BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N55 Turbo Engine / Drivetrain / Exhaust Modifications > Glitch with MHD?
Studio RSR
      04-06-2020, 10:54 PM   #1
sponitz
sponitz's Avatar
Drives: BMW 335i
Exclamation Glitch with MHD?
Sorry for the long book of a forum post.
I own a 2014 BMW 335i that's decently modified, including the new Spool FX-150, a single Walbro 450, a GFB DV+, and all the other bolt-ons. David Shoup tunes my car; I've been working with him for almost 2-years now. I've never had a better experience with anyone in the car community, and recommend him to anyone with a BMW that's looking to get tuned.
Anyways, all of a sudden, my oil level sensor stopped working on the car. I would get an error when trying to measure that said: "oil level measurement inactive." My car is still under warranty, so I brought it in, and they replaced the oil level sensor, still no luck. They put an oscilloscope on the line going to the DME to check continuity; everything checked okay. They said I needed a new DME which warranty won't cover. So, I ended up sending my DME and FEM to get rebuilt, reprogrammed by Levan and BIMECU Solutions. He is accommodating and is still helping me with the issue. He shipped the DME and FEM back, I put the car back together, and everything worked. When I flashed MHD on the vehicle, it stopped working again. I tried to flash the car back to stock with MHD, and it still wouldn't work.
Earlier today, Levan remotely programmed my DME, and it started working again. Has anyone had this issue before? I joined this group after some friends recommended I make a post, so here I am.
I already emailed MHD and am awaiting a response.
Thank you in advance!
      04-07-2020, 03:41 PM   #2
Tpriest7893
Drives: Bmw 335i f30 N55 ( sold)
  [0.00]
2012 bmw 335  [0.00]
02 2002 m3 Vert  [0.00]
If you flash back to stock map does the issue fix itself?
2012 bmw 335i sedan
VRSF catless DP
VRSF 5? HD IC
Stock intake(had open before and was sick of noise)
BMS CP
550i 351m rims with 275/245 set up.
No tune as of yet.
      04-07-2020, 05:44 PM   #3
thejeremyman9
thejeremyman9's Avatar
4364
Drives: 2015 BMW 335i
He already said in his OP that "I tried to flash the car back to stock with MHD, and it still wouldn't work."
My follow up question would be - was this flashing to stage 0, or completely uninstalling MHD?
I would try the latter as that completely removes the MHD software, as opposed to just changing the map. This should isolate MHD itself.
      04-07-2020, 05:46 PM   #4
Tpriest7893
  [0.00]
2012 bmw 335  [0.00]
Ah shit I missed that lol and with all the stuff I have read with MHD I never seen this issue so this is interesting!
2012 bmw 335i sedan
VRSF catless DP
VRSF 5? HD IC
BMS CP
No tune as of yet.
      04-07-2020, 08:00 PM   #5
sponitz
sponitz's Avatar
Drives: BMW 335i
I did completely remove MHD, not stage 0. The issue was still there. Levan from BIMECU Solutions was able to fix the issue by coding my car again. But this seems to be an issue with MHD. I'm not sure if anyone else has experienced this.
      03-25-2021, 04:32 PM   #6
omarsat89
Drives: f30 2014 335i
hi dear did you fix this problem because i have the saem thinks
sorry for bad english
      11-08-2022, 04:24 AM   #7
NathObeaN
NathObeaN's Avatar
Drives: M2 Competition (MY2021)
Did you ever get to the bottom of this? I have seen something similar recently and would be interested to know what the true cause/fix is? The guy I use for coding simply re-coded the necessary element via e-sys to bring back the oil measurement (with MHD still installed) but it would be useful to know if there is a way to prevent it from occurring in the first place.
      11-08-2022, 05:48 PM   #8
Pure435i
Drives: BMW 435i M-Sport
I have the same issue, I am also on MHD. I tried replacing oil level sensor with no luck.
Curious to hear possible results/ fix
Thanks
335i, f30, oil sensor
