08-24-2016, 10:44 AM | #1 |
Rep 156
Oil Leak
So I took my car in to get its "pre-purchase" inspection (bad mistake, should've done it before I bought it), they found an oil leak.
View post on imgur.com Right now looking at a drain plug and an oil sensor and then closely monitor it... Anything else could be a cause for the N20? |
08-24-2016, 01:31 PM | #2 |
Rep 230
Looks as a leak is from the plug. Could be simply loose or bad gasket, simple replace will fix.
Worse if someone over tightened the plug damaging the thread. It is plastic and needs very controlled hand tight to 18 lb/f (if I remember right). If that is damaged, that you need oil pan replacement. Not the end of the world, but will cost a few hundred I guess. |
08-24-2016, 03:26 PM | #3 | |
Rep 156
I guess at a few hundred I'm still ahead on what the BMW dealers here wanted for a CPO, that leak and one bent rim were the only bad news out of the PPI. |
08-24-2016, 05:06 PM | #4 |
Rep 156
So I gave it some thought, this diagnostic replacement order seem to make sense?
Oil Drain Plug + Sensor Gasket -> Sensor -> Oil Pan I'm actually not too convinced the sensor is bad, it seems to be detecting the level just fine. |
08-26-2016, 02:12 PM | #6 |
Rep 156
08-26-2016, 03:44 PM | #7 |
Rep 3,940
