BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > Regional Forums > UK > F30 M Sport ARB
      07-17-2016, 11:34 AM   #1
ar68
ar68's Avatar
England
149
Drives: F36 440i
F30 M Sport ARB
Has anybody replaced the front ARB on their xDrive with one from a M Sport model (25mm dia against 22.5mm dia on xDrive). Need to improve the handling of this car but don't want to go too far from stock ie fitting Birds ARB. Ordered ACS springs and they should be here any day now. Wondering if I should fit better ARB before I get alignment and headlights checked.
      07-18-2016, 03:20 AM   #2
Watsey
Drives: F31 330D sDrive M Sport
What aspects of the handling are you trying to improve ? If you want better turn-in then a stiffer rear ARB would be a better bet.
If you want flatter cornering stiffer front & rear ARBs will help hugely, depending upon what you choose.
Subframes have to be dropped to install the ARBs so definitely wait until afterwards (plus, say, 50-100 miles for things to settle down) for the geometry and headlight alignment.
      07-18-2016, 03:45 AM   #3
teaston
Drives: X3 M40d
As Watsey says either change both or just the rear. Just a stiffer front ARB would likely cause the car to understeer more.
      07-18-2016, 03:52 AM   #4
ar68
ar68's Avatar
England
149
Drives: F36 440i
Thanks for info. I just want an all round improvement as I have no confidence in the handling or braking of this car compared to previous models I have owned.
I didn't realise fitting new ARBs was such a big job so I might just fit ACS springs and see how I go on.
      07-18-2016, 03:56 AM   #5
ar68
ar68's Avatar
England
149
Drives: F36 440i
Thanks.
I don't have adaptive suspension on my car. Are you happy with how yours handles after fitting ACS springs. Planning to fit mine myself like you did too.
      07-18-2016, 03:58 AM   #6
teaston
Drives: X3 M40d
Thanks.
Yes I'm happy with it, but i do have adaptive.
Best to fit the ACS springs first and see how you like it.
      07-18-2016, 06:25 AM   #7
tbenn1
Drives: f31 335d
If your near Shropshire you welcome to come out in mine, acs springs and birds antirollbars
      07-18-2016, 07:44 AM   #8
ar68
ar68's Avatar
England
149
Drives: F36 440i
Appreciate the offer. I will give you a shout if I'm ever down your way.
      07-18-2016, 04:49 PM   #9
M40CCA
M40CCA's Avatar
1437
Drives: BMW 335xdrive LCI msport
Which engine do you have ?
335d xdrive 2016 M-Sport
745Le xdrive 2020 M-Sport
      07-18-2016, 05:02 PM   #10
Tengocity
Tengocity's Avatar
Scotland
8566
I had birds ARBS all round, then changed them back to standard when I changed to the ACS RS coilovers. Except instead of the standard rear xdrive bar I put in the sdrive one which 1mm thicker 13v12mm.
Whilst the car handles better overall now on the RS suspension I think the turn in was sharper with the beefy birds ARBs.
So in summary I would change the rear one or I'd change them both, but definitely not the front one only. I'd get ACS springs first though!
There is an adage that suspension engineers use- if you think it's the rear that's the issue then it's the rear, if you think it's the front that's the issue then it's still probably the rear...
      07-19-2016, 12:55 AM   #11
ar68
ar68's Avatar
England
149
Drives: F36 440i
Same as you mate except mines a pre LCI.
      07-19-2016, 01:08 AM   #12
ar68
ar68's Avatar
England
149
Drives: F36 440i
I will fit the ACS springs and see how I go. Having owned an E46 M3, E83 X335d Msport, E46 M3 CS, E60 M5, E92 335i Msport and an E84 X125d xLine before this car, its the first time I haven't had confidence in a cars abilities and that's including that X1 mistake I owned for 4 weeks.
      07-19-2016, 02:35 AM   #13
Tengocity
Tengocity's Avatar
Scotland
8566
That list of cars are some of the best cars BMW have ever made though so perhaps not the best comparisons! However, this 335d is the only BMW I've had that I've felt the need to modify the hell out of, so I know what you mean.
      07-19-2016, 05:12 AM   #14
ar68
ar68's Avatar
England
149
Drives: F36 440i
Does the extra 1mm diameter on rear ARB make that much difference. Makes you wonder why BMW would spec two different items so similar too each other rather than just standardising them all.
      07-19-2016, 05:13 AM   #15
Tengocity
Tengocity's Avatar
Scotland
8566
It made a small difference with reducing understeer. Not sure it's worth doing on its own but I wa taking the birds arbs off anyway.
      07-19-2016, 04:02 PM   #16
teaston
Drives: X3 M40d
It's an 8.3% increase in diameter,. You'd be happy if the car came with 8.3% extra power wouldn't you?
      07-19-2016, 04:08 PM   #17
ar68
ar68's Avatar
England
149
Drives: F36 440i
Good point well made.
      07-19-2016, 04:33 PM   #18
XK140
Drives: SEAT Leon Cupra Carbon/GT86
Personally I wouldn't have a clue to what difference it makes.
If you fit a rear arb to a front drive car which did not have any bar at all,as I have in the past,by what percentage do you improve it?
      07-19-2016, 04:53 PM   #19
NISFAN
NISFAN's Avatar
Drives: BMW M2
Actually it's something like 40% stiffer. So quite a difference.
      07-20-2016, 03:14 AM   #20
teaston
Drives: X3 M40d
So an 8.3% increase in diameter equates to 40% increase in stiffness?!
      07-20-2016, 04:07 AM   #21
NISFAN
NISFAN's Avatar
Drives: BMW M2
Yep, don't forget in cross sectional area you've gone up 17.4% or thereabouts.
Also the outer diameter plays a large part in the equation, from memory D to the power of 4 is in that torsion equation.
      07-20-2016, 04:56 AM   #22
ar68
ar68's Avatar
England
149
Drives: F36 440i
So its well worth doing then?
