01-09-2014, 05:55 PM | #2 |
Rep 503
The 2014 BMWs equipped with a ZF 8 speed transmission support a special coasting mode where the transmission disengages the engine (e.g. goes into neutral), the engine drops to idle speed, and the car coasts.
This allows you to lose less speed when coasting, which may prevent you from needing to hit the gas again. Normally, the transmission back drives the engine while coasting, downshifting to keep the engine above 1000RPM. In this mode, no fuel is injected to the engine while coasting, at the cost of higher frictional losses and hence your car slowing down quicker. |
01-09-2014, 06:05 PM | #4 |
Rep 100
Correct...It essentially decouples the engine from the rest of the drivetrain so you can "idle" at highway speeds as long as your foot is off the gas.
01-09-2014, 06:10 PM | #5 | |
Rep 503
As I mentioned, coasting before already did not require any gas -- it just caused you to lose speed a lot more rapidly. |
01-09-2014, 07:31 PM | #6 |
Rep 10,509
When I spent a day with a 2014 328 it seemed like the "coasting" would only work when I lifted my foot off the gas, and it did not work when I was using the cruise control.
Does anyone know if the "coasting" will work with speed control? I thought the most efficient way to drive on the highway was to use the cruise control to minimize speed changes, but if it negates the "coasting" feature, will it be better not to use the cruise control and try to coast? |
01-11-2014, 06:44 AM | #8 |
Rep 444
I thought the whole point in leaving the engine in gear was to save fuel, as no (or less) fuel is needed to keep the engine turning over?
If you put the car into neutral, I thought more fuel is needed in order to keep the engine idling? |
01-11-2014, 10:29 AM | #9 | |
Rep 6,227
Drives: 2018 340i M Sport
Garage List 2018 BMW 340i M Sport [9.38]
2020 BMW M340i xDrive [10.00] 2018 BMW 340i M Sport [8.00] 2006 BMW 330i Sport [4.50] 2004 BMW 330i ZHP [7.25] 2000 BMW 328i [6.00] |
01-11-2014, 11:01 AM | #10 | |
Rep 129
If you WANT to come to a stop you SHOULD engine break because the car doesn't use fuel and it slows down a lot faster than in neutral WITH the engine still pumping fuel. |
01-11-2014, 11:21 AM | #11 | |
Rep 1,805
The car is using more fuel when you engine brake opposed to a decoupled drivetrain / idling engine. Period. The concept of coasting... Think about a red stop light a quarter of a mile in front of you on a 55mph road. You let off the gas and you can easily coast to the light without the engine slowing you down so fast. |
01-11-2014, 11:42 AM | #12 | ||
Rep 444
01-11-2014, 01:04 PM | #13 | |
Rep 129
01-11-2014, 01:10 PM | #14 |
Rep 209
The manual says that coasting only activates in ECO pro mode and not when any of the following conditions exist:
Cruise control Foot on brake Foot on gas Speed below threshold I've also found there to be a refractory period for it. If you hit the brakes once on a downhill, it won't coast again for some time. Maybe until you hit the gas again and then keep your feet off both pedals. |
01-11-2014, 01:24 PM | #15 |
Rep 503
Also, remember that the F30 has regenerative braking for alternator recharging. When you use Coasting, the car can no longer regeneratively brake since the driveline is no longer connected to the engine belt, where the alternator resides.
(This is one situation that the ActiveHybrid handles a ton better, where the equivalent of "coasting" mode actually turns off the engine, and the electric motor is still connected to the driveline for regeneration and also slight boost) |
01-11-2014, 01:25 PM | #16 |
Too much is never enough
655
Rep 3,079
This would be beneficial in situations where you are traveling a long slight downgrade where there's no concern about scrubbing speed at any point. It will eliminate the normal losses associated with spinning the mass of the trans gear train. The gains associated with approaching lights on high speed roadways would be nominal. As noted, an injected motor doesn't add fuel when there's no load (i.e. coasting). The transmission spins the crank if the torque converter is locked. If it's not, it's fluid coupled which is a huge waste of energy.
01-11-2014, 02:08 PM | #17 |
Rep 2,248
So the normal coupled mode, which provides engine braking, uses no fuel but takes you only a limited distance. Coasting uses the fuel required to keep the engine turning over at idle, but lets you go farther, without adding power, than the coupled mode would. Which will be better in terms of fuel savings will depend on the specific circumstances.
01-11-2014, 03:52 PM | #19 | |
Rep 503
We are arguing over a really trivial (1%? Less than 5% for sure) fuel savings here. |
01-11-2014, 04:14 PM | #20 | |
Rep 15,858
All part of BMW's Eco-Pro push, to get the 25% improvement in figures by 2020. Same for innovations such as Predictive Driving Assistant and Eco-Pro Routes, all about improving mpg potential. We take for granted such features as NIC (Neutral Idle Control) these days, do many even know it's there disengaging the transmission while we sit with the footbrake on? A feature along with better torque converter lock up which improved AT fuel efficiency by 3 - 6%. Every little helps. Reasons why our UK 3.0d engines are now into 50+ mpg (imperial gallons). HighlandPete |
01-11-2014, 04:53 PM | #21 |
655
Rep 3,079
I agree everything cumulatively helps with the drive cycle testing, but real world is generally less effective. I'm not sure about the testing on your side of the pond, but the US drive cycle regimen is ridiculous.
01-11-2014, 05:20 PM | #22 |
Rep 209
What do you all think has a worse long term effect on the power train?
If you coast, the engine turns at a lower RPM. --Less wear on the cylinder walls and spinning parts of the engine, but the transmission cycles more between neutral and drive. More transmission wear? |
