, plug into their harness, which then branches into the ASD and the head unit.
      09-26-2017, 12:56 AM   #134
accloginsell
Hi all,
which is the newest PSDZ Data it will work?
as know i have 2016-07 and its to new, ASD not working.
Can someone help me?
Thank you
      11-25-2017, 09:26 PM   #135
Justin Gang
Justin Gang's Avatar
Austria
Drives: F30 320i 2013
Retrofitting a Base Stereo Audio of ASD is failed
Anyone who knows how to making wiring of ASD Retrofitting with Base Stereo Audio?
My car is F30 320i, made in 2013 early
I have tried ASD Retrofitting by myself refer to ISTA-D.
But it is not working. I mean...
Strange is that i can hear music. But the Artificial Sound is lose.
I can find out some error using ISTA-D.
ISTA-D said(I attached). and I referred to this image.
(AMP has been connected to Speaker's output instead of HIFI AMP.
Is ASD Module broken?
      12-12-2017, 07:07 AM   #136
berndh
Drives: BMW F11 525d
Originally Posted by Jadamczyk22 View Post
Finally got it working.
Single most important thing to note:
Any car with HK audio, which did NOT come with ASD, will also need a new HK amp which supports ASD.
**The cars with ASD have a different HK amp than the cars without ASD**
You will need to buy a new amp with the extra pins on the connector.
The NON-ASD HK amp has a connector like this:
The ASD amp has a connector like this:
The ASD connector for the upgraded amp can be found on ebay and other online sources, part number 1355795. But be prepared to buy a new amp if you have HK audio and want to retrofit ASD
Indeed, I bought the ASD module, and connector and made a custom cable. Then I walked to the car and found out that I indeed had the wrong Amp. I have the S677 (TOP-Hifi) in my 06-2013 5 serie F11. WHaaaa
Did someone very changed their TopHifi (S677) for the HK (S688) and noticed a difference?
      02-12-2018, 11:01 AM   #137
PauloPEC
Paulo PEC
Brazil
Drives: F30 328i Sport GP 2013/2014
Great Master Vitchie!!! Please, Help me to activate my ASD
Hi Vitchie,
Please, help-me! 'm trying to activate my ASD module on my 328i 13/14 Sport GP, but it didn´t work yeat.
I´ve already change with E-SYS, the ASD configurations, like picture atacched:
Could you help me?
Thanks
Paulo PEC
BMW F30 328i Sport GP 2013/2014
VIN:F975218
      02-12-2018, 03:14 PM   #138
atzebmw
Drives: Tesla Model 3
Did you already code (not FDL code) the ASD by your VO?
      02-13-2018, 02:39 PM   #139
PauloPEC
Paulo PEC
Brazil
No, I didn’t. Only FDL Code. Could you help me with some DYI?
I don’t know how to...
Thank you!
Paulo PEC
      02-13-2018, 02:57 PM   #140
atzebmw
Thank you!
Paulo PEC
This is easier than FDl code.
Read VO
Activate VO
Read VCM
Mark ASD ecu
Push the button "Code"
That's all and the ASD will be coded by your VO.
      02-13-2018, 04:32 PM   #141
PauloPEC
Paulo PEC
Brazil
Read VO
Activate VO
Read VCM
Mark ASD ecu
Hi,
I Did your step-by-step but didn't work.
Something else to do?
      02-13-2018, 05:08 PM   #142
atzebmw
Hi,
Did you retrofit the ASD?
Did the values from your first picture change now after coding the ASD (F001, F010, F020...)?
Do you have more choices now?
      02-19-2018, 11:02 AM   #143
Justin Gang
Austria
Hi,
I have a few questions.
Should we change to 3C17?(I have F30 320i)
Thanks you in advance.
      03-28-2018, 12:54 AM   #144
apocalypsbe
Belgium
192
Drives: X5 G05 45e
I have ASD on my 420D but I don't see ASD in coding
I don't have ASD sound on my speaker system (inside of car) as far as I know which is strange. I do have a HIFI system with amplifier in the trunk of my car.
The sound is only coming from the ASD M Performance exhaust line but I still assume it should be possible to code it but I don't know how to make it show up, we checked using Carly Pro module/app but the ASD module was missing
Can anyone tell me what I should do to make the ASD module show up in my particular case?
Let me know if you want me to show specific pictures or something to help me figure this out
      04-16-2018, 09:30 AM   #145
tela15
Drives: F30 318d Sport
Exclamation Can anyone wake up my 318d?
Hi everyone!
I've read through different threads trying to find a guide to do this.
I currently have a 2016 F30 318d which sounds
To install an Actuator/Booster is really expensive, although it seems to be easy to install. Another alternative would be the official M Performance Active exhaust – however, I love my blacked out single-pipe exhaust and would not change it for the double pipe.
The best option seems to be retrofitting the ASD Amplifier/Control Unit – I've seen a few under 100€. I just want the sound to be in the cabin and enjoy it while driving some exciting roads, I don't care if it sounds like nothing outside.
Does anyone keep any pictures from their retrofit? What harnesses, cables and fuses do I need?
If anyone can easily explain the process, I'll do it, and document it to share it with the forum for dummies like myself!
The car has the Harman/Kardon system
P.S. Created the forum account solely for this purpose! I really crave some noise from my car!!
      06-03-2018, 08:39 AM   #146
csc2ro
Drives: 2016 430xd F36 Luxury
Hi,
I have a 2016 F36 430xD, Luxury package, HI-FI system.
Do I have the active sound? I found the ASD module located in the trunk but I don't hear any motor sounds in my speakers.
Thank you.
      08-21-2018, 12:43 PM   #147
DayvG
Drives: F30 Sport
How much did you pay for your amp? I’ve been trawling eBay but can’t find anything with the correct connector.
      02-11-2019, 04:18 PM   #148
hallonmunk
Sweden
Drives: Glacier Silver 328i 2012
Anyone who has completed this retrofit and would like to guide us? What parts to get?
      05-07-2019, 04:29 PM   #149
iamvanja
iamvanja's Avatar
167
Drives: 2015 640i GC white on red
Ditto. Has anyone done this on a 640i GC?
      12-17-2020, 03:14 PM   #150
escribblings
Drives: F54 Mini Clubman
I'm sorry to necro such an old thread, but I can't find any other decent references on adding ASD.
I have an F54 Clubman, and I have retrofitted the driving modes (option 4VA). However, this now prevents ISTA from doing a software update, as it is now looking for the ASD ECU.
I have the HK stereo, from reading this thread, I am guessing that I might need a new HK amp, although looking on RealOEM it doesn't say there is an ASD/4VA requirement.
https://www.realoem.com/bmw/enUS/sho...diagId=65_2597
I am confused as to whether I need to run wires to all speakers, or just place it inbetween the current wiring connector and the amp socket.
Overall, I can get the ASD ECU reasonably cheaply, I am not to concerned about the sound, so would connecting the power and CANBUS (in my case I believe it's on KCAN4) be sufficient (assuming to get the soud I would need to run new wiring to all speakers).
I know I can just code out 4VA, get the update, and then code it back in, but I don't really want to go down that route.
      02-24-2021, 12:23 AM   #151
escribblings
Hi. Revisiting this in the hope that someone on here can shed some light even though my vehicle isn't an F30.
I've had a further look at the technical documentation for my vehicle.
I have option P674 - HiFi loudspeaker system Harman Kardon.
Originally Posted by TIS
If the vehicle is equipped with ASD (Active Sound Design), the ASD control unit will be installed between the headunit and Harman/Kardon hi-fi amplifier. Here, the ASD signals are mixed in to the audio signals from the headunit and then forwarded to the Harman/Kardon hi-fi amplifier.
Going from that, would the harness hsk1610 used work? And if so, is there a part number or link to an eBay seller?
      04-24-2021, 02:20 AM   #152
Siki78
Siki78's Avatar
136
Drives: F30,G30
Hier one nice write up from HIFI//HK to Y-Adapter
approx. 10x socket contact ELO- Power 2.8x 0.63 2.5-4.0 MM² (61136913612) -6.00 € -
approx. 40x socket contact MQS (61138369696) -12.00 € -
2x cover cap 42 POL. (61138364862) - € 7.00 -
2x socket housing black 21 POL. (61138364882) -6.00 € -
2x socket housing gray 21 POL. (61138364884) -6.00 € -
1x old Versärker to remove the "connector housing", mine was from an e46 but almost everything is possible, just look at the original connector and compare -30.00 € -
1x control unit Active Sound Design, actually it doesn't matter which one--200.00 € -
7m VEHICLE LINE 0.35 -10.00 € - (Conrad)
3m VEHICLE LINE 0.75-2.00 € - (Conrad)
1m VEHICLE LINE 2.50 -2.00 € - (Conrad)
2m VEHICLE LINE 4.00 -3.00 € - (Conrad)
File Type: pdf BMW Fxx ASD and HiFi Pin assignment.pdf (537.2 KB, 240 views)
Successfully retrofit on BMW F30 335xi 248,302,3AG,430,5AG,5AS,6NS,8TH and IHKA3
      04-19-2022, 06:55 AM   #153
Drimacus
Drives: 2013 F31 320d Luxury
Hi
I retrofitted HK and ASD on my car.
HK AMPT with asd support.
ESYS coded HK and ASD without problems editing FA to f31 340i
Unfortunately i have no sound from ASD.
HK work perfectly
Any hint?
no errors on ista at all, the only thing i found is about RAD_ON
According to diagrams, ASD ha two RAD ON,
One from HK, on pin 7, and one from HU on pin 13.
I checked both
The one on HK is present,
the one from hu is not present and pin 13 is not populated.
My car is a f31 07/12
i wired a cable from pin 13 a42*1b (hu) to pin 10 A233 (ASD)
Nothing changes.
      04-21-2022, 03:03 AM   #154
Drimacus
no hints?
