07-18-2012, 05:32 AM | #23 | |
Rep 10
If these are different, should they have different part numbers?
The same should apply to gearbox, diff, drive shaft, isn't it? For example, 320i shaft should have a different part number v.s 328i shaft. Is that a real case? Quote:
07-18-2012, 11:16 AM | #24 | |
Rep 1,544
Tuned 320i doesn't equal tuned 328i, if it does then Kelleners would have quoted the same power & torque figures for both engines. Most likely explanation is BMW "bins" the engines, i.e. those that makes at least 245ps will be 28i & anything in between that & 184ps will be 20i. |
07-18-2012, 11:25 AM | #25 | |
Rep 1,544
PN for 320i propshaft w/automatic gearbox: 26 11 7 609 365 PN for 328i propshaft w/automatic gearbox: 26 10 7 632 653 The diffs are definitely different cos the final drive ratio is different. |
07-26-2012, 09:13 AM | #27 | |
Rep 2,003
Giving all this discusion about the differences between the 20i and 28i forms of N20 it would be easier to buy the one you want, as BMW prefers to keep us in the dark.. (yet still reaping the benefits of one size fits all) |
07-26-2012, 11:07 AM | #28 | |
Rep 1,544
For all things mechanical, there's always a performance variance between examples. |
07-26-2012, 12:42 PM | #29 |
Rep 430
I am sure that the 320i engine could be configured in a 328i engine easily. Probably due to equipment, it is 150lbs lighter which is a lot.
The 2.0T in the 320i has an higher compression ratio at 11:1 than the 2.0T in the 328i at 10:1. Oddly, BMW Canada stills claims a 6-sp. for the optional automatic transmission for the 320i but I would be surprised if it was the case. Probably a typo. http://www.bmw.ca/ca/en/newvehicles/...figurator.html |
07-26-2012, 11:54 PM | #30 | |
Rep 1,544
For the engine, the 28i have more headroom for tuning as tuners big and small, well known & not well known quote different figures for both engines. |
07-30-2012, 12:27 AM | #31 | |
Rep 2,003
I buy the small modification theory more, which allows for different software outputting different HP (but can't be used on 20i engine because it would break) |
07-30-2012, 01:56 PM | #32 | |
Rep 1,544
Btw, the engine model listed on the HK EPD EFV list for cars with 20i is N20B20B & for cars with 28i is N20B20A. |
09-23-2012, 07:20 AM | #33 |
Rep 1
320i engine
if so much is the same on these engines, why waste the extra cash buying a 328i?
I have an auto 320i and loving it. Raced an e90 330i manual the other day in gauteng and beat him by half a car length... coming from a standard car, i would say there is huge potential in this engine! |
03-02-2013, 07:18 PM | #34 |
Rep 868
I wonder what are the differences too.
Is BMW using a downtuned version of N20 on the 320i, and using an N26 on the newer 328i? I went to REALOEM.com and they have an N26 version on the 328i now.
03-02-2013, 07:44 PM | #35 |
Rep 391
I did a ton of research before settling on 328i over the 320i. I noticed a tuned 320i would only bring power outputs near the 328i, but never over. Dont know if that remains true today.
It bugged me that tuned 328i output were well in excess of the tuned 320i. Hence my decision to go for the 328i. Apart from compression ratio, driveshaft and engine tunes, another rival bimmer forum recently found pistons were different as well. If you can, go for the 328i or your decision will always bug you. Alternatively go for the 320d
2018 BMW X3 xDrive30i M Sport
[sold]2013 BMW X3 xDrive30d [Sold] 2013 F30 328i |
06-04-2013, 03:08 PM | #36 |
Rep 121
Has anyone driven both?
Just curious if anyone has driven both a 320i and a 328i. If so, did you feel a significant difference?
Has anyone gone from an e90 328i to an f30 320i and felt dissapointed? So far, I've read one review from a poster on here who test drove one for his wife. He said it felt just like his 335i minus the power (of course), but said he really enjoyed the car and placed an order. I've read the performance specs and there's obviously a difference, but I'd like to hear from someone who has driven both and can give feedback on the overall driving experience. |
06-04-2013, 07:04 PM | #37 |
Rep 3,780
According to BMS the 320 runs 8psi peak and the 328 peaks at 17psi. They already have the in house 320 running 18psi.
'98 Dinan/RMS stage 2+(VAC cams, CES Cutring etc) '15 Buick Regal "T"(wife) '06 Saab 9-5 Combi 5mt (full suspension, LSD, clipped turbo etc) |
06-04-2013, 08:18 PM | #38 |
Rep 10,509
Do you guys see a lot of 320i in your area? Here in San Diego there were TONS of 328 on the lots, very few 335 and no 320
I wonder if that is a specific decision by the dealerships or if it is taking a while for them to get over hear. I have also never seen a 320 on the road. The car seems like a great deal and would be an excellent step up for someone who isn't used to or doesn't want more power (i.e. former 318i owner) |
06-05-2013, 09:39 AM | #39 | |
Rep 487
Drives: E90 328xi
I had originally planned on getting a used 335 in a couple years, but now I'm thinking of going brand new 328 or possibly even a 320i + mods. Time will tell, I guess. (335i guys, I'm in no way saying any of these cars are comparable to your 335i. )
Eibach Pro Kit | 19" Avant Garde M341 | BMS PBX
06-05-2013, 04:55 PM | #40 |
Rep 44
AC Schnitzer quotes 245hp with their piggy pack for the 320i.
That's up from 185hp/270Nm to 245hp/350Nm. It's really expensive, around 2750€, but comes with "full" warranty in Europe. For some reason it is not availabe for the XDrive. Check here and here.
2013 BMW F30 320i - M-Sport, Alpine White, M Sport suspension and brakes, Sport AT, VSS, PDC, Xenon, High-beam assistant, Harman/Kardon, Extended BT, Rims 403M (summer 19") and 397 (winter 18"), M Performance: Exhaust, Rear Bumper Diffuser, Carbon fiber mirror caps, Carbon fiber rear spoiler, Black kidney grilles, Floor mats. 3M Brushed Black Metallic vinyl wrap roof.
06-05-2013, 05:17 PM | #41 |
Rep 3,780
They put on their beta stage 2 and hit 266whp/278tq.
08-08-2013, 02:08 PM | #42 | |
Rep 12
Drives: E90 330i, F32 435i
and 220 ft-lb vs 200 ft-lb. E90 330i has 75 hp more.... where are you going to get his from your 320i? 0 to 100 the 330i is 1 second faster. |
08-08-2013, 02:26 PM | #43 | |
Rep 3,780
Here it is again. So its more like 255hp vs 200-210, and torque of 220ft lbs vs 240-250. But remember the beauty of forced induction. The 320 tune with no hardware is netting 266whp and nearly 280ft lbs of tq to the wheels.
08-08-2013, 05:01 PM | #44 | |
Rep 12
Bmw raitings for the 320i is 200lbs, 7.1 sec to 60 mls with the auto. 330i is 6.1 sec to 60 mls, this is from bmw n/a. you got 1 sec difference and thats a lot. |
n20b engine, n20b motor |
