03-17-2017, 06:59 PM | #1 |
Bud Light General
130
Rep 402
ambient lighting problem
While installing my bavsound speakers I accidentally pulled on the ambient lighting connector for the front passenger door causing it to break. I told BMW what happened and they replaced the ambient lighting with the newest version (for my 2015 f30) after replacing I am noticing that all the other doors are brighter than this door. Is there a reason for this? I want to bring it back to the dealer but am concerned that the lighting will stay this way.
03-22-2017, 07:18 AM | #2 |
Bud Light General
130
Rep 402
anyone have any ideas? The dealer is unsure what to do so any help is appreciated, whether it be to order s specific part or do something else to make sure the brightness is at a higher level
03-22-2017, 02:16 PM | #3 |
Schmollbraten
12512
Rep 1,985
Ensure that the replaced trim line and the year of build of your car is the same or at least not older.
At the F32 they changed the quality and other specs at the ambient light and older lines have the same effect.
Citizen of ///M - Town, where too much is just right Some say, that my scrotum has its own small gravity field and when Im slowing down that brake lights come on at my buttox |
jeffc83725.00 |
03-22-2017, 03:46 PM | #5 |
Rep 1,615
03-22-2017, 03:46 PM | #6 |
Rep 1,615
03-22-2017, 07:57 PM | #8 |
Bud Light General
130
Rep 402
DRIVER FRONT DOOR AMBIENT LIGHT-FUNCTIONING
PASSENGER REAR DOOR AMBIENT LIGHT-FUNCTIONING ****PASSENGER FRONT DOOR AMBIENT LIGHT-DIM**** (AFFECTED LIGHT) I know this isn't the worst thing that could happen but I am very OCD-looking at one door significantly dimmer than the rest really bothers me. My appointment is scheduled for Monday morning so hopefully these suggestions will help find the solution to this problem. |
03-23-2017, 03:32 AM | #9 |
Schmollbraten
12512
Rep 1,985
The LCI ambient lighting is much more brighter than the previous ones. They had tried a software update at mine with the effect, that the light was brighter than before for a few weeks. After every relighting it turns darker and darker and ended up into the same low level at my complaint.
So, this isnt a problem of the installed light-lines but the hardware to steer it.
03-23-2017, 06:53 AM | #10 | |
Bud Light General
130
Rep 402
03-23-2017, 01:13 PM | #11 |
Schmollbraten
12512
Rep 1,985
I say nothing to you what to do. Just telling you, that the change of the ambient light elements at the F32 had changed 2015 and since then this problem is obsolete. Ask your dealer about the F30.
03-23-2017, 01:19 PM | #12 | |
Rep 1,615
04-05-2017, 06:55 AM | #13 |
Bud Light General
130
Rep 402
Update:
My car has been with BMW for over a week now, they replaced the lighting tube, the LED module (with the new part number), and the bracket. I just got a call this morning from my service adviser stating the problem did not change at all, the other 3 doors are still significantly brighter than this door and they are stumped. The shop foreman is still thinking it may be a voltage issue and may try something with that. Not sure what to do here honestly. |
04-06-2017, 01:43 AM | #14 |
Schmollbraten
12512
Rep 1,985
I assume that theres a mistake with resistors and the modules which are steering the ambient light. After a SW update the lights were bright again and then start turning down to zero after each light switch on.
04-06-2017, 06:28 AM | #15 | |
Rep 109
04-06-2017, 06:57 AM | #16 |
Bud Light General
130
Rep 402
So they were able to resolve the lighting problem and the orange light is as bright as all the other doors...
But now there is another problem When switching from classic to sport lighting on idrive (orange to white light) all doors light up white except the light they fixed (front passenger door). The orange light works perfectly when in classic mode though. When in sport lighting no light comes on affected door at all. |
04-07-2017, 12:49 AM | #17 | |
Rep 109
06-29-2018, 01:57 PM | #18 | |
Rep 7
11-25-2018, 02:33 AM | #19 | |
Rep 1
Rear seat ambient lighting not working properly.
Hi, I have just picked up my X125i 2018 mode this week. Last I noticed the same. The ambient light on the driver side rear door is very very low compared to other three doors. Today I changed the settings to modern, lighting on all 4 doors works fine. It is just on the classic/ orange light this doesnt work. Any ideas what might be wrong? This is the first bmw car im driving, not sure if this is a fault there are settings that I need to change. Appreciate any help/ ideas. Thanks |
03-01-2019, 03:08 AM | #20 |
Rep 85
I have a F30 (2014) with ambient light
Now my right backdoor ambient light is not turning on. The rest is going on nicely. What can this be and how to fix it? Thanks Roopd |
