BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Wheels and Tires -- Sponsored by The Tire Rack > Newbie Question: 225 40R 18 Compatible?
      11-14-2017, 12:56 PM   #1
Ladhaan
Drives: 2018 430i xDrive M Sport
Hi,
Newbie here. I just purchased a 2018 i430 Xdrive Grand Coupe with M Sport Package. As the car comes with performance tires, I need to get winter tires. I found an awesome deal on 225 40R 18, but specs show I should be using 225 45R 18. Will this be an issue, or should I be ok with the 225 40R 18?
Thx!
      11-29-2017, 12:34 PM   #2
.BMW.
.BMW.'s Avatar
Sweden
1863
Drives: BMW F11/F31
225/40-18 is more than 3% shorter than OEM 225/45-18.
The shorter tires have quite a few drawbacks, increased wheel to fender gap, less wheel protection, increased speedometer error and the odometer counting more miles than actually travelled.
      11-29-2017, 01:08 PM   #3
floydarogers
Curmudgeon and Pedant
floydarogers's Avatar
Drives: 2010 335d, 2014 328d
While they can be used without causing mechanical problems, I also don't advise going smaller with tires.
Going larger is a bit more acceptable. Also, going go-flat (rather than RFT) is acceptable and gives you a bigger range of tires to buy from (perhaps that's what you've already done?)
      12-02-2017, 08:03 PM   #4
Venzen007
Drives: 2015 428i X drive Gran Coupe
I'm in a similar situation with a gently used 428i X drive Gran Coupe. Can you tell me whether your X drive came with staggered wheels or are they the same size front and rear?
      12-03-2017, 02:25 AM   #5
Ladhaan
Stock performance tires were staggered, but I forget the exact size. Got square setup for my winter set, which I just put on today. Got 255/40/18 Blizzak LM32 RFT with Replica rims all in for $1300. I know narrow is better, but the price on the set was too good to pass on.
      12-03-2017, 05:27 AM   #6
robbiep
Drives: VW e-Golf !
Oh, I've just spent loads of money on buying a nice car. Now I'd like to cut corners on buying tyres, because I can save a few dollars / pounds / lira / whatever if I buy the wrong size.
Read if back to yourself.
There's a phrase : penny wise, pound foolish.
crono06127.00
      12-03-2017, 08:40 AM   #7
jnecr
Drives: 2014 328d
Nothing wrong with saving a bit on tires.. I mean.. he's bought new tires. It's not like he was trawling eBay for deals on used tires. Plenty of people are running 255/40/R18s for a square setup.
2014 328d
      12-03-2017, 01:17 PM   #8
Cruzship0991
Drives: 2017 BMW 340i 6MT
Newbie here as well. Just recently purchased a used 340i and I live in Germany so winter tires are a requirement. Decided to go with a new wheel/tyre setup from tire rack. Went with the Sport Edition A10's 18x8 with the 225/45R-18 Blizzak WS80 XL's. Currently installed are 19's with 225/40 R19 P Zero RFT's on the front and 255/35 R19 P Zero RFTs on the rear.
So my question is do I need to get an alignment done or can I just switch the tires myself? As well as any follow on maintenance thats recommended?
First time having to deal with this and didnt find to many things with search that fit my specific situation lol. Everything Ive found so far suggests that I should be fine to swap them but figured Id check with those who have more experience.
Thanks!
      12-03-2017, 02:12 PM   #9
floydarogers
DIY is perfectly fine. No alignment necessary - unless in checking your summer tires you notice some uneven wear.
Make sure you check tire pressures and reset TPMS system.
      12-03-2017, 02:16 PM   #10
Cruzship0991
Thanks! I figured as much.
      12-03-2017, 06:14 PM   #11
floydarogers
One more thing: I prefer to put some anti-seize on the wheel bolts. Yeah you have to watch the torque but you'll at least be able to get it off in the spring.
Bozos at Bridgestone broke a bolt off last spring - and they were the ones that tightened it 5 months before.
      12-03-2017, 10:17 PM   #12
Ladhaan
Wake up on the wrong side of the bed bud?! These are great tires and are new. If you want to spend extra dough on narrower tires, go for it. I decided to save a couple hundred bucks.
      12-03-2017, 10:18 PM   #13
Ladhaan
Appreciate the comment
      12-04-2017, 09:06 AM   #14
wdeerfield
A family of bimmers
Drives: '18 G01 X3M40i
255s! for winter! let us know how that works out. ive got 235 and even that is too wide for snow.
2018 PB/Black G01 X3M40i | 699M | ZDA | ZPP | ZPX | Maxton front lip | X3M vents | 15mm Spacers | Diamond G20 style grills
      12-04-2017, 01:19 PM   #15
Ladhaan
Will do!
