11-05-2018, 09:46 AM | #1 |
Rep 153
Halogen to LED bulbs change. No issues so far...
I have been hesitant to do the bulb change due to other thread that talked about needing to do coding. I took a chance last weekend and did the change in my 2013 328i with basic halogen light and I got no error message nor flicker issue. The only thing I needed to do is lower the horizontal height. So far so good.
Update: I only updated low beams. No issues during night time. During day time, I do noticed both cold check (when turn on ignition) and warm checks (during idle and driving) blinkings with daylight running light on. I solved my low beam day time blinking issue by turning off the daylight running lights. More update: I decided to code away the low beams' cold and warm checks. This is because I want to turn on DRL during daytime driving. Last edited by Pdxway; 11-09-2018 at 10:22 PM.. |
11-05-2018, 09:59 AM | #2 |
Rep 16,089
If your bulbs have ballasts then you probably won't get a warning or flicker, but if you don't code out the cold/warm checks then the lights will blink every thirty seconds or so. Sitting in the car you have no way of knowing that it's happening.
Pdxway18.50 |
11-05-2018, 10:05 AM | #3 | |
Rep 5,457
Drives: F30
Its a $50 investment for a vehicle that you own. You will definitely find more than $50 worth of features with it, I promise. You do not have to know ANYTHING about coding to use the basic features. Just sayin... |
11-05-2018, 10:05 AM | #4 | |
Rep 153
https://www.amazon.com/gp/aw/d/B07H2T8XYM?psc=1&ref=yo_pop_mb_pd_title Let me check further if it blinks every 30 seconds or so. I was outside of the car looking at it for quite a while, I do not think I saw blinks.... Thanks! |
11-05-2018, 10:08 AM | #5 | |
Rep 153
11-05-2018, 12:23 PM | #7 |
Rep 153
It got something like this:
Pre-installed EMC decoder:*Equipped with EMC decoder, helps to fix connection issues for some vehicles* Is EMC decoder similar to 'Intelligent Control'? I checked again briefly and see blinking the first time I turn on car, where the car is in auto mode, trying to decide to use headlights or daylight running light. My car decided to use daylight running light in a couple seconds. But, once I switched to low beams, it remains constant without blinking. |
11-05-2018, 04:15 PM | #8 |
Rep 16,089
Read their ad copy, they call it both. Others call the same thing canbus adapters, though they have nothing to do with canbus. The blinking at start up is the cold check. Later it will get the warm checks. You don't see cold and warm check blinking with halogens because the pulses are too short to heat the filament enough for it to light up. LEDs don't heat up to produce light, and their response time to applied voltages is around 1/5 that of halogen, so they will blink. The only way to stop the blinking is to code to off the cold and warm checks.
11-05-2018, 04:37 PM | #9 | |
Rep 153
May I know how often is the warm check? Is it every 30 seconds? Or is it based on certain temperature? I wonder why I don't see any other blinks yet after that first start blinks, Thanks! Last edited by Pdxway; 11-05-2018 at 04:54 PM.. |
11-05-2018, 05:52 PM | #10 |
Rep 16,089
I coded most of my lamps when I put them in, so I didn't see them do any checks. My inner tail lights got overlooked. I seldom stand behind the car with the ignition on, but a few weeks ago when I did I saw them blink, alternating from left to right, maybe every 45 seconds or so. It stopped after I coded them.
11-05-2018, 06:14 PM | #11 | |
Rep 153
11-05-2018, 09:00 PM | #12 |
Rep 16,089
You should only have to turn the ignition on to see the blinking. That's what I did when I saw it on my tail lights. You won't see anything when the lights are turned on. The pulses are sent to the lights when they're off, to detect if they're blown or not.
11-05-2018, 09:27 PM | #13 | |
Rep 153
Thanks for all the information! I appreciate that! |
11-06-2018, 08:11 AM | #14 |
Rep 16,089
How do you know? My inner tail lights were blinking for 2 months before I noticed it. If I hadn't happened to have the ignition on while standing behind the car with the car in the garage where it was dark enough that the blinking was obvious they'd still be blinking today.
11-06-2018, 08:35 AM | #15 | |
Rep 153
*I have been standing in front of my car for multiple times, each time multiple minutes, while it is dark. *My wife stand in front while I turn on ignition, multiple times. *Sitting in car in the dark inside garage like a dummy, turning on ignition for multiple minutes and observe the light on the garage wall. Repeat multiple times. *Park outside the garage with garage door down, in the dark, observe the light multiple minutes on the garage door. Repeat multiple times. *On multiple stop lights, observe the light shining on the car in front of me. My wife and I have yet to observe any blink when it is dark. Yesterday morning, when there was a bit sun light, only in that one instance I observe a few blinks in succession when I turn on the car and the car trying to decide to use low light or daylight running light. I wonder may be it is because my car is 2013 model year and the electronic is not yet that sophisticated? Last edited by Pdxway; 11-06-2018 at 09:01 AM.. |
11-06-2018, 09:52 AM | #16 |
Rep 153
I recruited my daughter to check the low beams in front of the car this morning. No cold start blink. No any blink that she can see.
Since all three of us so far can't detect any blinks, I will say either the LED's EMC decoder is helping or my 2013 does not do cold and warm check. So far 3 nights and 2 mornings driving, plus multiple non driving checks, got no blinks during dark. Anyway, will continue to observe. |
11-06-2018, 11:05 AM | #17 |
Rep 16,089
I don't know if you noticed it, but I mentioned that the checks only happen when the lights are off. I can't say if the ballasts on my headlights prevented blinking, having coded the checks off when I put the bulbs in. I can only confirm that the rear lamps that I didn't code did blink until I coded them.
11-06-2018, 11:39 AM | #18 | |
Rep 153
Like I mentioned, so far during first turn on ignition, I did not observe blinks during dark time. During constant on time like idling and driving in the dark, I did not observe blink. During ignition shutdowns in the dark, I did not observe blinking. My wife and daughter looking directly from the front at the low beams, they did not observe blinks. So I really don't think I have anything to worry about as of now. I guess I am lucky with my choice of LED. |
11-06-2018, 12:49 PM | #19 | |
Rep 153
It is during day time when the daylight running light is on. Indeed I can see blinks during cold check and one blink on each light every minute or so. I turned off daylight running lights option and it actually helps. No more blinking during day time! So I think I am covered during day and night time now. Thanks! Last edited by Pdxway; 11-06-2018 at 12:56 PM.. |
11-06-2018, 12:55 PM | #20 |
Rep 16
Drives: 2015 328i
How is the beam/light quality?
11-06-2018, 01:10 PM | #21 |
Rep 153
I like the white better than the old halogen color. My old halogen has pretty clear cut off. The LED would blind incoming cars if used as is. I had to open the hood to use a hex key to adjust the aim to point lower. It seems stronger in short distance. I can't really comment about driving high-speed in pitch dark as I have not tried.
Amazon reviews are few, but all 5 stars. Other than that, I think it looks better from the front at night. Look a bit higher end than my old halogen bulbs. : ) |
11-06-2018, 03:03 PM | #22 |
Rep 153
BTW, if you see my post above yours, it will blink during daytime with daylight running light on. You either need to do coding or turn off daylight running light to stop the blinking.
No blinking issue during night time so far. This is just for low beams. I believe for back light, etc, you will need to do code. Last edited by Pdxway; 11-06-2018 at 03:14 PM.. |
